Old Oct 24, 2012, 03:59 PM
jjmelo is offline
Find More Posts by jjmelo
jjmelo's Avatar
United States, CA, Burbank
Joined Aug 2012
70mm BAE Hawk maiden flight and crash. What happened?
Hey guys!
I bought a 70mm BAE Hawk, made by TFmodels, here on rcgroups. I put it together and flew it this weekend, but the maiden flight ended in a crash.
Check out the video here:
http://www.flitereport.com/bae-hawk-...t-crash-video/
The instruction manual said to set the CG at 85mm behind the leading edge, but the seller said it was wrong and it should've been set to 65mm. The manual for the E-Flite version (which this TFmodel seems to be a clone of) says 80 - 90mm.
I set it to 65 mm, I even stuffed a 1000mah 3-cell in the nose to balance the plane at that point, but after I crashed it, the very helpful gentleman that was helping me out with the maiden said it seemed too tail heavy (the guy flies turbine-powered planes).
To me, it seemed like I had way too much throw on my ailerons, even though I lowered the throw to 70% with 35% expo, per said gentleman's recommendation. When we were doing a pre-flight check, he recommended that I lower the throw on aileron.
You can see I'm over-correcting on ailerons, causing me to invert at some point, lose orientation and eventually hitting planet earth. What do you think happened?
jjmelo is offline Find More Posts by jjmelo
Latest blog entry: Chasing tail
Old Oct 24, 2012, 04:29 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Looks tail heavy.
Oversensitive control surfaces is a bi-product of a tail heavy situation. When in doubt...always go with the nose heavy CG.
A nose heavy plane will fly poorly..but a tail heavy plane wont fly long.
vettster is offline Find More Posts by vettster
Old Oct 24, 2012, 04:31 PM
Znybar is offline
Find More Posts by Znybar
Joined Sep 2012
Looking at the videa I don't see how the experienced rcer could say it was tail heavy. It showed no signs of purpoising or tail stalling. Did you have to put a lot of down elevator to keep it level? I think it's clear from the video that too much aileron throw/expo was the issue. You over-corrected and that led to the crash.
Also I'd be weary of your plane actually being too nose-heavy, sound like you have a LOT of weight up the front. If the plane starts to pitch up at speed because you have to put trim, you'll likely have your CG set too far forward.
Znybar is offline Find More Posts by Znybar
Old Oct 24, 2012, 04:42 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Do you see when he's climbing out to the left how the tail is also to the left?
Was he pulling up to climb or was the plane doing it for him.. I dont know. But over sensitive ailerons are for sure a biproduct of a tail heavy situation. With an experienced turbine pilot next to him, I highly doubt he let him take off with an inch of throws.
Comon Pav...get with it
Old Oct 24, 2012, 05:21 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
GWS A-4 will balance on right on and seem tail heavy if there are too much throw in elevators and ailerons....really weird.
Seems like it's the same here....too much throw in controls...
Plane looked like it took off pretty good and got wild afterwards...I would make it nose heavy also and go from there.
erh7771 is online now Find More Posts by erh7771
Old Oct 24, 2012, 05:54 PM
Znybar is offline
Joined Sep 2012
Planes that fly dead level but have too much aileron sensitivity are NOT tail heavy. As I said, I asked the OP if he had to do much elevator correcting during the flight, which would certainly indicate imbalance.
Old Oct 24, 2012, 06:29 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
You may have asked...But he did not reply...
Where in that video did you see it flying dead level? He was climbing the entire time until it dropped a wing on the bank due to tail heavy. The rest was for sure over compensation. But in the bank the plane Stalled
Here's another question for him. Where DID you set the CG
See ya Pav got to go
Old Oct 25, 2012, 05:20 AM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
According to the website with the video (linked in the orig. post), jjmelo set the CG at 65mm behind the leading edge. If it was supposed to be 85 mm behind the LE, that means he flew it with a CG that was 20mm forward of where it was supposed to be. Still sound like it was tail heavy??
