Old Oct 23, 2012, 08:33 AM
confused UK is offline
Find More Posts by confused UK
United Kingdom, Constantine
Joined May 2010
Build Log
Chris Craft 63' Motor Yacht scratch build in UK
GREETINGS FROM ENGLAND!
Hi. Let me begin by apologizing for the length of this opening episode. I was already well in to my build before being persuaded to start a log.
Although there is at least one other very worthy on-going Chris*Craft 63' Motor Yacht build log on this forum, I have been 'encouraged' by several members to post one of my own. I am not an experienced modeller and this is only my third ever project, but I have a lonely passion here in the UK for Chris*Craft wooden boats, for which I blame Henry Fonda and his 'Thayer IV' CC Sportsman Utility that featured in the movie 'On Golden Pond' #see pic #1#.
Having made a fairly reasonable job of the Dumas 1941 CC 16' Hydroplane I built in 2010/11 #see pic #2# which turns heads at the lake and goes pretty well, I was hungry for a meaty new project to see me through the coming winter #or winters as it might turn out to be#. I wanted something big, stylish and before the plastic boat era and, after discounting Graupner's Jules Verne retro motor cruiser #see pic #3# because of its ready-made GRP hull #where's the challenge in that?#, I settled on the CC 63' Motor Yacht. I have a great book on Chris*Crafts by Anthony Mollica and Jack Savage #see pic #4# and whilst this particular model isn't pictured, the great photos of other Chris*Craft cruisers of similar vintage really took my fancy #see pic #5#.
So I started looking for copies of the original Sterling 63' Motor Yacht kit from the 1960's on ebay but none seemed to have templates for the actual die-cut parts. Then, by chance, I came across a post from iamplanecrazy2 on this forum who was able to help. With a full set of plans, instructions and a sheet of scans of the original die-cut parts I was ready to start. #see pic #6#
Mistake #1 - thinking it would be better to preserve the sheet of die-cut part scans intact, I had it copied at my local print shop. However, it was only after I had traced and cut out the keel parts and most of the hull formers that I realised the copy wasn't exactly the same size as the original. Consequently my 63' Motor Yacht is about 1% larger than it should be. That's OK as long as I keep remembering throughout the build!
Having gotten used to lite-ply, spruce and expanded foam board construction for my Hydroplane, I was very nervous about building such a large model almost entirely from balsa and did consider using alternative materials at the start. However, wise counsel from other model boat builders #and oldbilgewater in particular# prevailed and I went ahead with balsa. My apprehension was further relieved when I discovered an excellent source #The Balsa Cabin at Maldon, Essex# where they hand-picked sheets for me of harder density that withstand damage but can still be worked easily. I was glad, however, that I had acquired a small Spiralux Shapercraft hobby scroll saw on ebay #see pic #7# which, with preparatory knife-scoring and some practice, achieves a fast and accurate cut of the most intricate shapes.
As I started building the boat before deciding to write this build log I’ve already made all the hull parts and constructed the frame, but not, however, without some problems. #see pics #8-11# Although I traced from the die-cut patterns and cut out the parts very carefully, there were some discrepancies and lining-up issues that required ‘open balsa surgery’ during construction. This was mainly about the position of slots and notches, but also getting the right degree of curve on the assembled chines. I actually had to break and reset them to fit the hull formers. Consequently, there was a lot of cursing, compensating and tidying up to do in order that the finished hull frame was sufficiently smooth and tolerably true, but it was worth the time and effort.
Lastly, before I close this mega first epistle, I took the precaution of treating the entire hull frame with water-thin epoxy resin aka Ronseal wet rot wood hardener #see pic#12#. Turns soft balsa into hard timber and makes it waterproof. Only downside using it at this stage was that further sanding or shaping is much more difficult. If I did it over I would wait until I had skinned and planked the hull sides and bottom #which I will have to treat inside anyway#.
That’s quite enough for now. Next episode will cover fitting the hull skins and planking.
confused UK is offline Find More Posts by confused UK
Old Oct 23, 2012, 09:28 AM
pjesus is offline
Find More Posts by pjesus
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Guess I have one more thread to follow
pjesus is offline Find More Posts by pjesus
Old Oct 23, 2012, 10:01 AM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Welcome !
