Old Oct 22, 2012, 01:13 AM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
ESC in New FMS big Pitts
I am having a time setting the ESC in my new Pitts, 85amp ESC w/external BEC. Red wire is disconnected from ESC. First time I hooked it up and bound my AR600 I got a couple beeps and whoop de dooes , it was bound. Next following instructions I unplugged battery, turned on TX with throttle stick at full and plugged battery up and after 2 sec and two beeps went down to min. and ESC did it's thing going thru all the correct things like 6 beeps for 6 cells. Everything in plane worked.m After this I did something different , maybe I got into programming. Now when I plug up all I get is one beep but alls well. What is going on? Servo's work, motor works. Is all good. Scared to fly like this. Lions, tigers and bears, OH!! the Saints won, bag off/////zeezee/dave
zeezee is offline Find More Posts by zeezee
Old Nov 18, 2012, 07:00 PM
carlnoki is offline
Find More Posts by carlnoki
carlnoki's Avatar
United States, VA, Woodbridge
Joined Dec 2010
what ESC is it please?
thanks
carlnoki is offline Find More Posts by carlnoki
Old Nov 18, 2012, 11:35 PM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
If you are running an ESC with no internal Bec, called an opto, you need to rehook the red wire that goes to the rx. If there is no bec built in, there is no power being sent to rx, but the esc requires the red wire for communication and setting the program.
Your separate bec/ battery or separate battery alone will supply the rx its needed power.
If the ESC actually has an internal bec, and you have removed the red wire to run a separate bec, you will need to rehook it to change any settings. Be sure to remove prop and disconnect the separate bec if you rehook the internal. Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
New Product NEW FMS Pitts from BH!!! aviator4934 3D Foamies 1498 Jul 09, 2016 08:17 PM
Sold New Pitts Bi-Plane LPU in DFW birdy233 Aircraft - Electric - Airplanes (FS/W) 11 Jul 10, 2012 05:00 PM
Sold New in nox OS .61 SF ABC w Tatone Pitts muffler/tools dankar04 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 08, 2012 04:11 PM
Sold FMS 65A ESC - New kellymacdaddio Aircraft - Electric - Power Systems (FS/W) 2 May 07, 2012 08:54 PM
Sold New FMS big birds/New PZ T28/bats/parts/charger/Tx &RX cwm333 Non R/C Items (FS/W) 5 Jan 14, 2011 03:55 PM