Josh
jgalexander is offline Find More Posts by jgalexander
Old Oct 25, 2012, 08:51 AM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
I think Vettster is on the right track. There may be more going on here like angles of incidence wing to tail, and the C of G has to be calculated to match.( Knock off kit?) If too tail heavy the ailerons become ineffective at lower movements and speeds
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Oct 25, 2012, 11:36 AM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
I think this is being super analyzed here. I think its somewhat clear he lost orientation and dumped it. Regardless of if it was a bit tail heavy or not. If he made it that far around the tail heaviness wouldnt be that big of a deal. To the op. This is your first edf im assuing?
stingeragents is offline Find More Posts by stingeragents
Old Oct 25, 2012, 11:48 AM
jjmelo is offline
jjmelo's Avatar
Joined Aug 2012
Hey guys! Thanks for all the responses. Now to answer some of the questions that came up.
I set the CG to 65mm behind the leading edge of the wing. I was running it on a nano-tech 2650 mah 4-cell, which is lighter than the 3200mah battery other's have used. I stuffed a 1000 mah 3-cell battery to achieve the balance point.
I don't recall having to apply back pressure to keep level...maybe I did but the "flight" was very short.
This is my second EDF. My first one was the Hobbyking/Durafly D.H. Vampire. Its very gentle, forgiving and glides forever unpowered, mainly because its a foamy and because of the huge wing surface. I flown the Vampire a lot, and its the reason why I got bitten by the EDF bug. I've been flying for over 10 years, though.
I'm currently repairing the Hawk, fortunately I cut power and it landed in a soft spot. The nose is destroyed but very fixable (provided that I learn to fix fiberglass).
Old Oct 25, 2012, 12:34 PM
blanik213 is offline
Find More Posts by blanik213
BLANIK213
blanik213's Avatar
United States, NY, Phoenicia
Joined Feb 2008
I am at a loss to understand why most of you are in agreement that his setup was tail heavy when he stated that the CG was set at 65mm back of LE instead of recommended 80-90mm .65mm back would give you a biased nose heavy CG not tail heavy and at 20-25mm off from recommended CG and too much control throws that would create another type of stall situation in and out of a turn which is were the problem began and with over corrections he finished it.If not for the excessive throws he would have probably been able to get it back down in one piece to make CG changes and fly another day. Just my 2 cents sorry for your loss jimelo.
blanik213 is offline Find More Posts by blanik213
Old Oct 25, 2012, 12:57 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I completely agree with your thoughts, to add to it I think he also looked under powered and hawks like to tip stall or snap, so take off severely nose heavy and and probably holding up elevator to maintain level flight then he turns left and being nose heavy the nose will want to drop thus more elevator needed and BAM! high speed stall which is a snap roll to the ground.........I think the cg not being ideal was only a contributing factor to it being under powered, and yes it appears he was nose heavy not tail heavy. with jets, being overly nose heavy will cause you to crash also
my .02cents
jcdfrd is offline Find More Posts by jcdfrd
Old Oct 25, 2012, 01:59 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
over-contolling can cause a dynamic stall. rapid changes of AOA can cause a stall and the nose to tuck down as induced vortices are shed from the LE of the wing. based on what I saw in the video, it looked remarkably like the nose tucked after over-controlling while in the turn. combine that with the fact that the jet wasn't up to a decent speed yet and you got all the makings of the end result of the video. my two cents of course, but there's no doubt that the plane was over-controlled, which induce a nose down tuck and she stalled and hit the deck.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 25, 2012, 03:25 PM
djacob7 is online now
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
sSorry about the crash, jjmalo. What do you mean by "back pressure"? First time I heard this term.
djacob7 is online now Find More Posts by djacob7
Discussion Instructions/CG for Smartmodel 70mm BAe Hawk? fh64_lucky Electric Ducted Fan Jet Talk 2 Oct 25, 2012 12:06 PM
Discussion BAE Hawk - 70mm EDF Maiden flight jjmelo Electric Ducted Fan Jet Talk 1 Oct 24, 2012 04:04 PM
Sold Composite BAE Hawk 70mm EDF $200obo kclements Aircraft - Electric - Jets (FS/W) 4 Sep 07, 2012 02:00 PM
For Sale NIB BAE E-Flight BAE Hawk (price lowered) dmize Aircraft - Electric - Jets (FS/W) 8 May 10, 2012 07:44 AM
