Liverpool, England
Joined Jan 2005
Makes our 1" of snow here sound pathetic, the amazing thing is that as a country we just dont cope, everything grinds to a halt, it is unsual for us to get snow though
I wanted to ask how you designed the movement of the gear, I just find it amazing that such a small amount of servo movement results in such an action, did you make some form of mock up? what servos are you using? Fantastic work guys |
Hi Ken: We didn't get the 12" of snow as threatened, and the temp have come back up to a sunny -12C, right balmy!! hehe.
I cannot take credit for the design of the retract system. I used the same locations, rod lengths as drawn on the BT plans, but substituted oleos for the uprights. Original plans shows a single servo used back in '93, using bellcranks to pull the Lg from the same points. I did make a common jig from heavy board, remember I had to make 6 of these LG, 3 sets! I set up and tested each unit on the jig, fine tuning each lock system. Presently we are using HDPower servos, rated for 12kg @6volts (160oz). I believe they where HD1201's, but please let me confirm that, memory is what it is! In a perfect world, I'd use JR791 retract servos at 226ozs, and redo the the attachment arm point to allow 180 degrees. At $70 each, they are out of reach for me and my partners. In testing, I ran the 6 sets all on the same servo, 100's of full cycles, with no failures to date. The servo is accessible, if needed, we can replace the servo with something stronger, like a HD Power 9150mg, rated at 226ozs ($35). Doug B |
If your Mossy already has mechanical retracts, I'd suggest modifying the lower section to a more scale appearance. Without a lathe, milling machine, it would be very difficult to achieve. We had to modify the nacelles too to make this system fit. At 63", your LG would scale out at about 60% of ours. Show me some pics of what you have now, there may be a way. Doug B
And just delay the time they started operating by the amount of time that elapsed while the signal slope reached the point at which the servo was set to recognise that it was being asked to do something? Once woken up it would then operate at its own speed. Seems to me you need exactly what you have - a normal operation servo that will respond to exactly what your Tx is asking. Your world just got a bit more perfect... you didn't waste $70 a throw for the wrong servo! ![]() Robin |
Owen Sound, ON. Canada
Joined May 2007
I have also included a snow scene for the envious ones in the crowd. Makes for great building weather. Ken |
Doug, Ken,
that second picture above shows the stop.... If you take a look through this thread you can see the mozzie as I build her. The mechanical retracts failed & I replaced them with e-tracts late last year. http://www.rccanada.ca/rccforum/show...ht=BH+mosquito The retracts take a beating because there is no diagonal to take the landing forces and I continually have to bend the music wire strut straight (at least twice a season). |
Liverpool, England
Joined Jan 2005
Its sad that as beautiful as that snow scene is I have still spent longer looking at the other pictures (I need serious help
)Doug I know I should look back through the thread but what did you use to braise/solder/weld the top frame together? Ken |
I have tried in the past to use a Tig, but it tends to destroy the temper in the piano wire. Doug B |
I've looked at your build, honestly don't think you'd be happy trying to get a set like ours in there. The entire wing structure would have to be gutted to the top sheet, all cross ribs removed back to the front of flaps, then all reinforced down the sides with ply to regain its strength. Not sure even then if the nacelles are deep enough. they look shallower than true scale. fwiw Doug B |
| Thread Tools | |
| Discussion Whittle on Sin 6: Envy | MtnGoat | Life, The Universe, and Politics | 9 | Sep 11, 2012 07:30 PM |
| Discussion Formation flying, share your videos! | Castel101 | Foamy EDFs | 66 | Jul 12, 2012 02:39 PM |
| Question Aurora manual in single-page format ? | TJ-DULUTH | Hitec/Multiplex USA | 2 | Mar 07, 2012 03:05 PM |
| Cool 3 Zeroli F9 Panthers fly in formation | PaulDaniel | Fuel Jet Talk | 1 | Mar 06, 2012 06:30 PM |
