Old Feb 10, 2013, 08:44 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by mdv View Post
ok so I finally got around to repairing this and now the rudder servo only turns half way. When I move the stick left, fine. When I move the stick right, nothing. Actually, when I move the stick right, all the other control surfaces move a bit.
Does this sound like a stripped servo?
I've already replaced the rudder servo once and don't look forward to doing it again as it was a bit of a pain getting the servo wire through the small hole inside the tail.
Sounds like you've got a mix in the transmitter moving the other control surfaces. Did you load up the 540QQ profile from HorizonHobby or tweek it some yourself?
I don't have an answer for the rudder servo.
erkq is offline Find More Posts by erkq
Old Feb 10, 2013, 08:47 PM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
This is with the untweaked DX8 HorizonHobby proifle.
mdv is offline Find More Posts by mdv
Old Feb 10, 2013, 08:51 PM
erkq is offline
Joined Dec 2010
Yeah... I think they have rudder mixes dialed in. So that's that mystery. But the servo only going half way... I just don't know.
Old Feb 10, 2013, 11:41 PM
Gmoney97lgt is offline
Find More Posts by Gmoney97lgt
United States, UT, Salt Lake City
Joined May 2011
Went and picked one of these beauties up from west valley hobbies about a week ago. Just got back into flying after a couple month hiatus so not flying this one til I get a little more stick time on the cc I picked up.
Got a tp 480 25c and 2 nanotech 460s ready and waiting though. Also just ordered up a couple 7035 props. Think I may get one of the tp 325s after I try the ones I have now. This 480 will be the first tp pack I've ever used, always had Hyperion and nanotechs. Excited to try the tp.
I'm about 120 pages into this thread and liking what I've been reading about this plane. Seems like its gonna be a fun one. About to set up my rates and expos so its all ready when I am. Lots of great info in here and I know what to lookout for before flying. Keep it up guys!
Gmoney97lgt is offline Find More Posts by Gmoney97lgt
Old Feb 11, 2013, 01:21 AM
ccpdx is offline
Find More Posts by ccpdx
United States, OR, Hillsboro
Joined Jun 2010
Originally Posted by ForsheeMS View Post
Having an extra set of hands to hold the plane while you work the servo out would be beneficial. The servo is either glued or taped to the fuse. If you can get under it with a couple picks it should wiggle out. Tape a piece of string to the servo plug at the receiver before you pull it out of the fuse. You'll need this to pull the new lead back through to the Rx. I've had a couple where the lead slid right out but some take a good tug to force the lead out. Some good two sided servo tape is really all you need to hold the new servo in. The hardest part for me was getting the servo lead unplugged from the Rx. It can be a real PITA!
Cool. Thanks for the tips! Now I just have to figure out where to get some servo gears....
Charles
ccpdx is offline Find More Posts by ccpdx
Old Feb 11, 2013, 01:27 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by Gmoney97lgt View Post
Went and picked one of these beauties up from west valley hobbies about a week ago.,, not flying this one til I get a little more stick time on the cc I picked up.!
Fantastic!
You'll find it to be both easy to fly in low or mid rates, but also barrel-of-monkeys fun, once you select high (3D) rates.
Just be sure on this one to give it not just a usual controls-check functional type pre-flight for your maiden, but also do a good firm physical 'waggle' test, pulling on the landing gear (sometimes not well-glued) on the prop (adapter and or mount sometimes loose), gently pulling outward on rudder (CA hinges sometimes assembled dry, so they pull out in flight), and be prepared to re-glue the rear batt hatch hinge if it pulls loose (the tight fit of the pins in the barrel make it so if you lift up even slightly on the front of the hatch lid, before it gets some natural wear and loosens up a bit, you are accidentally levering the mount away from it's foam mount, so that can come loose)....be sure the wings are well mounted and the screws fit well. If the screws won't fit, lots of prior ideas in the thread for fixing that -- in the end, I just added a dab of Uhu Poh as an easily removable glue-seal to my wing tenons, where they meet the fuse cut-away.
The design of this plane is phenomenal, but early units had some assembly issues, so taking a few minutes to do your own little personal QC prior to flight is cheap insurance!
tracknoob is offline Find More Posts by tracknoob
Old Feb 11, 2013, 03:22 PM
wgarman is online now
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
My Rudder, too
My rudder servo has failed, also. HH says they'll send me one when they come in. Currently on back order.
Anybody got a substitute?
wgarman is online now Find More Posts by wgarman
Last edited by wgarman; Feb 11, 2013 at 03:22 PM. Reason: forgot the word 'rudder'
Old Feb 11, 2013, 05:01 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
value hobby---power hd 33 digital 2.9oz $6.00,got one in my plane .,the same umx connector
dalecheek1 is offline Find More Posts by dalecheek1
Old Feb 11, 2013, 09:38 PM
wgarman's Avatar
Joined Feb 2010
Thanks!
Old Feb 12, 2013, 01:17 AM
ccpdx is offline
Joined Jun 2010
Hmmm, that 2.9g value hobby servo looks very similar to the 3.5g E-flite one. I wonder if they share anything under the hood. If so, I'd want it for the gears. The weight difference could be the cable, if they're counting it.
Charles
Old Feb 12, 2013, 07:17 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I got my replacement servos yesterday in the mail, my rudder servo went out and used a 3.7G minima servo with the UMX connector soldered on. Working good so far, I am selling a lot of my birds after buying some balsa ships, this one will probably stay as long as she can fly in my backyard.
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 12, 2013, 11:46 AM
texbird is offline
Find More Posts by texbird
texbird's Avatar
USA, TX, Austin
Joined Jan 2011
Originally Posted by tracknoob View Post
Fantastic!
AND a number of people are reporting failing servos?
SO lets see - you basically have to recheck and potentially reassemble the entire plane and replace the servos?
Maybe we need a new acronym for this plane:
the NQQBNF - Not Quite Quite Bind N Fly
texbird is offline Find More Posts by texbird
Old Feb 12, 2013, 11:52 AM
erkq is offline
Joined Dec 2010
Yup... but totally, completely worth it IMHO. It's a fffffantastic flier!
Old Feb 12, 2013, 01:11 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Hey, I juys' fixes um, I dasn't make um....
(It's true that's way too long a checklist for any plane, much less a Horizon offering. Sorry. But as stated, it is well worth it. Of course, if you want a 3D plane which has perfect quality, easy assembly, and workmanship every bit as good as a Graupner/Multiplex right out of the box, then buy the new Visionaire. It's astounding.)
Old Feb 12, 2013, 02:47 PM
tourist_603 is offline
Find More Posts by tourist_603
Joined Dec 2007
What is the size of the prop nut? Is it metric?
tourist_603 is offline Find More Posts by tourist_603
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1175 Oct 17, 2015 01:18 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 08:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 09:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 07:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 03:22 AM
