Old Feb 10, 2013, 07:11 AM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Hi guys, What do you do when the stack of stator plates expand on one side?
I mean is what do you use to glue them back in shape, I tried to rub CA on and clamp in a vise but no luck. Is it toast?
Tom
ApexAero is offline Find More Posts by ApexAero
Old Feb 10, 2013, 07:16 AM
Life begins at transition
Australia, WA, Perth
Joined May 2007
Thin epoxy, line the vice in saran wrap, and leave for 24hrs.
disclaimer: This only has a 50% success rate for me so far! Out of the two I damaged trying to get them off a stator holder, I scraped one altogether.
Odysis is online now Find More Posts by Odysis
Old Feb 10, 2013, 11:28 AM
Ron H's Avatar
Bishopville S.C.
Joined May 2003
I'm surprised that the CA didn't work. Perhaps it was the rubbing? I Use thin CA on one side of one tooth at a time and over apply it to make sure it wicks between the plates, then immediately clamp it with that tooth level so the excess CA puddles on it. It dries slowly using this method so a kicker would help save time. !00% success rate so far for me, but I've only done a few so that doesn't mean much.
Ron H is online now Find More Posts by Ron H
Old Feb 10, 2013, 12:14 PM
Inspiration
modisc's Avatar
中国, 江西省, 南昌
Joined Aug 2011
Tom
You need to make sure these laminations can be put back in shape first, by pressing and adjusting without any glue applied yet. Then use some instant-dry glue to fix these laminatons, apply the glue, then use clamps to hold the laminations. I actually assembled a stator successfully, from a few blocks of laminations.
modisc is offline Find More Posts by modisc
Old Feb 14, 2013, 07:06 AM
Sidewinder
zeroback's Avatar
United States, FL, Pompano Beach
Joined Oct 2011
I clamp damaged stators flat and bake them in the oven.
zeroback is offline Find More Posts by zeroback
Latest blog entry: Edge Walker
Old Feb 15, 2013, 07:13 AM
ApexAero's Avatar
Joined Aug 2008
That rings a bell, I used long screws against the stator lams with coins as washers then heated it in the counter top oven. I suppose the procedure would reverse the warpage? I'll C'clamp it between two steel plates and bake it. Will report back !
Old Apr 05, 2013, 03:58 PM
ApexAero's Avatar
Joined Aug 2008
Here you go guys, thanks to all that advised me!
Tom J.
Old Apr 13, 2013, 09:18 PM
ApexAero's Avatar
Joined Aug 2008
Here you go guys! 10.8 HP!
Old Apr 14, 2013, 06:01 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Looking good!
What is the prop on that? And do you have final weight on the rewound motor? I always consider the Watts per gram to be the real measure of quality.
And that was about 15 seconds? How was the temp at the end of the run?
Jack
jackerbes is online now Find More Posts by jackerbes
Old Apr 14, 2013, 02:45 PM
ApexAero's Avatar
Joined Aug 2008
Hi Jack, it is a 10 x 17 from Marcus Koch in Germany. The motor weighs 1lb-1.5oz/496.11gr
equals 16 watts per gram?
Old Apr 14, 2013, 04:54 PM
Jack
USA, ME, Ellsworth
Joined May 2008
As you probably know, we consider average quality motor to be able to handle a continuous input power of 3 Watts per gram. So your motor is doing much better than that.
As you test it and use it more and check for heat you'll probably find that good for 7-8 Watts per gram or so continuous and that is very good.
You''re going to use it in a short duration/full throttle motor run event if I remember right. That means you can load it up to the point where it survives for the required duration.
If you are in serious competition events you can count on the fact that there will be someone there that wants to win bad enough to be perfectly willing to take a motor right to the limit to do it.
That is a nice looking prop and spinner, I don't even want to think about the coset or that I need anything like that on anything I fly. Are those sold by someone? Or just custom made?
Jack
Old Apr 15, 2013, 08:13 AM
ApexAero's Avatar
Joined Aug 2008
3 watts per gram? Holy Cow! I'm beside myself! I had a poor start with the HV160, the factory preset PWM was on 'out-runner mode' and had some issues not going to full power on full stick, Gerben was keen enough to recognize it and suggested using 16Hz explaining the controller was reading half what it should have on the 4Hz out-runner mode , it woke up!
The prop,spinner, yoke and hollow titanium motor shaft are produced by friends in the F3S Speed community of Germany and mfg on order. I could probably get more out of the motor and take it to it's limits but I can't afford the 900 euro for a YGE 300 amp ESC! 18700 rpm is right at 317 mph pitch speed minus 20% put me in the 250mph range, now I'm worried about the torque! It is so strong it twists the 14mm delrin test stand about 15 degrees at the head, takes most of my strength to do that by hand.....
Old Apr 15, 2013, 08:25 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Yep, 16 Watts per gram it should have been. And that is even better!
Sounds like you have good access to the best hands and minds for speed.
As I got started on re-winding I spent a lot of time browsing Dr. Okon's old croco pages on the building and re-winding motors and using his calculators and stuff. His the newer powercroco pages are interesting enough and google translates OK too.
I doubt that I'll ever get around to speed motors or speed flying. For my skills, it takes too long to find all the pieces when I fly too fast!
Jack
For Sale SOLD Scorpion HK-4035-500KV new in box bluedevil2001 Aircraft - Electric - Power Systems (FS/W) 2 Jun 04, 2012 11:48 AM
Scorpion HKIII-4035-450 New, Never Used! $225 Shipped! jmpwnd Aircraft - Electric - Power Systems (FS/W) 1 May 21, 2012 01:33 PM
Discussion Kv problems. scorpion 4035 and 4025 12N8P, rewind issue. modisc Electric Motor Design and Construction 15 Dec 27, 2011 02:10 AM
Discussion Rewinding Scorpion 4035 kit HSC2 Electric Motor Design and Construction 8 Jun 10, 2010 12:52 AM
For Sale 100 Croco 40mm Laminations. ryanl2006 Aircraft - Electric - Power Systems (FS/W) 0 May 09, 2007 07:54 PM
