Old Oct 22, 2012, 09:01 PM
LCKRC is offline
Find More Posts by LCKRC
Joined Oct 2012
Never done this before
So as the title says i have never made a rc boat before but i had one awhile ago and i loved it.
I do alot of race trucks and crawlers so this is a big change but i live in lake havasu so i need a boat to play with lol.
So i started with a hull i found on craigslist for 20$
i ordered a few parts off ebay and i had a hobby wing 1/8 scale brushless motor and esc that runs off 2 lipos witch i have to chose still.
i am gonna be running a DX2E 2.4 radio with it i still have to clean the electronics up but ill get a pic of them up soon tell me what you think
LCKRC is offline Find More Posts by LCKRC
Old Oct 22, 2012, 10:57 PM
LCKRC is offline
Joined Oct 2012
so i think i might have messed up with buying that rudder
I think i might need a 110mm or so but i made a small paper templet and held it to the boat in the spot i want it looks like it will hit the water at all times even in a hard right but that we will have to see lol
BTW the hull is a fiberglass 31in dont know much about it guy had it sitting and never used it
Old Oct 23, 2012, 08:25 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
If you set it up as a conventional v the rudder should be deeper into the water on a right hand turn than on a left. It should be mounteed about 1.5 - 2" to the right of the transom center line. Ideally you should have the water pickup in the rudder about 1/2" below the bottom of the v.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Oct 23, 2012, 09:27 PM
LCKRC is offline
Joined Oct 2012
i could be looking at it wrong but so far it seems like it will work out how you said i feel stupid but i had to even look up what transom is lol this is a big learning experience
Old Oct 23, 2012, 09:56 PM
LCKRC is offline
Joined Oct 2012
so this is my idea of how to mount my lid tell me what you think of if im going about this all wrong.
I want to have it with 2 body post mounted in the front and back of the lid that just use your basic body pin.
to hold the lid in place and make it some what more water tight.I want to take a wooden dowel or something kinda like a round plastic tube like pic but bigger and put that down around the base so the lid fits snug then i will fiberglass it in place and put a foam or rubber like coating on it for a better fit.
seems like a good way to do it what do you guys think?
Old Oct 24, 2012, 03:00 AM
LCKRC is offline
Joined Oct 2012
i have a question about picking my drive shaft i see things like flex shafts and other things.Do you pick the drive shaft for the boat,the mounting area you want or both.like do i just go flex shaft and also the drive shaft i already have coming with that outrigger does it just screw onto it or is that what goes right to the motor? i have been trying to look but havent had much luck
Old Oct 24, 2012, 04:50 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
What's done is done I guess but... a "stinger" usually works out better on a V hull than a strut does. http://www.offshoreelectrics.com/pro...os-stinger-str
For the size of your boat a .150 or .187 flex with 3/16" stub (prop) shaft is common. The 3/16" size bore is the most common for props. http://www.offshoreelectrics.com/pro...at=Flex+Cables Chances are the strut you posted the photo of only has a 4 mm bore which will limit your prop selection.
Connection to the motor is done with a coupler. These are available in many sizes. One end needs to fit the motor shaft the other the cable of your chosen flex. http://www.offshoreelectrics.com/pro...Motor+Couplers
Coming back to your hatch, (lid) most electric guys use hatch (hockey) tape to secure them. http://www.offshoreelectrics.com/pro...rod=hatch-tape Drilling holes in the hatch and using pins to secure it just gives the water another opening to get inside and kill your electronics.
Old Oct 24, 2012, 01:18 PM
LCKRC is offline
Joined Oct 2012
the main problem im having is the lip so when the hatch sets on the boat it just slides around cause theres not lip for it to set on
i guess i should have looked up a few things before i bought that stuff but it was cheap and i do alot of projects and im sure i can find a way to use it.
i just got a 380 brushless motor setud and i want to find a small boat next maybe a cat hull
Old Oct 24, 2012, 01:33 PM
LCKRC is offline
Joined Oct 2012
what is a stinger? i dont know the difference from what i got to a stinger for this boat im thinking about getting this if my setup i got doesnt work what do you think
Old Oct 24, 2012, 05:11 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
If you go back up to post 7 and click the link at the end of the 1st line it will take you to a stinger on OSE.
Old Oct 24, 2012, 09:14 PM
LCKRC is offline
Joined Oct 2012
i saw it says you can make more changes with the stinger im guessing that is a racing setup? that looks cool but is that the main difference is getting better performance because you are able to change prop angles?
Old Oct 25, 2012, 04:28 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
There are advantages to both struts and stingers. The stinger makes for easy drive angle adjustments on a V hull. The strut makes for easy drive height adustments on cats and hydro type hulls.
To run a strut on a V hull and take advantage of the adjustments you have to have an oversize stuffing tube exit hole and build a wet box inside the hull around the stuffing tube to keep it from flooding the boat.
Old Oct 25, 2012, 06:20 PM
LCKRC is offline
Joined Oct 2012
do you happen to have a pic of what this looks like
Old Oct 25, 2012, 07:44 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
You can find pictures of everything I've mentioned by clicking the links I gave you in the quoted post below. But, if you want some pictures...
Old Oct 25, 2012, 10:01 PM
LCKRC is offline
Joined Oct 2012
im sorry i did a bad post i saw the links i ment of a wet box i am getting more and more info the more i look on here and thank you for helping with stupid questions
Cool Never done before: SPV (SECOND Person View) KevinW (Qwin) Hodges Hobbies All Electric Fly-In (HHAEFI V7) 3 Oct 14, 2012 05:54 PM
Discussion Has this been done before (spectrum receiver in a Nextstar Ep ) rbgordon Beginner Training Area (Aircraft-Electric) 9 Sep 18, 2012 11:46 AM
Question I never built a wing like this before... Broken Wings Vintage & Old-Timer Designs 3 Sep 09, 2012 04:29 PM
Discussion Intellectual idiots - never before this clearly Gooroo Life, The Universe, and Politics 48 Apr 27, 2012 05:33 PM
Discussion Need some advice, never done this before catman529 Free Flight 8 Sep 29, 2007 08:19 AM
