Old Oct 25, 2012, 02:04 AM
savage0102 is offline
Find More Posts by savage0102
Joined Jun 2012
Question
Does a left turn fin makes the left turn better?
Hi!
Dragon Shark 650 ep boat has a right hand side turn pin, and turns very well to the right. But the left turn is not good, as you can see in this video.
DRAGON SHARK 650EP rc boat (1 min 22 sec)
If installing another turn fin on the left hand side, will it improve the left turn or not?
Your input will be appreciated! Thank you!
savage0102 is offline Find More Posts by savage0102
Old Oct 25, 2012, 02:27 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Only a bit... the prop torque will always make the right turn tighter.
CornelP is offline Find More Posts by CornelP
Old Oct 25, 2012, 07:46 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Try to get some of the bouncing out and it may help the cornering ,and yes a turn fin on the left of a mono hull will help it turn left most of the time .
highflyerbill is offline Find More Posts by highflyerbill
Old Oct 25, 2012, 12:06 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
It looks to me as though the centre of gravity may be too far back (needs to be 30-35% from transom, using velcro is a good idea as this makes it easily adjustable, once you find the sweet spot mark it with a marker).
Plus make sure your centre of gravity left too right is pretty well balanced or if it needs to be slightly off balance for some reason make sure the left side is the heavier as this counter act the torque twist from the counter clockwise rotating prop.
On a final note, try dropping the turn fin to it's lowest point if it isn't already as your hull seems very light on the water (possibly incorrect COG) and the chop is lifting the transom during cornering?
rotorkilla is offline Find More Posts by rotorkilla
Old Oct 25, 2012, 11:15 PM
flyboy4422 is offline
Find More Posts by flyboy4422
United States, OR, Hillsboro
Joined Jun 2010
It needs trim tabs to help with the bounce,COG will make the most of his problem eliminated.Fine tuning this boat takes time,it should be a nose down attitude with rooster flying smoothly.Should be around 1/3rd -1/2 back for COG.
flyboy4422 is offline Find More Posts by flyboy4422
Old Oct 26, 2012, 08:18 AM
Joined Nov 2009
Rule of thumb is 30% of the length of the hull measured from the transom . Then you can adjust for best cg from there . You may also try to move the strut up as the boat looks like it's running real loose .
Old Oct 26, 2012, 05:08 PM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Savage,
That boat needs some work on the general set-up; it's a stepped hull and should run much smoother without 'bunny tendancies' when getting up to speed
Judging by the acceleration (or lack there-of) the prop is too small, damaged, or flexing under load, try a metal one the same size and notice the difference in performance.
Keep in mind it's a single prop boat which will always turn better to the right, left hand turns at speed should be wider, after all, all races have only right hand turns...(with the exeption of the M-course).
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Oct 26, 2012, 07:57 PM
Joined Jun 2012
Thank you very much everyone for your input! I greatly appreciate!
Savage
Discussion Problems with tail/gyro - hesitates/stuggle making left turn stevo75 Electric Heli Talk 12 Aug 20, 2012 09:39 PM
Poll does fpv make you a better pilot? winstongotte FPV Talk 4 Mar 23, 2012 12:22 PM
Wanted Aqua Rio 51 left turn fin Ronbo Boats (FS/W) 0 Oct 09, 2010 02:05 PM
Does the GY240/401 gyro work better in the rear, or does it make no difference? EddieNewYork Micro Helis 22 Apr 26, 2005 03:35 PM
Why does my plane turn left? S55 Electric Plane Talk 10 Nov 17, 2004 10:38 AM
