Old Dec 05, 2003, 05:01 PM
BillBrian is offline
Find More Posts by BillBrian
Joined Dec 2003
Question
Building a power supply for brushless motors
I learned that an ESC converts DC into AC to run brushless electrics. Since I want to build a power supply (or buy one) to directly power a motor(s),what type of AC supply should I build/buy?
Is it a pure sine wave source?
Do I need to vary the voltage to vary the motor speed?
Where can I learn about the power requirements of these brushless motors?
Thanks!
BillBrian is offline Find More Posts by BillBrian
Old Dec 05, 2003, 05:25 PM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Unfortunately there is a lot more to it than that. If you search this forum (look in power systems section) there are a few plans for homemade ESC's. They are far more complex than a power supply.
Good luck!
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Dec 05, 2003, 07:00 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Idea: Buy a controller big enough for your use and build a DC power supply. Much easier and more fun.
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 05, 2003, 08:26 PM
CAFplanekid is offline
Find More Posts by CAFplanekid
De-Brushed user
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
little bit off topic, but Feathermerchant, where is Euless? Sounds familiar. Thanks
CAFplanekid is offline Find More Posts by CAFplanekid
Old Dec 05, 2003, 10:32 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Hey, I was serious. I'd just use a fused wire off a car battery if all you need is 12V
Just SW of D/FW airport
Old Dec 06, 2003, 06:59 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What he said. You don't just feed a fixed rate AC into the motor. You have to fire each winding with pulsed DC, and monitor rotor position carefully to ensure the motor operates correctly. That's what ESC's do.
..a
Old Dec 08, 2003, 03:37 AM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
What Andy said; BL motors do NOT run on AC. They run on pulsed DC, i.e., the output voltage from the ESC never swings negative - it's either on or off. Each set of coils (phases) get rapidly pulsed on then off in sequence thereby causing the magnetic rotor (whether outrunner or inrunner) to rotate. The faster the on/off sequence between phases, the faster the motor runs.
babblefish is offline Find More Posts by babblefish
Old Dec 08, 2003, 11:34 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Besides, regular old house current is only single-phase AC. Brushless motors are technically three-phase.
mkirsch1 is offline Find More Posts by mkirsch1
Old Dec 08, 2003, 07:06 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Re: Building a power supply for brushless motors
Yes, that's correct. The brushless motors we use run on synthesized three-phase alternating current. The waveform from ESC's isn't sinusoidal and the voltage is never more negative than the negative terminal of the battery pack, nevetheless it's still bona fide three-phase alternating current.
You might be able to find the information you need with this Google search for "three phase ac power supply". What are you building anyway?
Miami Mike is offline Find More Posts by Miami Mike
Old Dec 10, 2003, 03:49 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The difference between a brushless controller and three phase mains voltage is a lot.
Three phase motors are desined to run at constant RPM, can not be throttled, and work best in a fairly narrow power band.
What our ESC's do is chop DC about to give variable frequency variable voltage outputs. In a fiarly copmp[lex way, because they also sense RPM and throttle position and adjust everythung to (hopefully) get the best mix of pahse advance, frequency and voltage for every possible throttle setting prop load and rPM and inpout voltage...
Or to put it another way, do you REALLY want to follow in e.g. Castle Creations last 3 years of R & D? Or just buy a controller from them
Old Dec 10, 2003, 04:59 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
How a brushless ESC works, waveforms, diagrams:
http://www.torcman.de/peterslrk/SPEEDY-BL_eng.html
Met vriendelijke groet Ron van Sommeren
diy outrunner brushless e-motor discussion.
Electric fly-in & lrk meet, June 27th, 2004, Nijmegen, the Netherlands.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Dec 10, 2003, 04:37 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Vintage1 Good post. There are now many variable freq drives out there for things from locomotives to chiller drives. They allow better mechanical efficiency for many processes without the need for brushes and the associated maint.
Old Dec 11, 2003, 06:42 AM
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Re: Re: Building a power supply for brushless motors
Originally posted by Miami Mike
Yes, that's correct. The brushless motors we use run on synthesized three-phase alternating current. The waveform from ESC's isn't sinusoidal and the voltage is never more negative than the negative terminal of the battery pack, nevetheless it's still bona fide three-phase alternating current.You might be able to find the information you need with this Google search for "three phase ac power supply". What are you building anyway?
Indeed there are three phases, but this doesn't mean they are alternating current (AC). Alternating current implies that the voltage swings both positive and negative. Each of the phases for a brushless motor, on the other hand, is a "chopped" direct current (DC) voltage which in turn are 120 degrees offset from each other (120 x 3 = 360 degrees = one rotation of rotor). Another way to visualize this is to imagine a three cylinder engine where each of the cylinders represents one of the phases. Each cylinder fires in sequence one after the other to rotate the crankshaft.
If one where to connect a brushless motor to a three-phase AC power supply it would not run, but instead just sit there buzzing and humming due mainly to the fact that it uses permanent magnets. AC motors do not use permanent magnets unless there is a rectifier built-in which converts the AC to DC first. My mini-lathe uses such a motor.
Old Dec 11, 2003, 05:50 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Re: Re: Re: Building a power supply for brushless motors
Sorry, but that's just plain wrong. "Positive" and "negative" are relative concepts that depend upon one's frame of reference (what one chooses to call "ground"), and have nothing to do with the concept of alternating current.
One type of alternating current that we're all familiar with is that which comes from the electric company through power lines in the form of a sine wave, but that's by no means the only type there is. All electric current is either direct or alternating, and if there's any regular change in current, then by definition that change represents alternating current. Current that is capable of steadily flowing through a capacitor is alternating current. Current that can transfer energy from the primary winding to the secondary winding of a transformer is alternating current. (The current produced by a brushless motor controller is capable of both.)
The brushless motor controllers we use in our models work by synthesizing three-phase alternating current from direct current provided by battery packs. It's as simple as that.
Old Dec 11, 2003, 06:48 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Re: Re: Re: Re: Building a power supply for brushless motors
Brushless DC motors will not start and run on 3 phase AC. Brushless controllers perform the same function as the brushes and commutator do in a brushed motor. The difference being the FETs are doing the switching.
Steve
sneu is offline Find More Posts by sneu
Power pole for brushless motors? Jim McPherson Power Systems 12 Sep 08, 2012 11:55 PM
Need power supply for testing motors mgdon Batteries and Chargers 8 Aug 20, 2004 04:14 PM
Computer Power supply for Foam Cutting? dwood99 Foamies (Kits) 5 Jul 18, 2001 01:22 PM
homebuilt controller for brushless motors Ron van Sommeren Power Systems 13 Jun 03, 2001 01:31 AM
Computer power supply for charging E SOARER Power Systems 10 May 23, 2001 12:54 AM
