Old Oct 26, 2012, 01:57 PM
CaptLee is offline
Find More Posts by CaptLee
United States, CA, Hayward
Joined Feb 2006
rolex Will take a photo of setup sometime this week as going to add a Dimension Engineering ESC. But it is a bulkhead added with a 6 degree shim bolted to the uprights strengthing leg. The greasing the shafts was cured with a #40 hole drilled in the shaft log and sealed after use with a piece of tape. Would not think WD40 is good for your shaft as it has plastic bushings. LaBelle(Railroad Folks) makes a plastic compatible grease. Get a pair of K1720 props on order from Prop shop if you really want to wake this boat up. 3mm bore with setscrew is the proper shaft dimension.
CaptLee is offline Find More Posts by CaptLee
Old Oct 27, 2012, 08:51 AM
rolex0071 is offline
Find More Posts by rolex0071
IRELAND
Joined Jun 2009
Originally Posted by CaptCB View Post
You want the pushrod in a hole closer in, to the shaft center line, at the rudders. Also, CHECK your rudder arm clearence, VERY closely, as when you increase rudder throw, the steering arms come very close, or can hit, the inside of the hull. But you are headed in the right direction. CaptCB
Thanks - I did check the arms before putting the tug back together and all is working well.
rolex0071 is offline Find More Posts by rolex0071
Old Oct 27, 2012, 08:52 AM
IRELAND
Joined Jun 2009
Sounds excellent looking forward to any info and photo's to help me and others out there, and this is what this tread is about.
WD-40 may not be the best thing to use on shafts but its better dan nothing. - Many Thanks.
Old Oct 28, 2012, 05:58 AM
IRELAND
Joined Jun 2009
The Art of Ageing a model boat.
Here is what i am working on today, adding age to my Tug boat. And i have so much to add over the next few weeks like Nav Lights, and may other parts before i will be happy with the way she looks ! It may not be everyone's Cup of Tea, but a stock model just is not for me.
Old Oct 28, 2012, 08:15 AM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I didn't know that there were "official" mods to an RTR---.
der kapitan is offline Find More Posts by der kapitan
Old Oct 29, 2012, 07:19 AM
IRELAND
Joined Jun 2009
Your right, don't know what i was thinking of, so i re-named the thread again take a look !!!!!
Old Oct 29, 2012, 07:49 AM
IRELAND
Joined Jun 2009
Well i was out on the sea today testing the mods on the rudders that i did on page 2 of this thread and the turning of the boat was just excellent. The only down part was i was getting a lot of water on the back of the main deck, but it was fun to watch.
Old Oct 29, 2012, 11:32 AM
LA Summit is offline
Find More Posts by LA Summit
United States, IL, Naperville
Joined May 2012
Beautiful work!!! how did you do all the weathering?
LA Summit is offline Find More Posts by LA Summit
Old Oct 29, 2012, 01:00 PM
IRELAND
Joined Jun 2009
It has not been easy, i did not use paint, i used power liner permanent markers which is very hard to work with and to mix the colours with each other.
I am still working on the look of my Tug, and it will change more over the next ten weeks or so.
I'm not sure which way to go with her, The "BP" look "SHELL" look or just a work horse from Dublin port.
regards - Rolex.
Old Oct 29, 2012, 04:31 PM
Joined May 2012
Wow, thanks for the 'how to', so for the green deck you smudge the colors for the 'water color' effect... cool.
Old Oct 29, 2012, 05:54 PM
Prins Willem is online now
Find More Posts by Prins Willem
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
Shame you don't have other modelers to run with. The boat would take on a "natural" patina of age, with paint swaps, T bones, scummy water, dirt from sitting on the ground, sun baking, hull scrapes from beaching, etc., etc,. Be surprised how fast it and you will age.
Prins Willem is online now Find More Posts by Prins Willem
Old Oct 30, 2012, 10:15 AM
IRELAND
Joined Jun 2009
The deck was done by using a small bit of nail polish remover and by adding the the colour to the tissue, this makes the colour run on the tissue a little and with this i used the tissue to add the brown colour to the boats deck giving the deck that old used look.
The same was used for the smoke stacks, but NOT for the main cab of the ship. This was done by using 3 pens, Black pen, light brown pen and a dark brown pen.
First a little light brown pen want on, then the dark brown pen and then a little black.
Then you get the dark brown pen and mix all the colours on the cab together.
Done !
Warning: Permanent Markers are unforgiving ! Once on the boat the only way to get then off is with a lot of nail polish remover.
Old Oct 30, 2012, 10:36 AM
IRELAND
Joined Jun 2009
I know what your saying - However, when a was a boy all my model war ships where aged this way only i used paint not pen.
I am a One Model at a Time Man, i was the same with all my models over the years.
She has a number of marks from use already, as for the way she is looking now, Well i still have a lot of work to do before i can say she's "FINISH" and thats seen to be a long way off from where i sitting !
As for yourself, any input to help others is always welcome on this thread.
Many Thanks - Rolex
Old Oct 30, 2012, 11:44 AM
Joined May 2012
Nice, I like the Aquacraft Atlantic's rusty port holes etc... very subtle and realistic.
Old Oct 30, 2012, 01:44 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
very nice job of aging this one. May I sudgest adding some weight band let this one sit a little deeper in the water as this will help slow the roll and keep a little more water off the decks from the rolling motion.
keith S is offline Find More Posts by keith S
Build Log Southampton Tug - Our first boat. Antipodes Scale Boats 15 Feb 18, 2013 07:26 PM
Discussion Hobby Engine 1/36 RC Southampton Tug Boat vs. Aquacraft Atlantic Harbor Tug Boomer1 Scale Boats 228 Oct 24, 2012 11:44 AM
Discussion Which To Buy? Thunder Tiger Fishing Boat Or Southampton Tug? Johnn Dock Talk 9 Dec 04, 2011 04:03 PM
