United States, CA, Riverside
Joined Oct 2011
Cheers! |
United States, NC, Garner
Joined Nov 2012
just got servos from VALUE HOBBY,POWER HD 33,,,same size as stock...umx connector is ths same ....speed .07 ..2.9 grams,ONLY $ 6.00,,STOCK servos are sooo fragile ,,i mean ONE little TOUCH and STOP in a PINE TREE...well really..........................
Joined Jan 2010
I just broke one of the servos trying to get the plane back in the house. Its a real shame since this is the only small plane I will make the drive to go fly. Its just big enough to use as the main plane of the day and not a supplement to fly. Of course its small enough to also be used as a supplement.
Anyone besides me using APC 7x4 Slow Flyer? I have about 70 flights on my QQ now and it has become my go to plane. Just so easy to set it in the back seat assembled and go fly. I have 6 batteries of different brands and all work well. The ones from Twisted Hobbies are the heaviest but seem to have the most punch. Had I known ahead of time how good this little bird was going to be I might not have bought my 4th 3DHS 48" Edge. Never thought I would say that but I do love this little green beast. Only thing I haven't mastered is KE Spin.
Joined Jan 2010
United States, CA, Sebastopol
Joined Dec 2010
BTW, the APC's I've used have required absolutely no balancing. What a relief! |
Yes all the APC's I have bought of late for various planes have been dead spot on in balance. A big improvement over ones I bought over 6 months ago. I use 14x7E, 12x6, 6x4 and now 7x4SF. I have 2 GWS 7035 for the QQ but don't like them as well as the 7x4SF, though they are much better than the stock prop.
Joined Dec 2010
I was thinking of an AS3X conversion for this plane, just for fun. I find I can fly it in wind that is uncomfortable to stand in and makes my eyes water, so it doesn't really need it... but...
1. The AS3X brick has proven itself capable of running on 3S directly, so the lack of availability of 7.4 volts for it is not a problem. Just wire it up in parallel with the ESC. 2. The ESC can be controlled through the x-port and transmitter mixing on channel 5. Just run the single control wire as the power is already supplied to both the ESC and brick. But there are a couple of questions that have to be answered: 1. Can the gain be turned down via programming the brick? With the control surface sizes, throws and flight speeds, I would think that would be necessary. 2. Can the stock servos handle AS3X duty? 3. Can the brick power 4 rotary servos chattering under AS3X control? Will its VR crap out running with 3S? What do you guys think? TP always has great analysis of this kind of thing. EDIT: Re-thinking the servo power problem: As long as you maintain a common ground, the power to the servos could be from the ESC's BEC and the signal from the brick. That should take care of the servo power problem, n'est-ce pas? |
Indianapolis, IN
Joined Oct 2010
I am almost certain the UM AS3X bricks, gain control is not a programmable option.
Everythign else, is up to others! Why not throw a standard micro full size reciever in there with the HK gyro do-hickey. Seems a little easy, you will have to make the servos have standard servo plugs but that isn't horrible. |
Joined Dec 2010
Joined Dec 2010
Guardian's 11 grams with wiring harness. So... strip it and make a harness (or modify the original) with the smaller servo ends and shorter wires and you could get it down to... 7g? 8g? Worth trying?
It could fit in the receiver compartment and the CG could be adjusted to compensate by moving the battery back. I have plenty of room for moving the battery back. |
Germany, NRW, Dusseldorf
Joined Apr 2008
Modding
I did some changes for more stability and response.
I decided to show these rather in a video, than just describing it. This Video is in german language, because I'm german, but I subtitled it hopefully clearly in english. These changes find some maybe unnecessary in particular, but at least the battery attachment is worth being reconsidered. I don't trust in velcro alone and the magnetic force. All of these changes are not to difficult to do and improve this fine little thing. I am talking of under 2 Gramms of added weight, but the whole thing is more stable and works better on the elevator.
Joined Dec 2010
I especially like the elevator mod. You have had it more aerodynamically ballanced! So, in addition to more elevator authority there should be less load on the servo. We can have all that elevator authority with less chance of blow-back.
Joined Apr 2008
Yep!
And it's not a big deal to do, really! The two struts that connect the rudder and the elevator have another advantage, because at least my elevator had a little clearance and it bends slightly as well, so the movement of the servo was not fully taken to the elevatorrudder, which effects the neutral point negative as well of course.. this now is tight. the servo only moves what it should. makes it more precise and predictable anyway. |
| Thread Tools | |
| New Product E-flite 300 A6M5 Zero BNF Basic | Afraidtoregister | Electric Warbirds | 619 | May 03, 2013 01:53 PM |
| Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS | peterswolf | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Sep 14, 2012 07:43 PM |
| For Sale E-Flite MSR X BNF Basic edition | daign | Aircraft - Electric - Helis (FS/W) | 0 | Jun 01, 2012 08:59 PM |
| Sold Edge 540 3D ARF by E-Flite | freirem | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 28, 2012 06:38 PM |
| Discussion A6M5 Zero 300 BNF Basic by E-flite | BlazingStar | Micro RTF | 2 | Feb 03, 2012 02:22 AM |
