Old Oct 24, 2012, 10:43 PM
Sunfire is offline
Find More Posts by Sunfire
Sunfire's Avatar
Joined Jul 2007
opinions needed: designing a high speed, high aspect wing
dear friends, hello there
I normally lurk in the glider section but I do have some wing experience.
my wing experience include Ritewing Mini Demon, Lightning 36 and TL50 (as you can see, I'm a fan of CK). I also fly Mugies.
Anyway I have some foam core and sheet balsa loose and I'll be sketching out a high speed wing with high aspect ratio.
It'll have a fuse
I'll probably put it at 25 degree sweepback and 90 cm span, no taper. you think that's ok?
but what I'll like to hear is your recommendations on the airfoil..... and whether I neeed to blend the airfoil nearer the tips to a more symetrical foil
Any thoughts?
I'll like to put a 2040 size 3900 kv motor into it though
cheers
Sunfire is offline Find More Posts by Sunfire
Old Oct 25, 2012, 09:57 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
If you don't find the info you need,try a posting ing the Nurfluegel forum.
Regards Stuart.
Stuart A is offline Find More Posts by Stuart A
Old Oct 28, 2012, 11:39 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Take a look at this post. Your idea sounds similar.
Piece is online now Find More Posts by Piece
Discussion High aspect ratio VS low aspect ratio wings ?? khaled_abobakr Ornithopters 0 Mar 12, 2010 05:17 PM
Discussion A mixed Low and High Aspect ratio flying wing glider design for thermalling GreenAce92 Thermal 2 Mar 26, 2009 04:42 PM
Discussion High Speed Low Aspect Ratio Wings mattuk Modeling Science 124 Aug 14, 2008 12:49 AM
Help! High speed hull design help needed. AlecG Dock Talk 6 Mar 09, 2006 09:12 AM
ArtHobby High Aspect - Opinions? sritzi Thermal 14 Apr 21, 2004 02:43 PM
