Old Oct 24, 2012, 09:09 AM
Rian21w is offline
Find More Posts by Rian21w
Belgium
Joined Jul 2012
Build Log
scratchbuilt RC hovercraft
I started building this hovercraft two months ago and now it's finally finished
Length: 60 cm
Weight: 850 grams
Thrust motor: 630 watts
Lift motor: 315 watts
For the steering I used a mini Turnigy servo
Both motors use a seperate battery, a 4s 2200 mAh for the thrust motor and a 3s 1300 mAh for the lift motor.
Here are some pics of the finished hovercraft:
Rian21w is offline Find More Posts by Rian21w
Old Oct 25, 2012, 04:33 AM
hovermaniac is offline
Find More Posts by hovermaniac
Estonia, Harju County, Tallinn
Joined Jun 2012
Video please
hovermaniac is offline Find More Posts by hovermaniac
Old Oct 25, 2012, 10:22 AM
Rian21w is offline
Belgium
Joined Jul 2012
The thrust motor is broken but once I got a new one, I will make a video
Old Nov 01, 2012, 10:54 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Nicely done! Can you post some shots of the underside/skirt? I'm considering building something similar.
Firehawk989 is offline Find More Posts by Firehawk989
Old Nov 15, 2012, 12:36 PM
Rian21w is offline
Belgium
Joined Jul 2012
This are the only 2 photos that I've got from the skirt and the underside. Basically the hovercraft is a foam plate with a hole in the bottom for the lift propellor.
Then I made an "air chamber" where the air from the lift propellor comes out about 1.5 inches smaller then the foam plate an with holes around the sides.
The skirt is made of separate segments which are sewed together and then attached to the foam plate and the underside of the air chamber.
Old Nov 20, 2012, 08:45 PM
Vancouver, BC
Joined Aug 2009
Thanks! Looks like a good simple and effective design!
Old Dec 04, 2012, 03:40 PM
Rian21w is offline
Belgium
Joined Jul 2012
Finally I managed to get a new motor! This one is way less powerful than the one before but that doesn't matter because it was overpowered and with this little 24 grams motor and a 2 cell 450 mAh it is still quiet fast. I also changed the rudder assembly because one the first test run it just didn't wanted to turn. I tried making a video but the quality isn't that good and it was filmed indoors. Soon I'll make a better one outside when I can find some spare time!
Here is the link for the video:
Scratchbuilt rc hovercraft test run (0 min 27 sec)
Old Jan 03, 2013, 10:30 AM
badpilotto is offline
Find More Posts by badpilotto
BadPilot
badpilotto's Avatar
United States, IL, Custer Park
Joined Nov 2007
Rain21,
Awesome and it runs do well, nice work! Will it hover over water?
John
badpilotto is offline Find More Posts by badpilotto
Old Jan 05, 2013, 12:33 PM
Joined Jun 2012
Nice work!
Old Jan 07, 2013, 12:20 PM
Rian21w is offline
Belgium
Joined Jul 2012
Originally Posted by hovermaniac View Post
Nice work!
It should run on water but I'm a little afraid to test it because I don't want water to enter the holes.
Old Jan 08, 2013, 12:11 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
You are welcome and thank you for the answer. Another impressive item was how quickly it maneuvered. After watching your video I looked up some other hovercrafts and found a skirt-less type which reminded me of the Star Wars hovercraft.
Old Jan 09, 2013, 12:57 AM
jpcwebb is offline
Find More Posts by jpcwebb
MHA webmaster
United Kingdom, England, Reading
Joined Mar 2011
You can put small holes in the bottom edge of the skirt to drain water if you want to run on water regularly and it shouldn't affect hover performance - a few of mine have them.
jpcwebb is offline Find More Posts by jpcwebb
Old Jan 10, 2013, 02:06 AM
BadPilot
badpilotto's Avatar
Joined Nov 2007
jpcwebb,
Thank you for the information and I will one day attempt to build one. As a child I have always wanted a hovercraft that would go over water.
John
Old Jan 10, 2013, 04:09 AM
jpcwebb is offline
MHA webmaster
Joined Mar 2011
Er, ok, I was referring to Ryan21w's comment "I'm a little afraid to test it because I don't want water to enter the holes"...
Old Jan 13, 2013, 03:52 PM
Rian21w is offline
Belgium
Joined Jul 2012
Thanks it does indeed maneuver pretty good, but the faster I go the less responsive it becomes.
Thanks jpcwebb for the advice, I might try that out when I got over my fear
Gallery RC Racing Model Hovercraft since past Century camoesas RC Hovercraft 7 Yesterday 06:52 PM
Build Log Scrachbuild Rc hovercraft MAX FORCE XRT-617 hovermaniac RC Hovercraft 27 Jun 16, 2015 08:42 AM
Cool Strange (real scale and RC) Hovercraft - from the past & futuristic. camoesas RC Hovercraft 18 Apr 03, 2014 09:39 PM
Cool Simple Dollar Tree foamboard RC ( skirtless ) hovercraft balsa or carbon RC Hovercraft 24 Dec 30, 2012 06:01 PM
