Ahh your going to love this site its in the UK they have smaller metal props that can be trimed down as needed.
https://astecmodels.co.uk/catalog/ |
http://www.offshoreelectrics.com/pro...2318.26&cat=16
Product ID: grp-2318.26 Graupner 26mm For 2mm Threaded Shaft In Stock: 12 Aztec use to have the above. Or -Just watch this vid for reference you don't have to have a lot of fancy gear to do - a single file and some fine sand paper to polish out. You draw out a shape you like cut / file to shape place tape over the new blade trim excess tape off and place over the uncut blade to duplicate. Then file sharp as the vid shows. Detounge Sharpen and Balance RC Boat Props
To start take it down to 24mm, from there you can always trim down more if the motor is working too hard. By removing the low pitched area of the prop a lot of prop weight, drag with reduced amp draw increases rpm and speed.
Video of the Vee running here
| Thread Tools | |
| Help! Joysway offshore cat light... | syog100 | Micro and Sub-Micro Boats | 6 | Nov 24, 2012 11:07 AM |
| Discussion joysway offshore lite cat | syog100 | Micro and Sub-Micro Boats | 2 | Aug 27, 2012 03:35 PM |
| Discussion Magic Vee taking in water | MagicPython | Micro and Sub-Micro Boats | 5 | Jul 18, 2012 02:56 AM |
| Discussion Magic Vee trigger damage | snowmeow | Dock Talk | 9 | Apr 15, 2012 12:25 PM |
| Question Joysway magic vee | robadob | Racing Boats - Electric | 13 | Feb 07, 2012 06:22 AM |
