Old Feb 14, 2013, 10:34 PM
fstop is offline
Find More Posts by fstop
southeastern US
Joined Nov 2006
Good info...the suggested pack is 3s at only 450mah, right? IF i can get the cg right with the 500/2S pack it would still weigh slightly less than the 3S too--so less power needed and slightly more amps too? Plus if im not doing much acrobatics or full throttle thatd give me more run time wouldnt it? What size prop will i need to go with?
fstop is offline Find More Posts by fstop
Old Feb 14, 2013, 10:41 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I think what you say makes sense. I'd try a 8x4 to start with 2S? Just a guess I really don't know but that seems like a conservative start for 2S. I think you'd have enough power to fly "on the wing" even running a 7x3.5 on 2S. If you run a more stock sized 7x3.5 I'd just plan ahead, make sure you have enough space, don't get into tight situations.
BTW... you've flown an aileron ship, right??
erkq is offline Find More Posts by erkq
Old Feb 14, 2013, 10:44 PM
fstop is offline
southeastern US
Joined Nov 2006
I sure know what you mean about wanting to get out of trouble! 'Cept most of my planes dont have tons of throttle power or as much control surfaces i would imagine. How much rudder authority is there?
Only 370mAh pack, so its pretty forgiving with weight/CG?
Old Feb 14, 2013, 10:49 PM
erkq is offline
Joined Dec 2010
On the max rates I run at with "long arms" it's pretty huge. This thing can KE no problem at pretty slow speeds. I haven't really flown on anything but high rates so I really don't know. But I'd expect 78% throw to have pretty danged good authority.
The 370's go a little forward of the mid position. The forward edge of the battery lines up with the rear edge of the chrome battery-cover magnets. But I put my ESC below-deck so my plane is a little more nose-heavy than stock to start. The ESC is slightly more forward down there.
Old Feb 14, 2013, 10:53 PM
fstop is offline
southeastern US
Joined Nov 2006
Yea, have lots of aileron planes, but mostly older-era warbird varieties (ww1/2), no true modern acrobatic bird experience though!
Still using the original DX7 and out of memory model slots though ;(
Old Feb 16, 2013, 09:42 AM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Just did a couple checks on mine. Stock set up on 3s with the GWS7035 prop static numbers are:
8.7 Amps
99.7 Watts
This seems pretty standard to what others here are getting.
Next, 2s with GWS 8043 slow fly prop static numbers are:
8.39 Amps
63.1 Watts
Even with the 8043SF prop thrust is down quite a bit on 2s. Vertical would definitely be limited but it would fly no problems. I'm thinking a 9047SF would probably be fine on 2s but you'll have to be careful on take off and landing because it going to be really close to the ground.
For CG I fly mine on 3s with the battery nearly all the way back on calm days and move it about 1/2" from the very front when the wind is up. With the 2s 500 battery stuffed as far forward as it will go the CG is the same as my 3s set up moved back. Hope this helps.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Feb 16, 2013, 12:32 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
guys, I was out today and tested the "QQ setup file" first.
YESSSSS, this is what I'm looking for- the plane flies perfect in aerobatic and 3D flight level.
I'm really impressed- the Edge goes on line, flies like a big(ger) plane and I'm surprised how good she is !
Hope the Beast in this size will come soon
SLK Count is offline Find More Posts by SLK Count
Old Feb 16, 2013, 12:38 PM
erkq is offline
Joined Dec 2010
Indeed. I was out at the field doing flat spins, blenders, snap rolls, tumbles, etc. and a guy walked out during a flight. I landed before he arrived at the flight-line and when he saw the plane, he was amazed. He thought it was a lot bigger.
I hope a Beast comes out too!
Old Feb 16, 2013, 03:59 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
You could also use a GWS 9x5 3blade prop and just cut each blade down so that it becomes an 8x5x3. This should give you plenty of thrust and still have plenty of ground clearance. Cutting down those gws props is really easy too.
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 16, 2013, 05:31 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
-Brian
Seems like that would make the prop much less efficient.
They design them the be flown whole!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Feb 16, 2013, 06:26 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
probably a little less, but as long as you match the tip shape you'll have relatively good efficiency. I used to only tip .25" off the tip which doesn't change it much. This would be .5" which might be a little worse for efficiency.
math:
If you figure that the pitch is usually set at 75% of the blade that would be at 3.35" from the hub when the blade is 4.5" (9" prop) now each blade will be 4" so the set pitch is 85% so there will be an efficiency loss, but with this small scale and light weight I'd just fly it.
-Brian
Old Feb 16, 2013, 07:21 PM
fstop is offline
southeastern US
Joined Nov 2006
ForsheeMS, thats a great help! Thanks for the tests! I was afraid i might not be able to get a good cg even with the 2s battery pushed all the way up to the nose.
I'll get a couple of different prop choices you guys have suggested when i do get this plane--actually went to my LHS today, but they didnt have any in stock
Count, I agree on Beast too, had old version one and liked it--but i really like the size of this plane, not too small or big, hope they start coming out with a lot more in this size range!
Old Feb 16, 2013, 07:37 PM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
[QUOTE=ForsheeMS;24152567]Just did a couple checks on mine. Stock set up on 3s with the GWS7035 prop static numbers are:
8.7 Amps
99.7 Watts
8.39 Amps
63.1 Watts
QUOTE]
Looks like on 2S, current will be too high for the stock ESC if you prop up enough to be fun to fly.
mdv is offline Find More Posts by mdv
Old Feb 16, 2013, 08:15 PM
erkq is offline
Joined Dec 2010
Yes. He is aware of the performance difference. But it will still be "fun to fly" for him.
Old Feb 17, 2013, 03:49 PM
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
today, I was out with my new Visionaire. She feels like a "truck" at the sticks when you flow the Edge before
Yes, the Edge flies and seems like bigger planes- after bad QC issues and checked all things this plane is fine and really a shooter in this model size (without As3X).
One friend in our meadows asked me while I flow my Edge " Is this a new model and have this also As3X stabilization ?"
First YES and second NO !!!
continious saying "we need a Beast"
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1201 Jul 09, 2016 08:55 AM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
