Old Dec 20, 2012, 07:41 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Ducati Mechanic View Post
Man I love parallel charging! What used to take all night, now only takes a few minutes! If you guys haven't made the jump to the para- board it's the only way to go..
Yep... a really nice step ahead for the hobby for sure.
erkq is offline Find More Posts by erkq
Old Dec 20, 2012, 08:05 PM
N_O_V8_R is offline
Find More Posts by N_O_V8_R
USA, NE, Waverly
Joined Feb 2011
Tim,
I have the 3010 model with a1000 watt PS and have been parallel charging for over a year.
I even do my 6S batteries for my 60" EF planes. Nice to put it at 30A and have all three batteries done in 18 minutes. The only way to go!!!!!
I charge (6) 460mah at a time also, at 8.3 amps they are done in 18-20 minutes (both examples = 3C charge rate) = that is some serious flying. I can charge at 5C if I need them in 10 minutes.
For all you out there without a para board, many places offer a 3 into-one cable. Or make your own cheaply. Most 10A (50 watt) chargers can easily handle (3) 460 mah batteries at a time at approx 3C. 4.2 x 3 x 1.38 x 3 = 52 watts, or charged at 4.1A
Just remember, all batteries must be the same cell count (Ex.: 3S). You set the voltage the same and add the currents.
Example: You have (5) 460mah lipo batteries that you want to charge at 3C rating (assuming that your batteries will handle that high of a charge rate). The calculations are as follows:
Set charger for 3S lipo (11.1 volt)
460mah/1000 = .46 amps
At 3C (.46 x 3) = 1.38 amps charge rate each.
1.38 x 5 batteries = 6.9 amps is the charge rate you will set on the charger.
Simplified = (.46 x 3 x 5)
To do (6) batteries at 2C rate (approx. 1/2 hour charge time) = .46 x 2 x 6 = 5.5amps.
When I do (3) of my 6S 3300mah packs at 3C, it goes like this:
3.3A x 3C x 3 batteries = 29.7 amps (4.2v x 6cells = 25.2V x 29.7A = 749 watts).
Another example: I'm flying my 12S 700 size electric heli, using two 6S packs at 5000mah each. What is the maximum "C" Rate I could charge these at and stay within the 30A, 1000watt rating of my charger?
Watts = Volts x Amps. Maximum charged voltage of a 6S pack is 25.2 volts (4.2 x 6).
1000w/25.2 = 39.68 amps, that is over the chargers rating of 30 amps.
30A x 25.2V = 756 watts, well within the wattage rating
30A/2 batteries = 15 amps each. 5000mah/1000 = 5A. 15A/5A = 3C charge rate.
You be ready to fly in approx. 20 minutes.
Have fun, and be safe,
Ric
N_O_V8_R is offline Find More Posts by N_O_V8_R
Old Dec 20, 2012, 08:22 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by Dannyboy85 View Post
Just curious I downloaded the 540qq file for my DX8 and the travel for elev and rudder are already at 150% who is running 150?
I'm on 150 for both.
turnerm is offline Find More Posts by turnerm
Old Dec 20, 2012, 08:33 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
the dx6i only goes to 125%.......boo hoo...wa wa
dalecheek1 is offline Find More Posts by dalecheek1
Old Dec 20, 2012, 08:37 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
You better ask Santa for a DX8 then.
Old Dec 20, 2012, 08:41 PM
N_O_V8_R is offline
USA, NE, Waverly
Joined Feb 2011
But you can also adj the Dual rate limits to 125%, can't you?
That's over 150% total
Travel Adj 125% x DR 125% = 156%
Old Dec 20, 2012, 08:50 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Originally Posted by turnerm View Post
Dude - that's some beautiful land you've got to fly on. I'm jealous!!
I swear, the next house I build/buy is going to be on some land just like that and I can walk out in my backyard butt-ass naked and fly if I want!! Good thing for you guys I keep the camera on my head I suppose...
Thanks me and dads lucky to have such a spot to fly. As you see its wide open ,free, .8th a mile from my current home n only 7 mile from, dads. He keeps grass cut we can fly pretty much anytime we want there is 4 ama tables a picnic table under a nice sheld
epoweredrc is offline Find More Posts by epoweredrc
Old Dec 20, 2012, 08:52 PM
Joined Nov 2012
santas HELPER put me on to a panasonic pocket cam and hat,,,for xmas,,,then i can post vids of my adventures with flying my AIR ..O...BATIC PLANES.... I got sum MAD SKILLS....my THUMS will back up my MOUTH,,,MY BIG MOUTH.........................
Old Dec 20, 2012, 08:56 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Nov8r,
Yeah man that's what affords me the ability to fly ten cell with my 78 inch Extra. I can slam four 4400mah 5s packs, fully charged, at the field, in less than an hour.. Same thing with four 6s 3600's that I fly in the 64" MXS..
I'm not even pushing the C rating doing them in that amount of time. I like to keep the equipment cool. I usually charge between two, and four C..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Joined Nov 2012
did not think of that ...will give it a try ,thanks dr only goes to 100% dx6
i
Old Dec 20, 2012, 09:17 PM
N_O_V8_R is offline
USA, NE, Waverly
Joined Feb 2011
It'll work.
Just set your Travel Adj. to 125%
Than keep adding DR till the servo arm stops traveling - no need to go further.
You should end up with approx. 120% DR, which will give you 150%.
FYI - 100% Total = +/- 30° throw. 150% = +/- 45° throw at the servo.
Most servos have max. endpoints set at +/-45°.
One other note, most you might already know, you ALWAYS want to use up all the servo throw that is available.
That means use 150% if you can. Why?, resolution and mechanical advantage.
If 150% is too much, move links outward on horns, or inward on servo arms, until you get the desire control surface travel.
Everyone keeps talking about getting longer servo arms.
Isn't there a hole farther down on the Ele & Rud horn? (Drill one in there if there is room)
(mine hasn't arrived yet, so I do not know if the extra hole is available).
Torque is torque and MA is MA, doesn't matter how you get there, unless you run into clearance/interference problems. (Ex.: a 2" servo arm hooked to a 2" control horn is still 1:1....doesn't matter if it is 1" connected to a 1", still 1:1 MA
Old Dec 20, 2012, 09:22 PM
N_O_V8_R is offline
USA, NE, Waverly
Joined Feb 2011
i
you are probably correct on the Dx6, but I thought my Dx6i had 125%
Dx7's have 150% Tr-Adj and 125% DR
Haven't had a servo I couldn't MAX out yet with my Dx7
but I really like the DX8 and my Dx18QQ.
Old Dec 20, 2012, 09:42 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
Man you young pups really know how to hurt an old man. All this talk about 150% throws. I run 60-70% and the guys at our club are amazed at the response and roll rates this thing has. I couldn't begin to think what 150% would do. I suppose it has to do with 3d stuff, and we don't have any 3d flyers at our club, so nobody knows any better I suppose. I begin to wonder if anybody else just flies regular aerobatics with this thing or if everybody that has it but me is a 3d flyer.
bobly is offline Find More Posts by bobly
Old Dec 20, 2012, 09:49 PM
Joined Nov 2012
tr adj at 125% dr will go down from 100 but not go past ...thanks anyway.....get pretty tight back and front loops with 125....150 % and plane would bite it s own tail....................
Old Dec 20, 2012, 09:53 PM
Joined Nov 2012
put MOOOORE throw s on your plane......then U will B THE OLD TOP GUN at your club.......................
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
