Old Oct 24, 2012, 05:25 AM
darksaber is offline
Find More Posts by darksaber
Joined Apr 2012
NEW RELEASE Top Rc Hobby - 1280mm BLAZER trainer with 2 sets of WINGS
BLAZER TRAINER
Well i have been buying TOP RC HOBBY models for some time now and own there FW-190 1200mm ,GEEBEE 1200mm & Cessa 184 965mm and and have been very impressed with there models so far and have now heard that there releasing a new trainer aircraft with a twist to all other trainers on the market today.
One of the things the BLAZER stands out from the rest is that it not only comes with 1 set of wings but two as one set is configured for very stable flight and the other was designed for aerobatic maneuvers once the pilot has gained enough experience to pull off flight stunts.
Trainer Wing
With the trainer main wings, it can achieve the stable flight and is easy to control. The Blazer cannot stall even under the middle speed or lower speed flight. It can also manage inside loops, outside loops, inverted flight, axial roll and other aerobatic action.
Sports wings
The sports wing is designed for middle class or experienced pilot's who enjoy throwing there aircraft around in the the sky.
With the sports wing fitted it can achieve high speed flight and flexible maneuvers . It can manage much more vigorous maneuvers than the trainer wing.
It's powered by a 2200mah 3s lipo and should give over 8 minutes of flight and the model like previous aircraft from top rc hobby is easy to put together without needing any glue so it will be easy for new pilots to set up.
Features
Easily Removable aluminum alloy landing gear for structural strength and very good shock absorption.It also has high ground clearance so you will be able to take off from rough landing strips without problems.
Durable and crash-resistance design with high practicality and vivid color scheme,Overall a good choice for a beginner.
A automatic heat dissipation function on the motor that ensures high efficiency and prolongs the life of the motor.
All the servos are easily detachable to make them easy to maintain or replace and the plane is easy and convenient to disassemble and maintain overall for some one new to the hobby.
Steerable landing gear
Specifications:
★ Wing Span: (1)Trainer version: 1280mm/50.40in; (2) Sports version: 1200mm/47.25in
★ Length: 942mm/37.09in
★ Weight: 1152g
★ Thrust rate:1:1
Configuration:
★ Motor: Out runner brushless AT3511 KV750
★ Battery: LI-PO 11.1V,2200mAh 20C
★ ESC: 30A Brushless ESC
★Servo: 9g*4
★R/C System: 2.4Ghz 4ch E401 radio
darksaber is offline Find More Posts by darksaber
Old Oct 24, 2012, 09:32 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
The price for this model is? The website shows nothing listed as far as pricing for anything they offer.
dedStik is offline Find More Posts by dedStik
Old Oct 24, 2012, 01:12 PM
Joined Apr 2012
That's because there a manufacturer in china mate , it's up to the retailers to price the products as there the middle men who import the models from china and sell them in your reverent country.
But knowing how good value the TOP RC HOBBY planes i already own are im sure it will be reasonable.
As soon as see any see websites selling them or get any more info i will post it here.
One of the many good things about this manufacturer is that there models are solidly built and come in good packaging unlike for instance plenty of hobbykings disasters waiting to happen.
NEW RELEASE - TOP RC HOBBY Blazer-trainer with TRAINER WING FITTED (3 min 23 sec)
TOP RC HOBBY NEW RELEASE Blazer trainer with SPORTS wing fitted (2 min 34 sec)
Old Oct 24, 2012, 07:12 PM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
i want one but how?
IWC is offline Find More Posts by IWC
Old Oct 25, 2012, 07:36 AM
Joined Apr 2012
Well your going to have to be patient as this is a new release so u will have to wait until online retailers start stocking it .
I will contact the manufacture and ask them which online retailers have any ordered, maybe they can help.Which country are u in as your location has a part to play on price and availability.
I don't work for TOP RC HOBBY but i know a few company's in Asia and just pass on information that i come across in my line of work so i don't know all there business dealings .
Some TOP RC HOBBY aircraft i brought back from china for my model aircraft club mates and myself.Every one of them was top notch quality and well packaged.They all arrived in England after a 6000 mile trip without a mark on them .
TopRC Gee Bee R3R Flight test (4 min 53 sec)
Old Oct 28, 2013, 06:44 AM
Dalrock69 is offline
Find More Posts by Dalrock69
Dalrock69's Avatar
United States, AR, Jonesboro
Joined Oct 2012
Airfield Blazer RC 4 Channel Trainer Plane Ready to Fly RTF 1280mm Wingspan - $179.00
http://www.nitroplanes.com/95a283-bl...Fa5r7AodVXYAiA
~D~
Dalrock69 is offline Find More Posts by Dalrock69
Old Oct 28, 2013, 07:13 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Nice 2nd plane. It certainly would be advantageous to have it available as a PNP for those wanting to use their own Tx's & reduce price. I'd buy one.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Oct 29, 2013, 08:27 PM
kelly2508080132 is offline
Find More Posts by kelly2508080132
Joined May 2012
Denny
Well ,it named ARF version in USA ,I think
kelly2508080132 is offline Find More Posts by kelly2508080132
Old Jan 20, 2014, 02:12 PM
Wesley Dreyer is offline
Find More Posts by Wesley Dreyer
stock blazer rc plane
South Africa, KZN, Richards Bay
Joined Dec 2013
Review rc Blazer pnf.
Bought one here in South africa. First plane. Assembly easy.Motor is very powerfull. Easy to fly. Take off must be on a smothe surface as the prop is a match stick clearance from the ground. Give it gass the prop digs in to the grass and you go nose over. Once its in the air it goes like a at out of hell. Landing is horrible as no matter what you do the prop touches the ground and you flip. Got a bigger nose wheel to help. Put it into the ground twice very hard. Some foam glue on the wing supports and a new prop . All ok to go again. This plane earns my respect as one tough trainer of note. Besides the bad nose wheel and the huge 12 x 8 prop that catches everything its a tought little sport. 3 out of 5 for me.
Wesley Dreyer is offline Find More Posts by Wesley Dreyer
Old May 30, 2014, 04:59 AM
NoLimitsVideo is offline
Find More Posts by NoLimitsVideo
Joined Nov 2011
This post has been out for a very very long time. But I just ordered a Blazer, so I was wondering if you guys could give me some feedback and tips before I receive it ? Are you still happy with this plane and what else ........
Thanks a lot.
Phil
NoLimitsVideo is offline Find More Posts by NoLimitsVideo
Old May 30, 2014, 04:12 PM
failboat is offline
Find More Posts by failboat
yank and bank!!
Joined May 2013
So is there a back to the future hoverboard inside it?
failboat is offline Find More Posts by failboat
Discussion NEW TOP RC HOBBY Hawker Hurricane 750mm NEW RELEASE darksaber Electric Warbirds 155 Mar 14, 2015 06:57 AM
Discussion NEW TOP RC HOBBY 965mm Wingspan 400 class cessna 182 darksaber Beginner Training Area (Aircraft-Electric) 13 Aug 31, 2013 12:57 AM
Found Sky Trainer CMP 50 Nitro RC Plane Wing Set Needed chebert Aircraft - Fuel - Airplanes (FS/W) 0 May 09, 2012 08:12 PM
SuperStar 40 or Hobby Town Trainer top wing needed everyoneknowsjef Non R/C Items (FS/W) 3 Nov 08, 2011 11:08 AM
SuperStar 40 or Hobby Town Trainer top wing needed everyoneknowsjef Aircraft - General - Miscellaneous (FS/W) 0 Nov 08, 2011 07:15 AM
