Old Nov 17, 2012, 05:41 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Originally Posted by Airman74 View Post
I see what your saying about wing moving with full deflection,, I noticed on mine if I moved ailerons slowly it didn't move wing as much,, I'm wondering if this is just from those huge ailerons moving so quickly and hopefully with air pressure over the wing it won't be an issue. So did anybody notice the little hatch marks on the side of the fuse right at back edge of ailerons?? I wonder if this is a reference point for setting ailerons at 0 undercamber??? And is it just me or is there a ever so slight amount of anhedral in these wings???
The dimples in the fuse is to align the ailerons correctly. There's a tad bit of anhedral on mine too - think it's normal and should not affect flight. I don't see the wing flexing with the aileron deflection - maybe my eyes aren't as good as yours...
crazyj is offline Find More Posts by crazyj
Old Nov 17, 2012, 05:45 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
I don't see the wings flexing in the video either - bad eyes too I guess.
bobly is offline Find More Posts by bobly
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Yes on my larger Kyosho Red Bull Edge 540, it has that same anhedral, so maybe inherent in design of the edge?? Wonder what purpose it would serve??
More stable inverted?? ,,, and has anyone here heard of mixing aileron trailing edge reflex with up elevator in order to stabalize harriers???
Airman74 is offline Find More Posts by Airman74
Old Nov 17, 2012, 05:51 PM
_Colton_ is offline
Find More Posts by _Colton_
Team Horizon Hobby
_Colton_'s Avatar
United States, AZ, Tucson
Joined Feb 2012
Just to shed some quick light on the wing moving thing.
Any aircraft with large ailerons moving quickly with a good spring gear will do this on the ground. Every Giant scale I've seen or owned has done the same.
Nothing to be worried about at all.
On a side note we had a few of these flying indoors last night. It's a blast! In a small space as long as it's post stall it's very predictable and fun to fly.
_Colton_ is offline Find More Posts by _Colton_
Site Sponsor
Old Nov 17, 2012, 06:10 PM
0gravity is offline
Find More Posts by 0gravity
A tale of two slickies
0gravity's Avatar
United States, IL, Chicago
Joined Feb 2010
Flew it... Quite a bit. Stock esc was bad out of the box but had another a friend loaned.
A. Tail wheel went missing after first flight but was able to take off from grass every time. Check your tail wheels.
B. Wish wings were magnetized to fuse... The little screws defeat the purpose almost. I'll need to keep wings on.
That's the bad stuff. Plane tracks very well. Cg with my 500s was moved back to 1/2" back from wall. Getting 6 minutes.
Hover hard to hold... I might want to look at other prop options... Thing is a KE KING tho. I want to look into fine tuning for harrier - it's my fault but got alotof winng rock.
Flying wot is a kick in the pants :-)
Landings and takeoffs very easy.
Flew in wind and calm. Got bounced around and am thinking about a gyro already.
All in all its a great flyer. Well worth the money and got folks talking... I really like this plane. Heckuva lot!
0gravity is offline Find More Posts by 0gravity
Old Nov 17, 2012, 06:15 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Thanks for the flight report Have you called HH? I'm sure they'll send you another ESC. Did it have inverted wing rock too?
FlyWW1 is offline Find More Posts by FlyWW1
Old Nov 17, 2012, 06:28 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
The batteyr compartment is pretty big length and width wize. I have a TP 480 3s and it fits fine. They recommend that the battery be pushed all the way forward in the compartment to balance. I'm guessing a larger heavier battery can be slid back to find balance. I'm sticking with the recommended size to keep it light weight.
Here's a quick video to get your taste buds going...
http://youtu.be/S1ulcCF_uOg
Gosh that was entertaining. Thanks. Would have been way better if you could waggle the control surfaces to the music.
shastamike is offline Find More Posts by shastamike
Old Nov 17, 2012, 06:44 PM
0gravity is offline
0gravity's Avatar
Joined Feb 2010
Not worried about it HH has always treated me very well. I did not try inverted harrier
Old Nov 17, 2012, 07:01 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Quote : Stock esc was bad out of the box.
Did you try putting throttle trim ALL the way down to lowest setting. On mine I had to do this before it would arm
Old Nov 17, 2012, 07:13 PM
Sixinarow is online now
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Ok, ignorant question. Is this designed for two or three cell? Or both?
I have 450mAh 2S 25C already
460mAh 2S 25-40C and 370mAh 3S 25-40C Nanos are on order from HK.
Sixinarow is online now Find More Posts by Sixinarow
Old Nov 17, 2012, 07:14 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
460 2S 25-40C and 370 3S 25-40C Nanos are on order from HK.
450-500mah 3s
Old Nov 17, 2012, 07:52 PM
0gravity is offline
0gravity's Avatar
Joined Feb 2010
Yup. Checked 1st.
Old Nov 17, 2012, 08:08 PM
Addicted
Joined Dec 2011
450-500mah 3s
That's what I thought but I also thought someone mentioned 2S. The 370s will have to work for now in until HK gets 450s back in. Or I will get some elsewhere.
Also, is the 6.8x3.5 prop an off-size? I am not sure if my LHSs will carry Edge parts. I found some GWS 7x3.5 today.
Old Nov 17, 2012, 08:11 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
These are better than anything HK sells. Cheaper and they're in stock. Just don't buy them all up
http://www.hobbypartz.com/98p-25c-450-3s1p.html
Old Nov 17, 2012, 08:13 PM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I was thinking about getting those and just cutting .5 off the tip to make a 6.5x3.5. I might even try the 6x3x3 for slower high alpha flight. The only problem I can think of is the spinner.
-Brian
kalmon is online now Find More Posts by kalmon
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1230 Sep 27, 2016 03:15 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