Excellent !
Quite good to see this started, I am sure it will be a great posting.
The other models you have built look Very good, I am sure this one will be a Winner !
Tim B. is offline Find More Posts by Tim B.
Old Oct 23, 2012, 01:21 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Very nice start to your CC, confused UK! You did a great job with the Hydro too!
Aerominded is offline Find More Posts by Aerominded
Old Oct 24, 2012, 12:23 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
I'm in.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Oct 24, 2012, 03:20 AM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
me too
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Oct 24, 2012, 07:16 AM
Gravman is offline
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Yep, me too
Gravman is offline Find More Posts by Gravman
Old Oct 24, 2012, 10:34 AM
tinknocker is offline
Find More Posts by tinknocker
tinknocker's Avatar
New Jersey
Me also
tinknocker is offline Find More Posts by tinknocker
Old Oct 24, 2012, 11:01 AM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Thats alot of popcorn
P31 is offline Find More Posts by P31
Old Oct 24, 2012, 11:32 AM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Excellent !
Quite an illustrious crowd !
Old Oct 25, 2012, 03:18 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
I'm in; where do I pay?
jeepers1940 is offline Find More Posts by jeepers1940
Old Oct 25, 2012, 05:22 AM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Welcome
PETER : Welcome to the best group of mentors,experts,antagonists,and good guys & girls.
Since our first contact (your PM 5 Sept) your project has been of interest to me .
Obviously,I am interested in Stirling 63 s.,There was more. Your introduction here shows the builder and the person.
Again,welcome and above all enjoy,ask,learn,add your insight so others can learn from you. Oh,and did I say,enjoy?
OBW
oldbilgewater is offline Find More Posts by oldbilgewater
Old Oct 25, 2012, 05:24 AM
Joined Jan 2012
Oh yes, I almost forgot.
Old Oct 25, 2012, 06:48 AM
Joined May 2010
Thanks to all!!!
Well, I am somewhat humbled by the level of interest and kind comments received. I'll do my best to make a reasonable job of the boat.
I'll post something about skinning the hull shortly, but I'm onto the planked sections at the moment. After the almost instant gratfication of achieving a smooth and unblemished hull shape after applying the balsa side skins, the planking always looks a mess but I have to keep reminding myself that it'll be OK (I hope!) when it's all sanded and filled.
Meanwhile, a neat little USPS postal box has arrived from Gary Barnes (www.garysboatyard.com) containing all the metal fittings I'll need - everything from anchors, portholes and hatches to railing stanchion bases and ChrisCraft logos - all cast in bright pewter that should polish up to something approaching chrome. I'll post a photo in due course.
I've also made one other significant transatlantic purchase by ordering a bespoke power and hardware package from Rich Koll (frankg) at M.A.C.K. Products. I could have tried to match the spec by buying similar kit in the UK form various sources and saved some money, but as I've never properly understood how best to match ESCs, motors and props etc I reckoned it was well worth leaving that to an expert. Looking forward to opening the box!
Thanks again for your combined encouragement.
Old Oct 25, 2012, 12:01 PM
P31 is offline
P31
P31
Joined Dec 2011
I will be watching, I also am building a 63' CC, and in the process of a refurb, on a Corvet.
Gary
For Sale Plans and Patterns for Sterling Chris Craft 63' Motor Yacht Kit B-11M iamplanecrazy2 Boats (FS/W) 13 Nov 28, 2015 05:24 PM
Off Site Sterling Chris Craft 63' Motor Yacht w/Fittings Kit papower Boats (FS/W) 3 Jan 24, 2012 12:47 PM
For Sale Built Sterling 63' Chris Craft Motor yacht Hull and plan set. Skipper AM299 Boats (FS/W) 1 Mar 05, 2011 07:23 AM
Question 63' Chris Craft Motor Yacht Kirchnerbrn Scale Boats 2 Jun 18, 2008 04:42 PM
For Sale Vintage Sterling Chris Craft 63' motor yacht model kit lefidler Boats (FS/W) 0 Jun 09, 2007 11:45 AM
