Old Jan 25, 2013, 05:31 AM
Mike Meyer is offline
Find More Posts by Mike Meyer
Mike Meyer's Avatar
United States, OK, Goldsby
Joined Jul 2012
What material did you use for the skirt?
I discovered my old (as in, the son that was born when I was using it is now in college) Tyco Typhoon, which I sett aside when the skirt ripped. I'm thinking about "renovating" it (2.4Ghz rx, new motors & esc, etc), but first I have to figure out if I can replace the skirt.
Mike Meyer is offline Find More Posts by Mike Meyer
Old Jan 26, 2013, 09:20 AM
Rian21w is offline
Find More Posts by Rian21w
Belgium
Joined Jul 2012
I used some kite fabric because it is very lightweight but very strong.
It should be perfectly possible to rebuilt the skirt but the hardest is to get the right pattern for your hovercraft. You might want to try to use the old one as your pattern for making the new one.
Rian21w is offline Find More Posts by Rian21w
Old Feb 16, 2013, 05:41 PM
Miskatonic is offline
Find More Posts by Miskatonic
Miskatonic's Avatar
United States, VT, Burlington
Joined Feb 2008
You could also use rip stop nylon for the skirt, which is basically the same thing. They sell it at fabric stores. Speaking of that, I have to repair the skirt on my UHM-30. I wish I built a model with a dedicated lift only motor since I don't always want to come to a screeching halt every time I cut the throttle. Plus water evacuation is a big concern when the motor shuts off. Blipping the throttle on mine helps to tilt the nose up and shoots the water out of two small holes in the rear of the skirt.
Rian, how do you control the speed of the lift motor? Nice ductwork, btw. You may also want to consider a 3-bladed prop for the lift motor. I found that it helps "charge" more air into the duct because you have less space between your prop disc which seems to "seal" the duct better.
Miskatonic is offline Find More Posts by Miskatonic
Old Feb 19, 2013, 10:07 AM
Rian21w is offline
Belgium
Joined Jul 2012
I plugged the lift motor into the throttle channel because I wanted to be able to just give some throttle and then focus on the steering. The thrust engine is plugged into the elevator channel and then I did some mixing. The only problem is that i can't get more than 50 percent thrust or I have to flip a switch but then you constantly have to push the right stick down if you don't want thrust.
Good idea, I might try that later when I bought a three bladed prop. If I would make a new hovercraft I would certainly make the duct as small as possible because of the same reason. But the thrust motor is very light, so I just have to apply 1/3 throttle to lift it.
Old Feb 28, 2013, 06:47 PM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
on a hovercraft i built a while back, i modded the transmitter (cheap walkera heli) so that it had 2 throttle sticks it worked fine for me
derk is online now Find More Posts by derk
Old Jun 02, 2013, 04:26 AM
Rian21w is offline
Belgium
Joined Jul 2012
I already thought about that but I don't want to ruin my spektrum transmitter
I'm still having trouble with the steering, is there anyone out there that knows how I could solve this problem?
Old Jun 03, 2013, 01:15 AM
jpcwebb is offline
Find More Posts by jpcwebb
MHA webmaster
United Kingdom, England, Reading
Joined Mar 2011
In post 19, you say you did some mixing; what exactly is the mixing setup? I would have thought that the thrust fan could be controlled with the elevator channel entirely separately. What I have seen some folks do if you don't want to open up the Tx is to hook an elastic band over the aerial, behind the back of the tx under and up over the stick to hold it in the down position. A bit crude but it seems to work.
jpcwebb is offline Find More Posts by jpcwebb
Old Jun 03, 2013, 05:25 AM
windnsea is offline
Find More Posts by windnsea
Australia, VIC, Bass
Joined Jan 2013
Try reducing the size of the rear fins or even remove them completely and adjust the control linkages for maximum movement of the rudders.
As for the throttle problem you may need to use another esc with programmable throttle range, this would allow 100% throttle from the centre stick pos. I use a turnigy car esc with reverse which works well as it is designed for neutral at centre stick pos. pk
windnsea is offline Find More Posts by windnsea
Old Jun 03, 2013, 03:23 PM
Rian21w is offline
Belgium
Joined Jul 2012
jpcwebb, I mixed the elevator and flaps channel and then I set the flap rate for normal to 50 percent I think. So in normal i've got max 50% throttle with the stick centered and when I flip it I've got 100% throttle but the stick has to be all the way down if I want to stop. The throttle is controlled separately this way. I might try the rubber band trick
windnsea, If I remove the rear fins, how am I supposed to steer? I'm sorry, I just seem to not fully understand... I've seen some other people use a car esc and it does seem to work perfectly but I'm just sixteen years old and I don't have a lot of money to invest so... But thanks for the advice I'll try to modify my fins.
Old Jun 03, 2013, 07:25 PM
windnsea is offline
Joined Jan 2013
sorry to confuse you, - I only meant remove the fixed fins not the rudders��
Old Jun 04, 2013, 09:51 AM
Rian21w is offline
Belgium
Joined Jul 2012
Ohh thanks, I already thought about that. I might just make a new, round duct with fins that don't have the fixed rudder part.
Old Jun 05, 2013, 04:27 AM
windnsea is offline
Joined Jan 2013
Description:
Here is a pic of one of my models using an edf unit connected directly to a servo. Gives great steering response but you need to use a ballbearing servo to take the thrust loading.
Theres plenty of cheap and reasonable quality edf units and parts at hobbyking if you want to try something similar.
Old Jun 06, 2013, 01:54 AM
jpcwebb is offline
MHA webmaster
Joined Mar 2011
How about simply extending the rudders? Some folks in the MHA who had problems with a scale BH7 model added transparent plastic extension pieces onto the trailing edges of the rudders to give greater control. Seemed to help.
Old Jun 06, 2013, 07:17 AM
Rian21w is offline
Belgium
Joined Jul 2012
Yep, that probably is a better solution. The problem is that once it gets up to speed, the rudders almost don't have any effect. It doesn't really matter because I like cruising with it anyway. It just turn the moment I want it to .
Windnsea, good job on that hovercraft , but I want to make it work with these motor and prop. I will design an edf model in the future though and then I can mount the edf onto a servo.
Gallery RC Racing Model Hovercraft since past Century camoesas RC Hovercraft 3 Jun 14, 2016 07:07 PM
Build Log Scrachbuild Rc hovercraft MAX FORCE XRT-617 hovermaniac RC Hovercraft 27 Jun 16, 2015 08:42 AM
Cool Strange (real scale and RC) Hovercraft - from the past & futuristic. camoesas RC Hovercraft 18 Apr 03, 2014 09:39 PM
Cool Simple Dollar Tree foamboard RC ( skirtless ) hovercraft balsa or carbon RC Hovercraft 24 Dec 30, 2012 06:01 PM
