Old Oct 23, 2012, 03:15 AM
romano_st is offline
Find More Posts by romano_st
no way
Croatia, Split-Dalmatia County, Split
Joined Apr 2012
Question
good throttle *servo for 20 cc gasser??
What do you guys think, analog or digital for a throttle servo on a zenoah g20????
romano_st is offline Find More Posts by romano_st
Old Oct 23, 2012, 03:26 AM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
I use Futaba S 3010.... crude, heavy duty servo's that withstand vibration pretty well. Cheap too. they are intended for control surfaces of big scale planes, but do OK here as well.
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Oct 23, 2012, 08:25 AM
WCB is offline
WCB
Find More Posts by WCB
WCB
NC
Joined Aug 2005
analog
WCB is offline Find More Posts by WCB
Old Oct 24, 2012, 03:53 AM
no way
Joined Apr 2012
thanks for reply, so you would use analog, reason why i ask is i have 4 futaba s3151- digital, i was thinking to use one as throttle servo......or maybe no, what is major downside of a digital on throttle?
Old Oct 24, 2012, 05:59 AM
jymz is offline
Find More Posts by jymz
jymz's Avatar
Delaware, Ohio
Joined Nov 2006
No downside to digital. Use what you have.
jymz is offline Find More Posts by jymz
Old Oct 24, 2012, 07:23 AM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
I use what I have as a rule too. Where I pay attention is the geometry, end point adjustments, and smooth interference free motion.
ahicks is online now Find More Posts by ahicks
Old Oct 24, 2012, 08:20 AM
The Netherlands
Joined Nov 2009
The major downside would be unnecessary high power consumption
Which is no big deal, because it is not much anyway....
Still, I would use analog, because I would so for anything that does not require digital, just as a basic rule of thumb....
Brgds, Bert
Old Oct 24, 2012, 08:23 AM
WCB is offline
WCB
WCB
NC
Joined Aug 2005
Originally Posted by WCB View Post
analog
I keep a couple of extra inexpensive standard analog servos just to use on throttle, but in a pinch I would do as suggested by the others...use what you have.
Old Oct 25, 2012, 10:36 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
I've never bothered with a digital on throttle (I'm cheap), and would never use one with metal gears (too much slop), but if you have the S3151's sitting around, use them. On throttle, the difference in current draw between a digital and analog isn't worth worrying about.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 26, 2012, 05:27 PM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
the 3151 is a good choice but a little on the weak side as far as output goes. if you like to still use the throttle return spring you may find that the servo binds at full open.
i like to use the hitec HS-605. its definitely overkill in the torque dept for throttle, but the helical teeth on the output gear are very strong and resist vibration well.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Oct 30, 2012, 05:16 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
A properly set up throttle servo won;t bind at full open with the throttle spring attached. the spring also offers negligable resistance to movement
I think the Futaba S3151 mentioned above is an ideal throttle servo. It has enough power and being digital will allow more fine control of the throttle plate. this would hold true for any good quality digital servo. I chose digital throttle servo's for these reasons.
An analogue like a S3010 r even a S3004 is also fine. Don't sweet the servo choice, just set it up well using the correct geometry and it will last the life of the plane.
TimBle is offline Find More Posts by TimBle
Old Oct 30, 2012, 07:16 AM
rjstrickjr is offline
Find More Posts by rjstrickjr
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
I have used what I had in the past but not anymore. JR Sport ST47BB is what I used alot till they kept breaking gears. I only use a JR821 or Hitec 5485 on throttle and choke from now on. I almost lost my H-9 P-47 twice before I switched over and i have had no problems. Yes it has a DLE20CC on it and it's awsome!
rjstrickjr is offline Find More Posts by rjstrickjr
Old Apr 10, 2016, 04:54 AM
Sacalu is offline
Find More Posts by Sacalu
Romania, HR, Gheorgheni
Joined Sep 2008
Could I use for the throttle and choke of an RCG 20cc mini servos of 12g like the HobbyKing 939MG Servo MG 2.5kg / 0.14sec / 12.5g? https://www.hobbyking.com/hobbyking/...sec_12_5g.html I mostly see in pics of gas engines standard servos for throttle but I might have seen also mini servos, can't remember exactly. The throttle level moves very easily, I don't see why 2,5 - 2,7kg of force won't be enough.
Sacalu is offline Find More Posts by Sacalu
Old Apr 10, 2016, 08:31 AM
Joined Aug 2008
I'm using one on a 3D plane where weight is pretty important, but if you're going to try, I'll warn that set up is something you need to keep a close eye on. End point settings are critical. Set incorrectly the servo will overheat and burn out pretty quickly,
A std. servo would be much more forgiving.
Old Apr 10, 2016, 11:50 AM
ace7938 is offline
Find More Posts by ace7938
ace7938's Avatar
Canada, ON, Newbury
Joined Sep 2014
Hitec HS225mg or if need a little weight HS5625mg...of course I have an old cub with hitec 311 plastic gears that just keeps on going...
ace7938 is offline Find More Posts by ace7938
Found 15 cc Gasser SBP Aircraft - Fuel - Airplanes (FS/W) 0 Aug 28, 2012 12:33 PM
Discussion 30 cc gasser drankuraggarwal Fuel Plane Talk 5 Aug 14, 2012 08:30 AM
Wanted Looking for a DLE 20 cc douglasf30 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 31, 2012 07:50 PM
Question Which Servos for a Gasser? Fokker DII Giant Scale Airplanes 10 May 24, 2012 07:42 PM
Discussion 20 cc gasser on 64" Extra? fyrc22 Fuel Plane Talk 3 Jun 06, 2011 10:38 AM
