Old Dec 05, 2003, 01:51 PM
BillBrian is offline
Find More Posts by BillBrian
Joined Dec 2003
Question
Power Supplies for Testing Electric Motors in a Test Stand
I am designing an aircraft and want to test the motor and craft's stability, thrust, etc., in a test stand and power the motor with a tethered power supply so that I don't have to worry about recharging the batteries while I configure and tweak the assembly. Does anyone have any experiencxe/suggestions for what would work well for a power supply. I was thinking about using 12 volt car batteries or a battery charger to inout into the controller. I would also like to supply 2 electrics. I'm looking to use about two 1/2 hp motors in the craft. Would I be better off using the car batteries or could I bypass the batteries and use the charger supply directly- I would choose a motor that would run effciently with 12 volts each, hence two chargers or two batteries.
Bill Brian
BillBrian is offline Find More Posts by BillBrian
Old Dec 05, 2003, 03:17 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Just off the top of my head, I think it would be hard to find (and expensive to get) a dedicated DC power supply which could provide a current in excess of 30A [and you'd need two of them] - I have a RadioShack 13.8V/10A supply, but the largest I've seen in our store was only 15A. Big deep cycle marine 12V batteries should do the trick.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 05, 2003, 03:37 PM
Joined Dec 2003
Thanks Phil,
I have found 30 amp battery chargers on sale for $59.99. They are the kind on wheels that you get from an auto store. I don't know why they wouldn't work? Do you?
Bill
Old Dec 05, 2003, 03:52 PM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Chargers don't supply DC, only rectified AC. They may work if you get them to charge an auto battery, and take the power from the battery. This limits you to 12V - Ie 10 cell NiMH flight packs.
But I'm afraid you are using a hammer to crack as nut. Running motors for more than a few seconds on a bench is likely to overheat them, and your flight battery should be more than enough for that. If you want to measure static thrust you can do that in a few seconds, but most modellers find it a waste of time as it doesn't give info at flying speed (except for hoverers).
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Dec 05, 2003, 04:16 PM
Joined Dec 2003
Yes, hovering is the application and we need time to test. We don't expect to run it at full throttle very long, but we hate the thought of changing out batteries--and we may not have enough thrust to lift batteries and everything else until we scale up the model. We are experimenting and want to keep our costs down in the early concept testing stages. Tethering simplifies--sounds like we need to use batteries and limit the amperage to keep the motors from overheating???
Old Dec 05, 2003, 04:43 PM
newracer is offline
Find More Posts by newracer
Addicted to R/C
Fort Collins, Colorado
Joined Nov 2003
I have an Astron 50 amp supply but it was expensive. There is another thread about this.
newracer is offline Find More Posts by newracer
Old Dec 05, 2003, 07:20 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
With a cheap trickle charger and a decent car battery you can run your motors for "a short time" no problem. You could even leave the battery in the car (really cheap) if you had enough lead.
Use your instrumentation to measure Watts/Amps input and stop after a few seconds to take temps. "Sneak up" on your test points carefully and you can avoid letting the smoke out.
Be careful. Yesterday while running up a 110W system, I noticed sudden quietness and simultaneous lightness of the new plane I was holding. A quick look around revealed my homemade mount failed and the motor/gearbox/prop/esc were about 10ft away. It happened instantly. One moment running at 110W the next all quiet. No damage to people (glad I was outside) or plane. I was embarrassed about the failure though. Next generation will be way overbuilt. I hope.
feathermerchant is offline Find More Posts by feathermerchant
Old Dec 07, 2003, 04:48 PM
Cuda is offline
Find More Posts by Cuda
Detroit Rocks
Cuda's Avatar
Motor City. USA
Joined Dec 2002
Bill. The astron power supply is a fine unit. I run one on my Ham Radio Station and it will deliver 35 Amps all day. If you want a lower cost power source I wound get a deep cycle battery. I have a small deep cycle golf cart battery in my field box and I have never ran it down at the flying field charging my batteries at 6 amp. The only draw back with a deel cycle battery is they need to be charged wtih a special 1.5 amp charger if you want it to last for years and they are heavy. Hope this helps.
Cuda is offline Find More Posts by Cuda
Old Dec 07, 2003, 05:02 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
They're pricey, but something like this would be ideal.
Variable V output, up to 28A.
http://www.bkprecision.com/www/np_specs.asp?m=1690
William A is offline Find More Posts by William A
Old Dec 07, 2003, 09:26 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The point that was raised earlier, but appears to have been overlooked, is that you should not run a power system on a test stand or similar for more than a few seconds. This is the quickest way to overheat and destroy electric propulsion system components. There's no amount of "tweaking" that requires a power system to be run for more than a few seconds at a time.
..a
Old Dec 08, 2003, 12:10 AM
Speed-3 is offline
Find More Posts by Speed-3
Speed-3's Avatar
cow town
Joined Jun 2003
Re: Power Supplies for Testing Electric Motors in a Test Stand
ASTRON Makes some power supplys that we use to test all our speed controls 0~18 V 0~100 AMPs
Do a web search for astron power supplys
Ken
Bill Brian
Speed-3 is offline Find More Posts by Speed-3
Old Dec 08, 2003, 07:13 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I use a low Tec. approach to testing. I test the amperage with a watt meter, then hold the plane up, give it full power and ask myself "will this fly".
If it will go up if I let go, then it will hover.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Data test data for MVVS electric motors Nico Peursum Power Systems 6 Apr 03, 2007 01:12 PM
Need power supply for testing motors mgdon Batteries and Chargers 8 Aug 20, 2004 04:14 PM
Ezoners at Old Warden for Vintage and Electric Fly In on May 25/26? Thomas B Electric Plane Talk 0 Apr 15, 2002 06:42 PM
Website for Johnson electric motors?? Bleriot Electric Plane Talk 3 Jun 26, 2001 06:58 PM
Computer Power Supplies for charging? RC_Newbiee Power Systems 4 Jun 12, 2001 07:57 AM
