This thread is privately moderated by RHTizzy, who may elect to delete unwanted replies.
Old Oct 23, 2012, 11:06 PM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Build Log
Auto flipping - getting your quad to do a 360 flipover in full flight
Here are the relevant topics
MWII - http://www.multiwii.com/forum/viewto...tart=10#p17758
Mutiwii have it solved by either programming a T9x or by adding a bit of code the the .ino code to make Acro mode more manageable. Changing the Rates ( "RC Rate to 1.0 and my Pitch/Roll rate to 0.7") will allow you to freely flip and roll as you see fit but it's extremely hard to fly normally. In the above solution the quad switches to LEVEL mode if the sticks are near centre.
MPNG - http://code.google.com/p/arducopter/wiki/AC2_SimpleMode
Flipping is preprogrammed and can be accessed via ch7 and changing the settings in the mission planner.
The difference between the two is mainly that MWII allows you to flip in any direction for any duration or sequence. MPNG just activates a 1 flip on the roll axis using a switch on your Tx and direction or duration cannot be changed, ie a slow flip forward is not possible.
RHTizzy is offline Find More Posts by RHTizzy
