Mali, Tombouctou, Timbuktu
Joined Aug 2012
@Integrity..
These are the 2 bolts that I have really snug, as they are the 2 that hold the tail boom in the brackets. I just realised you plan on using the 2801 RX with the uBeastX but I think you might have issues. I replied in the Walk-era thread by KDean about shakes and compatibility issues as noted by Buzzflyer here in the UK who has been asked to build them on occasion with the 2801 RX. You might want to eMail John, here for more info'; http://www.buzzflyer.co.uk/ |
Joined Aug 2012
Loving those CF boom supports. I'm gonna get some of those, definitely.
I notice the servo's have all changed as well. Mine uses 501 on the swash and a 502 on the tail. Wonder what these new ones are like? Not that I can fault mine at all. I do not like the new Formula canopy one bit though, and it's a rip off at $90 I think. I think the Neon Green one is quite smart though. |
Which skids are you using? The white ones particularly?
I almost got this one instead but it was sold out everywhere, as was the uBeast combo. But i had been eye balling the last one in stock for a while at club heli. So i grabbed that one. I think the BeastX is going to be just fine. I will probably hold off flying the X5 for like a YEAR or 2 before i can afford a damn DX8 i suppose. No point in getting the DX6 or 7 with only 1 idle up mode. GRR. I wish Walkera wasn't such proprietary junk! Quote:
Screw paying $100 for a canopy too. Like i said, i grabbed a Canomod canopy with a crack in it from helidirect for $25. You can't beat that. I'd bet money that Fusuno canopies are better made than Gaui's stock and Canomod too. But it looks nice. I just know the Fusuno canopies will bend and flex nicely and are not so brittle. I'd fly without a canopy or make my own before dropping that much on one. I don't need a stinking canopy to slap my sticks around then crash anyway, right? ![]() Far as i know, Hyperion are the manufacturer for the servos. I think they just upped them to a higher grade servo. From what i can tell. I didn't look at both to compare, and i know next to nothing about them compared to you guys. But the Premium package servos say "Brushless" These are superior to the "Coreless" servos i suspect are given on the uBeast super combo heli. I wouldn't doubt if they have extra torque because of the brushless motors vs coreless. But either way they should last longer before the motors go bad. Who makes that Vbar? Is it Mikado? |
Joined Aug 2012
The stock boom supports on mine are Aluminium, or some light metal, but I can't remember right now as it's in the bedroom. The Aluminium boom supports are OK, but I would much prefer those new ones. They look great. Anyway, when are you expecting your X5? PS- Gaui have been listening to us, and have just released some CNC tail grips for the X5, and they're quite reasonably priced at a msrp of $37 I think. http://www.gaui.com.tw/html/shopping_view.asp?sn=1633 I don't mind the stockers at all, the plastic used is nice and sturdy,but I heard people have been using X4 and X7 grips if I'm not mistaken. |
Just a thought, i plan on getting some for mine eventually and have been using them on my 450. It keeps the tail nice and firm for piros. Those CNC tail grips sound sweet for that price. I don't mind the plastic. But i fear stripping from the grip linkages under the tail load. If no one is having the issue, they are probably fine. But CNC just looks better too. It's probably heavier though, huh? I just checked. The X5 is in Orlando as we speak. That is only about 45 minutes from here. It will probably be delivered tomorrow. Maybe along with all the tools and things i ordered. The pack from hobby king should be here soon too. But it's looking like the X5 will be grounded for a good while. |
That remote antenna I was referring to was a "loaded balanced" item, the length of the antenna was short, but the "load" was matched to equal the proper length of a full length antenna.
In other words, a antenna can't just be lengthened or shortened to suit you. They usually make the antenna length to the middle of the frequency range at a 1/4 wave length. Here is the formula: This chart shows wavelength in meters and frequency in hertz. By looking on the chart you may convert from wavelength to frequency and frequency to wavelength. Frequency and wavelength of light are related to one another through the speed at which light travels. Equation: f * λ = c Equation: E = hc/λ where: f = frequency in Hertz (Hz = 1/sec) λ = wavelength in meters (m) c = the speed of light (299792458 m/s) E = energy in electron Volts (eV) h = Plank's constant (6.626068 × 10-34 m2kg/s) Quote:
The N router is in 5.1 Ghz no where near your freq.
