This thread is privately moderated by JavaScript, who may elect to delete unwanted replies.
Old Oct 23, 2012, 09:26 AM
JavaScript is offline
Find More Posts by JavaScript
JavaScript's Avatar
DFW Texas
Joined Feb 2010
Modifications to the Drastik Big Stick
Been flying my TexasRCPlanes electric 66" Drastik for a while now...
Couple issues:
1. landing speed - I cannot seem to slow this plane down when there is no wind. I have added flaparon mix to the the radio and dial that in before turning base. It adds some flaps and up elevator. - HELPED HUGE! made landings slick. I used the slider on the radio to be able to adjust how much is used.
2. Prop ground clearance when landing gear flex. - I normally have carbon fiber landing gear that do not flex all that much. This plane has aluminum landing gear that flex pretty good and caused me to strike the prop if not careful.
Solution was to build spring struts for the front landing gear. (pics enclosed)
And increased the wheels from 2" to 3"
A fellow club member helped me with this.. it took piano wire and 2 compression springs.
We measured the wire and made 4 pieces that were log enough to get around the axle and back to half way up the landing gear.
In my case the landing gear was 14 inches from the mounting bolt to the axle.
Then using a torch we heated and bent the wire the diameter of the axle and the mounting bolt. Making 4 U shaped pieces with small hooks at the end. Put those into the springs then attached to the plane and covered the springs with heat shrink.
What a difference. This took almost all the bounce out of the landing gear.
JavaScript is offline Find More Posts by JavaScript
Old Oct 23, 2012, 04:33 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Would have been nice to see your mod b4 the heat shrink was added
Weed89 is offline Find More Posts by Weed89
Old Oct 23, 2012, 06:14 PM
JavaScript's Avatar
DFW Texas
Joined Feb 2010
That can be arranged.
Old Oct 23, 2012, 06:50 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
Thanks..I Love Landing gear mods ...
Discussion Wright Stick Modification tom1968 Sport Planes 2 Sep 03, 2012 07:03 PM
Build Log Big slow stick-esque plane derk Foamies (Scratchbuilt) 15 Apr 23, 2012 11:18 PM
Sold Great planes big stick 60 ROBERT.S Aircraft - Fuel - Airplanes (FS/W) 1 Apr 21, 2012 03:06 PM
Sold Bud Nosen A&A Kits For Sale! Citrabia, Trainer $200.00 ea. Giant Big Stick $175.00 stevster Aircraft - Fuel - Airplanes (FS/W) 4 Apr 07, 2012 08:40 PM
Wanted GP Giant Big Stick BT00561 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 29, 2012 01:06 AM
