Old Oct 25, 2012, 10:48 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
whattya think this 460 3s nanotech?
http://www.hobbyking.com/hobbyking/s...Warehouse.html
flyrtim is offline Find More Posts by flyrtim
Old Oct 25, 2012, 11:27 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I don't care for the 25c Nano packs
these look good!
http://www.hobbyking.com/hobbyking/s...dProduct=25505
brushless55 is offline Find More Posts by brushless55
Old Oct 25, 2012, 11:29 PM
big ignore list
Joined Nov 2011
Originally Posted by Kevin Greene View Post
Ya want AS3X???...Put one of THESE in http://www.hobbyking.com/hobbyking/s...dProduct=25448 for $15...Remove the case for extra weight savings...I have two on order...
Kevin
I have two of those setting in my Hobby Room!
Old Oct 25, 2012, 11:36 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
I use these in other planes and love them
http://www.hobbypartz.com/98p-25c-450-3s1p.html
kuczy is offline Find More Posts by kuczy
Old Oct 26, 2012, 12:01 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Still didn't answer my question though....differential...mentions it in manual. Haven't used it before.
J
jabsten is offline Find More Posts by jabsten
Old Oct 26, 2012, 01:07 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I'm excited for this one. You think i could use this in the plane so i could use my A9? http://www.hobbyking.com/hobbyking/s...mpatible_.html
hone1er is offline Find More Posts by hone1er
Old Oct 26, 2012, 01:38 AM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
It probably just means dual aileron mode, differential doesnt belong in an aerobatic plane no matter the skill level.
airpower is offline Find More Posts by airpower
Old Oct 26, 2012, 03:44 AM
Tomdomification is offline
Find More Posts by Tomdomification
Tomdomification's Avatar
Joined Sep 2011
I've subbed too! I'm planning to buy the full-size F-27q for out at the club so this might be good for learning 3-d'ish maneuvers at my local sport oval. It's not too big, expensive or cheap (quality).
Can't wait to see the first reviews and videos!
Tom
P.s. It looks great in the video!
Tomdomification is offline Find More Posts by Tomdomification
Old Oct 26, 2012, 05:39 AM
AeroHeadTW is offline
Find More Posts by AeroHeadTW
AeroHeadTW's Avatar
United States, NJ, Berkeley Heights
Joined Nov 2009
Looks great--but I too would also love a slower, floatier replacement for the umx 300 so I can practice knife edges etc in my 25'x45' of "mostly" branch-free clear airspace front yard (it's small and surrounded with tall trees, so many times if it's too windy at the field it's passable for front yard flying+no commute). I could likely fly the new 540qq in my yard (lots of epp 32 yak and um p-51 flights; but it seems like other than being in high alpha most if the time, it might be really tight and bit speedy for some of the moves with long, graceful lines that the umx300 can do at a slower speed.
AeroHeadTW is offline Find More Posts by AeroHeadTW
Old Oct 26, 2012, 08:23 AM
jayjohnson is offline
Find More Posts by jayjohnson
Joined Sep 2012
what about the power plant on this bird, I wonder if it has power for vertical climbs?
jayjohnson is offline Find More Posts by jayjohnson
Old Oct 26, 2012, 08:29 AM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
I the video it sure looked plenty capable of whatever you choose to throw at it.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 26, 2012, 08:30 AM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Watch the video
Old Oct 26, 2012, 08:55 AM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
J
Differential is very important for aerobatic airplanes. Some need it, others don't. Differential simply means that you have less aileron travel in one direction than in the other. This helps make the model roll more axial. The model should roll around an imaginary string through the fuselage and out the spinner. If the model looks as though it rolls around the canopy, or rolls around the landing gear, its likely that you have a differential problem. Many times, it is that you have differential, and don't need it, but there are a few cases where you do need to add some differential. Edges generally need a little to make it roll the straightest. If you don't think this is a big deal to you, the airplane will fly fine without it. Just flies a bit better with it.
Hope this helps.
Seth Arnold
Horizon Hobby.
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 26, 2012, 08:58 AM
flyrtim is offline
Joined Aug 2011
how is this plane in wind?
this is speculation of course until Chuck tests it out
I am guessing this plane is good in wind of 15mph.
here's why:
considering this 3d plane has a symmertrical wing and the cutting though edge design, weighing 8.30z. I also consider that
my 41" 3dhs edge is good in wind 15-20mph
my v1 sbach good in wind 10mph
my 32" f4u corsair good in wind 10mph
my converted as3x sbach good in wind of 20mph+
If I find this stock plane is not so good in wind then I can
add the hobbyking as3x
Old Oct 26, 2012, 09:01 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
here's why:
How planes behave in the wind is partly a function of design but also related to your flying style. If you like to do a lot of low, slow, and floaty stuff then flying a plane of this size in winds greater than 8mph or so isn't going to be a lot of fun.
I just switch up my flying style a little based on what the wind is doing.
But having said that... most Edge planes do not like the wind very much. Edges don't track as well as something like an Extra. This shows up even more so when it's windy.
turnerm is offline Find More Posts by turnerm
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
