Old Nov 03, 2012, 10:00 AM
Bart10 is offline
Find More Posts by Bart10
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
Originally Posted by A.T. View Post
Depends upon your definition of normal.
Do You suggest that my ESC can be damaged? Sorry for stupid questions. At the first time I bound point-blank connected Li-pol pack. In the near future, I will bind it using Alkaline cells.
Bart10 is offline Find More Posts by Bart10
Old Nov 03, 2012, 01:34 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Not at all, that is just one example of the many issues which occur when trying to bind using an ESC/BEC
(with or without servo connected).
This especially the first time an ESC is used and is still in the process of setting it's own internal program.
Power can pass to the servo driving them silly before any power has reached and appropriate control
signal returned from the receiver.
This is very well explained as provided previously:
. Servo Wag & Jerky Servo Movements
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Nov 03, 2012, 03:40 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thanks again. Some time ago I have a similar situation in my another model when I have an Optima 7. I use SPC port that. I have set fail safe in neutral positions and when I have turned off the TX (I could change the trimmer a little), servo move a little in one direction and then in the other (immediately after I have turned off TX). I have set fail safe again and to date everything has been OK. Is it normal? It could predicted that servo has moved immediately but I don't think so.
Old Sep 23, 2014, 10:37 AM
griesel is offline
Find More Posts by griesel
Joined Sep 2006
Minima 6
I have more than a dozen Minima 6T's and Minima 6E's. They are wonderful except
they seem to loose their bind quite often if not powered. What is the spec on
bind retention without power?
griesel is offline Find More Posts by griesel
Old Oct 03, 2014, 10:31 AM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
You should never lose the bind unless you accidentally go into the scan function with the transmitter/module. This typically happens if you hold the button down too long when attempting to perform a range check.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Found Hitec Minima 6 channel Receiver davew478 Aircraft - General - Radio Equipment (FS/W) 0 Jun 01, 2012 12:10 AM
Sold Hitec Minima 2.4ghz 6 Channel receiver mpotter187 Aircraft - General - Radio Equipment (FS/W) 5 May 06, 2012 06:24 PM
Question Minima 6 binding problem--please help! Bob Brown Hitec/Multiplex USA 2 Mar 19, 2012 07:08 AM
Wanted Hitec Minima 6 RX YellowJacketsRC Aircraft - General - Radio Equipment (FS/W) 4 Mar 14, 2012 09:32 AM
Discussion Optima 6 or Minima 6 2.4 Antenna Installation Ron Kay Hitec/Multiplex USA 3 Nov 16, 2011 09:00 PM
