Old Oct 24, 2012, 10:33 AM
chrisorbics is offline
Find More Posts by chrisorbics
Chris
Joined Apr 2012
Best Charger for around $100 that can charge 4 batteries at once up to atleast 6 cell
Hi, i am looking for a good charger that can charge 4 batteries at once up to atleast 6 cells. There are so many out there that I don't know which one to go with. I have a seen one from hobby king and diamond brand advertised in magazines. Does anybody have a reccomendation?
chrisorbics is offline Find More Posts by chrisorbics
Old Oct 24, 2012, 10:39 AM
creapyd is online now
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Buy quality, buy once. Your charger is your first and formost line of defense against accidental lipo fires. Don't cheap out. If you can only afford $100.00 then I recommend the
Cellpro multi 4. It will only charge 1 battery at a time, but its one of the safest and best chargers out there.
creapyd is online now Find More Posts by creapyd
Old Oct 24, 2012, 11:02 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
OP clearly stated 6 cell (presumably lipoly) requirement. In addition to his desire to have 4 ports, the Multi-4 fails the 6 cell criteria as well.
Many have had good success with the Hobby King, Hobbypartz, and Hitec multi-port chargers.
I'm sure that actual end-users will add their experience.
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 24, 2012, 11:06 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I am pretty sure there isn't a battery charger that can charge 4 6cell batteries all at once for $100. You'll pay that much for the power supply alone
MCrites is offline Find More Posts by MCrites
Old Oct 24, 2012, 11:15 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Depends on what you consider success. If you consider customer service and support into your overall success factor I've never seen anything that indicates HK delivers in that area.
Ohmic is offline Find More Posts by Ohmic
Old Oct 24, 2012, 11:18 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Well said creapyd.
christorbics: you left out the most important part of your requirement. What is the mah capacity of your batteries? That is needed to determine the wattage of the charger.
For instance four 6S 1000mah charged at 1C requires over 100 watts.
Four 6S 2200mah charged at 1C requires over 220 watts.
Assuming your batteries are at least 2200mah I recommend you get at least a 300 watt charger.
iCharger 106B = 250 watts @ $90
iCharger 206B = 300 watts @ $125
However for $175 you get 1000 watts from the PowerLab 6. With the PL6 you could charge four 6S 2200mah at 3C.
All from Progressive RC
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Oct 24, 2012, 11:35 AM
Prefectionist
Joined Mar 2007
I totally blew past the 6s requirement. sorry. you can't get what your asking for under 100.00. Save up and buy quality
ether cellpro 10s or 10xp or if you buy the powerlab 6 you can parallel charge many 6s batteries. but all those are well over $100.00 and you need to find a good powersupply to feed them.
Old Oct 24, 2012, 04:33 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Also didn't specify if he wants to charge 4 of the same cell count at once in parallel or if he wants 4 independent charging ports so he can charge multiple cell counts at once. That's an important clarification.
This is the highest wattage 4 port I know of:
http://www.hobbyking.com/hobbyking/s...y_Charger.html
grimbeaver is offline Find More Posts by grimbeaver
Old Oct 24, 2012, 07:07 PM
Chris
Joined Apr 2012
Hi, I mostly charge3 cell 2200mah batteries but I am going to be getting a charger rc giat fussion which run on 6 cells minimum. If I could do two six cell pack at once I would be happy. Also four 3 cell 2200 mah packs would be great.
Old Oct 24, 2012, 10:10 PM
Ohmic is offline
USA
Joined Jan 2002
You might be able to pickup a used TP-1010C for that price.
Old Oct 25, 2012, 12:17 PM
Chris
Joined Apr 2012
Who makes that charger? If I spend more what do you reccomend?
Old Oct 25, 2012, 12:24 PM
United States, MN
Joined Feb 2011
Lets make this simple...
Charger:
http://www.progressiverc.com/icharger-106b.html
http://epbuddy.com/index.php?main_pa...&products_id=1
Paraboard (your choice based on connectors):
http://www.progressiverc.com/adapter...arallel-boards
http://epbuddy.com/index.php?main_page=index&cPath=15
If you don't know what you need give either of these stores a call and the guys who run them will be more then happy to help you determine what you need. They are both very reputable dealers.
Old Oct 25, 2012, 12:47 PM
Ohmic is offline
USA
Joined Jan 2002
Thunder Power, that's the TP in the model number. Check the batteries and chargers classifieds section.
If you can increase your budget I'd highly recommend the FMA PL6 or PL8.
Old Oct 25, 2012, 02:44 PM
USA, GA, Marietta
Joined Aug 2005
Go back and read post #6. I covered all the basics there.
Glen
Old Oct 25, 2012, 03:09 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Turnigy has a nice 400W charger.
RC Man is online now Find More Posts by RC Man
Discussion Balance charging 6 1S lipo batteries at once octanejunkie Batteries and Chargers 85 Oct 30, 2015 06:11 AM
Sold Want to charge 2 packs at once? New OBO Celectra 300mAh 2S balance charger for fomies Tomy. Aircraft - Electric - Batteries & Chargers (FS/W) 3 May 04, 2012 11:38 PM
Discussion charging 6 x 1s batteries at once help widget2k4 Batteries and Chargers 23 Mar 08, 2012 05:56 AM
Sold parallel charge and balance cables for charging up to 6 lipos at once ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 27, 2010 11:09 AM
Discussion Needing a battery package of around 100 Whr that can be charged in about 20 minutes.. elglobie Batteries and Chargers 11 Aug 06, 2009 09:59 PM
