This thread is privately moderated by I R Irv, who may elect to delete unwanted replies.
Old Oct 22, 2012, 05:49 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
R3-e2
My new experiment, It's kind of a Bi-Wing MAV with 3 rudders and 2 elevators. 2mm Depron, 6'' WS and the airframe weighs 4.90 grams. I thermal molded the wings airfoil and dihedral. Planning on using a 6400 with the micro J3 Cubs motor/gearbox and a Hyperion 70mah bat.
I R Irv is offline Find More Posts by I R Irv
Old Oct 25, 2012, 07:16 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Bi-Wing Mav
Interesting project. I will be following progress. Hope to learn more about the molding process.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Oct 28, 2012, 09:20 AM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
The molding is the easy part, making the wood jig was the harder part. To be honest the jig was also easy but I've been doing woodworking for 30yrs.
I drew the airfoil on the ends of 2 boards, rough cut them on a table saw by ripping them at different blade angles close to the airfoil shape. Glued them together and sanded my cuts smooth.
I then made my 4 miter cuts at 9 degrees to give myself a 18 degree Dihedral. Used a sliding power miter saw for this, then glued the 3 pieces together.
MOLDING
Lightly tack the Depron wing to the wood jig, and wrap a thick piece of chair cushion foam with Ace bandages and bake in the oven, 225* for around 40min.
Discussion Donats GEE BEE R3 (hobby lobby R3) sebbe Scale ARF/RTF 3 Nov 14, 2015 07:19 AM
Discussion Gee Bee R3 Starmax (Dymond, Modster) beetyii Foamies (Kits) 17 Nov 26, 2013 11:30 PM
Build Log Semi scale Gee Bee R3 (potensky kit improved) indoor_fr Scratchbuilt Indoor and Micro Models 22 Oct 03, 2012 03:17 AM
Sold Saito R3 90 VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Aug 06, 2012 10:29 PM
Sold Saito 450 R3 zdsh13 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 21, 2012 06:30 AM