Also, I found that the Devo 10 is using the same "DSSS" protocol as the 2801 pro. With your 2702V RX your dual antennas must be at 90 degrees from each other. That picture you showed of the two curled in the same direction is not correct & I sure hope it wasn't your layout. The reason we went to a remote antenna for 72 MHZ. was no one wanted a 34-36 inch wire flopping about near our tail rotors or near the main blades if you did pitch pumps. Just too easy to snag it. |
Just to back myself up. Because i might have been barking in the dark. I found this on wikipedia (however reliable that might be) It looks like the 5 Ghz wireless n protocol is not completed yet. The standard is planned to be finalized the end of 2012: Full article on IEEE 802.11n-2009 But all that being the case. I 100% doubt that any kind of interfearance is the cause. The range is too great for there not to be considerable degradation. Plus the stupid thing is supposed to hop channels to prevent that. If Walkera can't get that right. Well, it's worse than i thought. |
Well when i got home today my new X5 and my first wave of spare parts arrived! PLUS! Guess what! The guy at my LHS is selling his complete airframe for it without blades (possible with motor, not scorpion) for $200. Can you say spare parts!?!
Oh yeah, and i made an extra $300 today on a side job. So guess who will NOT be using the 2801 pro to fly this beast! I might test it out or something. But i'm waiting till i get the new one. I seriously challenge someone to doubt that i make money appear when i need it though the universe's law of attraction! It's all in your head! Can anyone verify for me that all i need for the uBeast is a satellite RX, not a full RX right? This is what the guy at my LHS told me. I won't need to do anything buy plug my servos into the uBeast and get a Spektrum TX with the Satellite RX? Someone please verify if possible? I thought a RX was also needed with a Satellite attached to that, but now thinking about it. That seems redundant!? OH, AND i have to plug my vendor! Sorry guys. This has never happened in this hobby for me. But i HAVE GOT to send some business this guy's way. He was SUPER helpful in offering to try to get my Savox 0257 servos warrantied on my 450 for a broken potentiometer on two servos. Since he tried!, and was being totally honest with me that it was unlikely but he at least would TRY. I decided to order my X5 and all of my current spare parts from him (except the skids in the photo came from my LHS, YES!!!!, my LHS stocks Gaui parts too!) The thing that REALLY sets this above and beyond any purchasing experience i have had in this hobby is. On top of the Free Shipping, that was absolutely not some BS, crappy shipping. It was 3 day Priority mail for FREE. Thats at least a $25-$30 value right there! But he sold me a 2801-pro RX that he had on sale for something like $34. Apparently he was out of stock!!! OH NO!!! Right???? No this guy didn't even contact me about it or anything. He placed a order though another vendor for a 2801-pro that cost $44+ tax since he lived in the same state + SHIPPING. He might have made some money off the heli purchase. But having an item sent to me from another vendor, which cost more, plus tax & shipping. Then it had advertisements and logos for the competitor web site with it too! This guy simply wanted me to get what i ordered and enjoy my purchase. End of story.. So MAJOR HATS OFF to Rick over at Club Heli for making this my very best, most exciting heli purchase EVER! I really can't say enough about how well his communication and willingness to please has been. So please check out the web site for your Gaui and other heli needs. Right now they have all their Walkera parts on sale too! 30% off. (looks like he's smart and is liquidating his WK inventory) ![]() http://www.clubheli.com/ |
United Kingdom
Joined Sep 2011
More pictures please!
| Thread Tools | |
| Discussion Gaui x2 fes super combo best in its class | celuffka | Electric Heli Talk | 0 | Mar 01, 2012 09:49 AM |
| Sold Gaui X5 fes combo RTF | Rc-Heaven | Aircraft - Electric - Helis (FS/W) | 0 | Feb 03, 2012 02:04 AM |
| Sold Gaui X5 FES "Super Combo" + extras | Flatusboy | Aircraft - Electric - Helis (FS/W) | 1 | Oct 11, 2011 07:53 AM |
| For Sale selling GAUI X2 FES Super Combo microbeast version | lidong lisa | Aircraft - Electric - Helis (FS/W) | 1 | Sep 07, 2011 12:27 PM |
| Sold GAUI X5 FES COMBO BNF w/Hyperion Batteries | cjdscratch | Aircraft - Electric - Helis (FS/W) | 0 | Jul 19, 2011 07:13 PM |
