Old Dec 02, 2012, 01:57 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
Picked up mine yesterday. With an expensive e-flite batt too, to see how it compares to the Nanotechs. Too bad the weather is poo over here.
I hated that silly-looking toy pilot so I delicately detached the canopy from the fuselage (not very difficult to do since the glue has a light bond). I didn't even use paint for the canopy. Just a big, fat, black Sharpie marker on the inside of the canopy. Works like a charm!
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Dec 02, 2012, 01:58 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
2S lipo pack
one guy from our German bulletin board use 2S 450mAh packs with 8x4 prop and he is impressed about it !
SLK Count is offline Find More Posts by SLK Count
Old Dec 02, 2012, 02:00 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
I did that today. It's not impressive unless all you want to do is fly slow.
FlyWW1 is offline Find More Posts by FlyWW1
Old Dec 02, 2012, 02:01 PM
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
I hated that silly-looking toy pilot so I delicately detached the canopy from the fuselage (not very difficult to do since the glue has a light bond). I didn't even use paint for the canopy. Just a big, fat, black Sharpie marker. Works like a charm!
1A, you did a good job and removed "Matt"- I did the same ! In this case it's fine that HH used such a poor glue, isn't it
Old Dec 02, 2012, 02:04 PM
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
that is the forecast which I assumed - for indoors it would be fine...
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Originally Posted by kuczy View Post
I guess the 300 is not working with this mount after I looked at the pic.
If you can get that prop adapter off it may work. If not we could just use wood or make new holes for the 300 X mount. I just don't want to spend the money on it until someone with a 300 has made it work and says it flies great. However if these 280 motors keep crapping out we will all be experimenting anyway
Old Dec 02, 2012, 02:06 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Yes it would be an ideal set up for indoor flying. I didn't even think of that. I even tried it on 3s and it wasn't any better than the 7x3.5.
Old Dec 02, 2012, 02:09 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by turboparker View Post
As Meatloaf so eloquently put it - 'There ain't no Coupe de Ville hiding at the bottom of a Cracker Jack box'.
Joel
LOL
that's awesome!!
brushless55 is offline Find More Posts by brushless55
Old Dec 02, 2012, 02:10 PM
big ignore list
Joined Nov 2011
[U]I tried a GWS 8x4 on all stock setup this morning. Didn't fry anything[/U] However it didn't really improve performance either. Had a little more thrust but less speed. To much prop for this motor so it can't reach maximum KV. Great a flying slow though. It might work on the Park 300 or 340 but I'm not sure it would be worth the trouble and money in the end.
Good to hear man..
I know there were a few who thought the stock goods could not hold up, but I was keeping it real
Old Dec 02, 2012, 02:13 PM
big ignore list
Joined Nov 2011
Originally Posted by FunkeyMonk View Post
FYI - the 540qq is listed as "BACKORDERED" on the Horizon Hobby website. Maybe they're sold out a first run of planes, and will make some adjustments for a second run.
Maybe.......?
I don't think they were expecting this sexiness to be so popular
Old Dec 02, 2012, 02:15 PM
big ignore list
Joined Nov 2011
Originally Posted by turnerm View Post
I personally think that the stock motor is most of the problem. It seems cheap compared to the Park 300 and the Park 300 seems cheap compared to something better like a Motrofly. I've got maybe 15-20 flights on mine and my stock motor is binding? Just doesn't seem right.
is it hard to turn by hand?
Old Dec 02, 2012, 02:24 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Originally Posted by brushless55 View Post
Good to hear man..
Well I didn't say it would hold up for long. Like I said when I went to 3s it struggled to get to full speed. These motors are even holding up with the stock prop or the 7x3.5. I just think they are JUNK! Worse than something from HobbyKing. I think when my motor goes and it will. I'm going with the Motrolfly motor for less money and better quality.
Old Dec 02, 2012, 02:27 PM
big ignore list
Joined Nov 2011
were you able to run a temp gun on the esc and motor?
sucks about the motor issues I keep reading...
Old Dec 02, 2012, 02:32 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Temps really weren't bad at all. It was just to much prop for the motor to get full KV. So it's going backwards instead improving flight. Check this gem out! We could swing a 7x6 SF with the stock ESC. This would be an awesome setup! Speed and thrust with maximum efficiency. I think I'm going to order one.
http://www.subsonicplanes.com/upload...1350__page.pdf
Old Dec 02, 2012, 02:34 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Sad to hear that and pls inform us what HH will say to the problem ! Could you pull your motor shaft few milimeters forwards ? I had this at my motor and removed it- now the motor doesn't grind or makes untypical sound.
How many flights did you have with your Edge ?
Only about 15-20 flights probably...
turnerm is offline Find More Posts by turnerm
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1175 Oct 17, 2015 01:18 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 08:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 09:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 07:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 03:22 AM
