Old Dec 05, 2003, 12:25 PM
nugulator is offline
Find More Posts by nugulator
Joined Oct 2003
how come the lithium cut off points are different on different speed controls?
i have a pixie 7 and the 2 cell cut off is 4.7 volts...my friend has a pixie 20 and his is at 6 volts.
why is there a difference
nugulator is offline Find More Posts by nugulator
Old Dec 05, 2003, 01:06 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
I think the pixie is programmable for different cut offs...
Lithiums can't be discharged past 3v per cell, if it goes below 3v per cell (6v for 2s, 9 for 3s) permanent damage can be done to the cell...
Phreakish is offline Find More Posts by Phreakish
Old Dec 05, 2003, 06:16 PM
Joined Oct 2003
it is programable for different cut offs...its just that...their recomendation is 4.7 volts for 2 cell lithium on the pixie 7 and 6.0 volts which to me is correct on the pixie 20.
Old Dec 06, 2003, 04:02 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
This has nothing to do with Radios so I'll move it to Power Systems where it may get more attention.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Dec 06, 2003, 09:08 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The factory set LVC's are 4.7V for the older, non-programmable Pixie 20 and for the Pixie 7P, and 5.0V for the Pixie 20P.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 06, 2003, 09:14 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Sorry, I forgot to mention that I've had correspondence with Castle Creations over the peculiar 4.7V recommendation for the Pixie 7P and they admitted that it was an error and that they would correct it to 6V [matching the info for the Pixie 20P] in their new instruction sheets. You may get away with 5V for 2s, but obviopusly you need 8V minimum if you are using 3s.
Cheers, Phil
Old Dec 08, 2003, 01:24 PM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Re: how come the lithium cut off points are different on different speed controls?
I'll tell you why there's a difference: There is no hard-and-fast law that says 3.0 Volts per cell is the cutoff for LiPolys. Right now, it's the general consensus that 3.0 Volts per cell should be the cutoff for LiPolys.
mkirsch1 is offline Find More Posts by mkirsch1
Old Dec 11, 2003, 10:10 AM
Joined Oct 2003
got ya
thanks alot man
i set it at the 6.0 cutoff
Help! How do I set the dischage cut off voltage on my Ripmax Pro-Peak Prodigy II charger? sl33pdirt Batteries and Chargers 6 May 21, 2007 03:11 AM
Discussion Lithium cut off voltage For Hyperion ESC? gpang788 Power Systems 4 Apr 28, 2007 02:05 PM
Discussion How come most bluecor/depron wings are built w/out an airfoil? airdawg Foamies (Kits) 7 May 26, 2006 06:58 AM
Discussion how to change low volt cut off on hackerx30 yodie001 Power Systems 1 Feb 01, 2006 09:55 PM
How to discharge Li-ion on Orbit with right cut-off? juantrinidad Batteries and Chargers 2 Nov 14, 2002 09:54 PM
