Old Dec 03, 2012, 08:45 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
What is the negative of having throttle trim all the way down all the time? Not enough power?
grovey is offline Find More Posts by grovey
Old Dec 03, 2012, 08:46 PM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
Originally Posted by Dave Eichstedt View Post
Not sure why you're saying this. Page 4 of the manual online shows shorting the pins first (step 4) and plug in the flight battery second (step 7).
http://www.horizonhobby.com/pdf/EFL6250-Manual_EN.pdf
Well, my manual has it backwards, as the poster had as well. Took me a time or two before I realized that was backwards from the way it is supposed to be.
Grabbing manual.. posting pic in sec
Step 7, says to hook battery BEFORE shorting the pins. This is the incorrect procedure. The pins must be shorted before powering the RX. At least with any Spektrum Rx I have dealt with, and this one as well, needed the pins shorted first, before powering the Rx
PropsnWings is offline Find More Posts by PropsnWings
Old Dec 03, 2012, 08:47 PM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Originally Posted by grovey View Post
Thank you, this did it. Lol @ the manual, seriously.
So now that the trim is all the way down, do I have to leave it there ALL the time to arm the ESC?
Here's a photo of the trim settings on my DX7s. With this setting a slight bump of the throttle stick turns the motor on.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Dec 03, 2012, 08:48 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
5
A
But step 7 says plug in battery then says short out the bind pins.
7. Connect the fl ight battery to the aircraft. Short the pins until
the receiver LED begins to fl ash rapidly (typically after 5
seconds).
And back in step 5 says put transmitter in bind mode (which I took to mean turn it on with bind button held in)
5. Put your transmitter into bind mode. Refer to your transmitter’s
manual for binding button or switch instructions.
I found that I had to short pins first, plug in plane battery, then put transmitter in bind mode.
It just seemed confusing to me at first anyway.
bobly is offline Find More Posts by bobly
Old Dec 03, 2012, 08:56 PM
bobly is offline
Joined Sep 2010
Originally Posted by jabsten View Post
How the heck did you guys get the bolt loose to take off prop? Man I can't get it off lol
J
righty tighty, lefty loosey - small crescent wrench or pliers (or box end wrench or socket if you want to do it right) - rotate nut counterclockwise while holding prop. Mine was no problem to remove.
Old Dec 03, 2012, 08:57 PM
Joined Jun 2011
Originally Posted by bobly View Post
5
A
seconds).
Agreed, had the "boss" my wife read it, and she too says that those steps are written confusing, as once you get to step 7 and read it, it appears the manual wants the battery hooked before the pins are shorted. So I can see how some can get confused on this.
I now see though, if you ignore the second sentence in step 7 it would be correct.. still needs rewritten, to be less confusing.
Old Dec 03, 2012, 08:58 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
Why no bind plug? We have to resort to paper clips and such, it's hard to hold the trainer switch, turn on TX, and hold something to short the pins all at the same time.
slo-fly is offline Find More Posts by slo-fly
Old Dec 03, 2012, 09:01 PM
Joined Jun 2011
Originally Posted by slo-fly View Post
Why no bind plug? We have to resort to paper clips and such, it's hard to hold the trainer switch, turn on TX, and hold something to short the pins all at the same time?
A paperclip seems to "jamb" in between the pins without bending them, and hemostats seem to work too.
agreed a jumper of some sort would have been great.
Old Dec 03, 2012, 09:05 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
reverse grip tweezers. don't even need to take the hatch off.
kuczy is offline Find More Posts by kuczy
Old Dec 03, 2012, 09:07 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Anyone, before this gets lost in all the posts?
Also yes the manual is correct, just gotta read a bit more carefully. All it is saying in step 7 is the keep shorting it until you have bound successfully.
Old Dec 03, 2012, 09:08 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by RCBABBEL View Post
bbly,
Picked my youngest up from school.
Ran a couple of errands for my wife.
Noticed the lack of wind. aka: Dead Calm!
Two stop lights and one mile later, my EQQ was in the air.
She really has some moves with 150% servo throws.
Jel,
I'm flying 10 min on the Hyp 550s and still not replacing 80%.
The Hyp 320s are giving me 5~6 min super light flights.
Perfect batt for touch-n-go work from a small field.
Will be test flying lightened T.P.s next.
Do you think there will be a demand for lightened T.P. (3S) 325 65C w/JST-XH taps?
rc
RC so far it appears that the TP 325 65C is one of the best lightweight batteries. I'd say go for it.
Read all the steps again. in step 4 they have you short the pins. no where between 4 and 7 do they tell to remove the short! What step 7 says is to plug the battery in, Pins still shorted from step 4, and keep the pins shorted until the led flashes rapidly (about 5 seconds).
-Brian
kalmon is offline Find More Posts by kalmon
Old Dec 03, 2012, 09:13 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
...throttle trim all the way down.....
I keep my throttle trim 5 clicks below neutral on all my planes--as safety measure--so if I bump throttle--or if I mean to put it all the way down--but don't--the throttle remains off.
some planes (or ESC to be more precise) need the throttle calibrated so that throttle has full range--and starts before 1/2 thottle. This plane did not.
If throttle trim is ALL way down--I suppose you might not ever reach WOT.
flyrtim is offline Find More Posts by flyrtim
Old Dec 03, 2012, 09:15 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
I think the edge should come with a bind plug, it should also have a tag on the bind plug saying "throttle trim needs to be in lowest position to arm esc".
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
So should I keep bumping it up then until it arms?
Quite annoying... Unless there aren't ill effects of having It all the way down.
Old Dec 03, 2012, 09:19 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
J
I used a mini vise grip to get mine off
Airman74 is offline Find More Posts by Airman74
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
