Old Oct 21, 2012, 04:18 PM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
Balsarite substitute??
Just ordered some Coverite (aka Litespan) for covering a 1/8 scale Super Cub. Unfortunately, due to shipping restrictions, I was unable to have Tower ship the Balsarite adhesive to me - it's flammable so it can't be shipped via air, and I live in Alaska so that's the only option.
I've heard you can thin out some of the Aliphatic glues with water and that will work but is there a commercial product that will work as well?
bdshort is offline Find More Posts by bdshort
Old Oct 22, 2012, 06:13 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I quit using Balsarite a few years back. I've been using Aquanet hairspray as a substitute. Just spray on a coat and let it dry (15min). Then iron the film as usual.
TomCrump is offline Find More Posts by TomCrump
Old Oct 22, 2012, 08:18 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
One possibility is white carpenter glue thinned with water. Apply with a brush, let dry, then iron the film as usual.
jkettu is offline Find More Posts by jkettu
Old Oct 31, 2012, 09:14 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
What would you use with fabric that has no adhesive on it?
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: I looked and I looked and I...
Old Oct 31, 2012, 09:29 PM
bdshort is offline
Joined Mar 2008
Just to let everyone know, I'm using ModPodge thinned with water, as well as a glue stick to help position pieces.
Old Nov 07, 2012, 10:58 AM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
My LHS couldn't get the Balsarite because of shipping restrictions, but for some reason they can get SIG Stix-It. (Perhaps because it is in a metal can????)
SIG is very proud of it (as in it is $$$$) but it worked very well on the Coverite 21st Century Fabric I used as the decking material for an RC sailboat. It looks and smells like rubber cement- dries clear in about 30 min and heat activates with your covering iron.
The Stix-It is on the SIG website under "Glues" rather than in "Coverings". The 8 oz can is product code SIGSX001.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Nov 12, 2012, 11:18 AM
kw_counter is offline
Find More Posts by kw_counter
United States, CA, Hidden Valley Lake
Joined Aug 2002
I used the SIG Stix-It on my last covering.
My goal is to keep the covering on around the engine area.
Not very many flights but it seems to be doing a good job so far.
If they'll ship it to CA I'm sure you can get it in Alaska.
Good Luck,
KW_Counter
kw_counter is offline Find More Posts by kw_counter
Old Nov 12, 2012, 08:33 PM
Top_Gunn is offline
Find More Posts by Top_Gunn
Joined May 2010
Another endorsement of Stix-It. I've used it both with Sig Koverall, which has no adhesive, and in place of Balsarite with 21st Century fabric. One thing that might be a concern about using it with Litespan, though, is weight. (I'm just raising the issue: don't know about relative weights of Stix-It and Balsarite.)
Top_Gunn is offline Find More Posts by Top_Gunn
Old Feb 25, 2014, 02:16 PM
fgroza is offline
Find More Posts by fgroza
USA, OH, cambridge
Joined Sep 2001
Don't forget to lightly sand the wood after the Balsarite or whatever you use to smooth out the grain that has raised .
fgroza is offline Find More Posts by fgroza
Old Sep 11, 2015, 09:54 AM
cessna180 is offline
Find More Posts by cessna180
Canada, ON, Brownsville
Joined Nov 2013
On iron fabric I use POLY TAC. It is a STITS product used on full size aircraft,available from Aircraft Spruce. On models covered with Coverall or Dacron or other fabric I use BUTERATE DOPE thinned with thinner. The advantage of using dope when covering with fabrics is that it can be released with thinner and repositioned but for example if you use WB Uretane it cannot be released when dry.
Michael
cessna180 is offline Find More Posts by cessna180
Old Sep 22, 2015, 06:51 AM
Jeffrey L. Davis is offline
Find More Posts by Jeffrey L. Davis
Joined Sep 2015
The hair spray makes sense as it has a good bit of lacquer in it.
Jeffrey L. Davis is offline Find More Posts by Jeffrey L. Davis
Help! Ferrite ring substitute ? Axefly Power Systems 4 May 26, 2012 04:39 PM
Question Folding Prop Substitution for Fixed - Questions Gemini2 Power Systems 2 May 09, 2012 08:40 AM
Discussion Eflite Apprentice Battery Substitutes swimman Batteries and Chargers 2 Mar 10, 2012 11:54 AM
