This, and the loose latch hardware, and the rattlely wheels though are not collectively enough to even make a tiny dent in the otherwise unadulterated pleasure of that first outing with it. Looking forward to wringing it out even further tomorrow. EDIT TO ADD: Woot -- over half way through reading the thread now! Lotsa good stuff in there! |
Scottsdale Arizona
Joined Dec 2009
Ok, this is very important info, write it down. The eflm1920 is a 2mm collet that will fit master airscrew props without hub adapters, and apc props. It weighs 2.6g and is 3.99. It also has a little metal nose cone for those that don't want to use the stock spinner. The eflm1935 is a set screw adapter that is very similar to stock, fits the gws and stock props, only has one set screw and weighs 1.3g.
USA, CA, Chico
Joined Feb 2011
USA, CA, Chico
Joined Feb 2011
Plus,,,,, someone's here gota try the 300 motor on 8x4 right??? ;-) |
USA, CA, Chico
Joined Feb 2011
It's too bad cause this plane is just sooooooo AWSOME otherwise |
This thing can take a licking for sure. HH sent me a new set of wings and they came with the decals on them! If that's the case for all the parts, I will have no issues beating it up and then replacing parts as needed. The only problem I see is HH keeping good stock.
Joined Mar 2012
This plane flies incredibly, BUT only when I actually get it to fly.... Update: Motor coils are now visibly coming apart. not good.
So I Replaced stock prop with orange gws 7x3.5 and went to go fly. On takeoff prop exploded... Spinner cracked.... Still not sure why Second try, Put another GWS prop on, accidentally sanded both sides, learned the hard way... ![]() Third try, put another GWS prop on. Hub in spinner backplate detached it self leadimg to insane vibrations... Fourth try. Glued backplate hub back in. Put another GWS prop on. Was unable to tighten the nut down as I can't find an allen wrench to take off the prop adapter. Ripped off the cowl and tightened nut down properly. Flew fine, but about as loud as my CZ Yak. Well I have mixed feelings, as you can tell :-) |
| Thread Tools | |
| New Product E-flite 300 A6M5 Zero BNF Basic | Afraidtoregister | Electric Warbirds | 619 | May 03, 2013 01:53 PM |
| Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS | peterswolf | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Sep 14, 2012 07:43 PM |
| For Sale E-Flite MSR X BNF Basic edition | daign | Aircraft - Electric - Helis (FS/W) | 0 | Jun 01, 2012 08:59 PM |
| Sold Edge 540 3D ARF by E-Flite | freirem | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 28, 2012 06:38 PM |
| Discussion A6M5 Zero 300 BNF Basic by E-flite | BlazingStar | Micro RTF | 2 | Feb 03, 2012 02:22 AM |
