Old Dec 05, 2012, 12:23 PM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
Hmm, my new wings arrived just now, for my new but not correctly assembled product.....
I guess I did not realize I would need to swap servos, linkages and horns in order to get this new product flying... I still love HH customer service, however I had not thought about having to do this already, nor was it mentioned, nor any instructions how to do this. I am guessing the servos are glued in?
I am not sure why the plane itself is all packaged into foam and a box, but yet these new wings are in a plastic bag... in a bottom of a cardboard box... with packing paper stuffed on top of them. They appear OK, but wow am surprised, as the box came smashed, by none other than UPS.
PropsnWings is offline Find More Posts by PropsnWings
Old Dec 05, 2012, 12:29 PM
ScottGridley is offline
Find More Posts by ScottGridley
United States, MA, Rutland
Joined Oct 2011
Guys, what's everyone using as a reference point for neutral on the elevator? Mine is tough to eyeball because of the bevel and a slight offset to the stabilizer. Nice they molded ticks into the fuselage for the ailerons, but nothing at the tail end...
sg
ScottGridley is offline Find More Posts by ScottGridley
Old Dec 05, 2012, 12:32 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
Originally Posted by kuczy View Post
So.... The HURC motor isn't the same size as the Hextronic and its not a drop in fit.
I take it you got yours today? Not what I was hoping to hear. Anybody have any links to the hextronic motor that fits?
slo-fly is offline Find More Posts by slo-fly
Old Dec 05, 2012, 12:33 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
What?!?! You'll be able to make it work right?
FlyWW1 is offline Find More Posts by FlyWW1
Joined Jun 2011
sg
I dont think those "ticks" were molded there... they were made from the aileron contacting the fuse when you installed the wings ?
Old Dec 05, 2012, 12:35 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I'm pretty sure they were molded there. They're on my plane as well(sounds like they must be on yours as well) and were there before i installed the wings. I really don't mind any of the cosmetic defects that the plane might have. My tail wheel did fall off and that bothers me but other than that i got this thing to bash around in the yard or at lunch not for the looks. I understand some people want a perfect product but this thing flies great, i'm very pleased with the performance(hopefully the motor holds up)
It's foam, just have fun with it. When it's zipping by you're not looking at the nail marks or whatever may bother you anyway.
hone1er is offline Find More Posts by hone1er
Old Dec 05, 2012, 12:38 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Originally Posted by hone1er View Post
Sucks that your motor burned up. Mine makes a weird noise when i do a KE pass, i don't think my motor will last long. I was also thinking an 8'' prop would be pretty sweet on this thing. Hopefully you can make it work out with the bigger prop.
That noise might actually be normal for this motor surprisingly. My zero that has a 300 motor has done that exact thing your describing from day one. And I now have many many flights on it still going strong. :-)
Airman74 is offline Find More Posts by Airman74
Old Dec 05, 2012, 12:41 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
I'll get in touch with Terry from www.smallpartscnc.com and see if he can fab a billet aluminum motor mount that fits the park 300 and 340 and possibly other motors.
Old Dec 05, 2012, 12:50 PM
Joined Jun 2011
I am quite pleased with mine as well..
I only mentioned the tick marks, as only one side of mine has it, the side I had the trouble of getting the wing to lineup.
Old Dec 05, 2012, 12:58 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Ahem:
tracknoob is offline Find More Posts by tracknoob
Old Dec 05, 2012, 01:01 PM
Joined Jun 2011
Originally Posted by tracknoob View Post
Ahem:
Gotchya.. I was referring to the mark my right wing aileron made when having trouble installing... I was wrongly assuming he was speaking of the same mark.
Since when do we need "tick" marks to center a control surface? Its a nice feature, but I think we would be better off, finding the center ourselves, as with my elevator, its not hinged on center, it sits slight above center, so I just use a straight edge on the side to determine if its centered.
Same can be done on the wings.. they are two "halves" glued together, so you have a "center line" to guide you.
Old Dec 05, 2012, 01:41 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Absolutely.... I'll be able to make it work. It's just not a drop in to the 280 mount.
kuczy is offline Find More Posts by kuczy
Old Dec 05, 2012, 01:42 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
..looks fine with the wooden Zinger prop but I assume this prop will be too heavy in weight and blade size- did you also changed the ESC ?
as asked in the past and not have feedback up to now-once again- do you have motor axle play while you pull the spinner cone ? Maybe these few milimeters would be responsible for the mystic sound during flight (grinding sound). After remove that axle play my sound is quieter and constant also in hard aerobatic maneuvers.
Pls try it !
SLK Count is offline Find More Posts by SLK Count
Old Dec 05, 2012, 01:50 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
On some planes, sometimes the sound you hear in violent maneuvers is the prop cavitating -- just caught my 1000mm crunchy Sbach342 doing that today on video.
Not sure what sounds are at work here on the Green Machine, haven't caught my motor sounding odd yet.
Old Dec 05, 2012, 01:54 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
I talked to Terry, he is going to fab a billet mount. I'm just gathering info at the moment to make something that will fit a variety of motors.
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
