Old Oct 21, 2012, 11:46 AM
Bart10 is offline
Find More Posts by Bart10
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
Help!
Minima 6- questions
Hello!
Can somebody tell me, what is real weight of Minima 6E or Minima 6T with cover and without it? It's very important for me. Please help.
Bart10 is offline Find More Posts by Bart10
Old Oct 21, 2012, 01:54 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Hitec Minima - Weight with and without case
Originally Posted by Bart10 View Post
Hello!
. Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E, 6T & 6L Lite Micro Receivers...
.. Minima are compatible only with Spectra Module V3.01 or higher. Caseless Weights for 6 & 7ch Optima Transceivers.
extract:
"Minima 6E/6T Micro Receivers. ("E"nd and "T"op connectors as pictured below). these weigh 6g with the case and 4g without."
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Oct 21, 2012, 02:29 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thank You very much.
Old Oct 23, 2012, 10:03 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
I have a new question. What is a range od Minima 6?
Old Oct 23, 2012, 01:15 PM
A.T. is offline
Joined Aug 2002
Optima 6, 7 & 9 Transceivers & Minima Receiver - Operating Range
Same as an Optima transceiver as just answered to furtherest range last night on another forum, quote:
"Furtherest reported to date has been over 3 miles over ground (5km+), so allow further in the air as outlined under.
. Optima RX - Installation RX, BODA Antenna FAQ, Volts & Range Test.
extract:
. Optima Transceivers - Operating Range
includes:
"11Dec10 added:
Range of Aurora Telemetry System with standard Antenna:
The Hitec AFHSS 2.4Ghz system on the ground has been tested to 3 miles+
so at 5280' per mile, that's over 15000' which is well beyond visual range.- Mike."
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Old Oct 23, 2012, 02:15 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thx for reply but I can't find info about Minima's (not Optima) range (?).
Old Oct 23, 2012, 02:18 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Same as Optima.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Oct 23, 2012, 02:20 PM
A.T. is offline
Joined Aug 2002
As in post #5:
"Same as an Optima transceiver as just answered to furtherest range last night on another forum,"
Read "Minima" in place of "Optima", relating to range, within the linked post.
Alan T.
Old Oct 23, 2012, 03:09 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Oh, yeah. Now, I can see. Thank You very much.
Old Nov 01, 2012, 03:44 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
I received my Minima on Monday (unfortunately it's secon hand one). Today, I connected battery to this RX and I looked that LEDs blinked, motor didn't seem beeps and my cheap servos were jump about every second (one tooth per second).
Second problem is that I have wanted to try, what happen when I turn off my TX. Probably nothing has happened but when I have turned on the TX again, rudder's servo moved a little. After that I have set a fail safe and now everything is OK (when I turn on TX [for test, of course], servos don't move). Is this normal? Where was the problem? I use cheap (blue) servos.
Note: I have done more tests but before I had done it, I had changed an aileron's trimmer. When I have turned off my TX first time, aileron's servo has moved a little after a few second, as ussually. But in senond time (probably second, I'm not sure), the aileron's servo has moved immediately after turning off the transmitter and when I have turned it on again, servo has gotten a big, fast movement. Where are problems?
Old Nov 02, 2012, 06:19 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
It sounds like the BEC is not providing enough power.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Nov 03, 2012, 12:24 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thx for reply but BEC can't be broken. I had used it before I got the Minima and everything had been normal. I remembered that Minima probably showed both blue and red LED on a moment, when servo got a big, fast movement. As I said before, these strange situations happened when I turned on or off my TX. How can I reset my Minima 6 or what can help me?
Old Nov 03, 2012, 01:51 AM
A.T. is offline
Joined Aug 2002
Mike is quite right in that many ESC/BEC do fail under the demands of poor quality servos as provided previously:
. Electronic Speed Control - Why BEC and LVC cause most EP RX problems.
Low cost servo are such because they use low cost (= high drain) motors to keep price down:
. Servo - FAQ : Which servo to buy - Peak Servo Current Test Results.
With regard to rebinding your Minima, refer to the brief instructions and pictures at:
. Hitec AFHSS ID-Setup (Bind) Latest Spectra Module V3.01(0) & Transceiver V2.02(0)
Also as previously advised, it is best to disconnect any ESC/BEC and use a separate fully charged
5 cell NiMH/NiCD pack or 4 cell battery holder with 4 new Alkaline cells.
This avoids the many problems of poor performing BEC during ID-Setup, especially those you are
using in the low power lightweight ESC range.
Alan T.
Old Nov 03, 2012, 03:32 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
So these problems are quite normal?
Old Nov 03, 2012, 05:39 AM
A.T. is offline
Joined Aug 2002
Depends upon your definition of normal.
Have responded to your many similar posts and PM resulting from your acknowledged use of poor batteries and accessories.
Problems with all RC systems arise when users do not follow instructions nor check that batteries
are fully charged and mix equipment (e.g. servo) with other brand items.
Another Q & A example in past few days:
Faulty 3A BEC could not handle two servo
Minima Jittery servo "YOU ARE CORRECT"!
"I made the tests, disconnected one servo and the other one moved properly and answered my commands.
Connect the other and disconnected the other one and, perfect, right response, no problem" - Faulty ESC/BEC.
typical response from Futaba:
Other Brand Compatibility
"If a piece of non-Futaba equipment does not work with a Futaba receiver, it is up to the maker of the non-Futaba equipment
to make changes needed if they want their equipment to be compatible.
There are too many different types of non-Futaba accessories for Futaba to be able to test and check for compatibility."
If you follow the procedure in post #13 without ESC/BEC & servo connected then a good link should be made and servo tested as in example quoted.
Alan T.
Found Hitec Minima 6 channel Receiver davew478 Aircraft - General - Radio Equipment (FS/W) 0 Jun 01, 2012 12:10 AM
Sold Hitec Minima 2.4ghz 6 Channel receiver mpotter187 Aircraft - General - Radio Equipment (FS/W) 5 May 06, 2012 06:24 PM
Question Minima 6 binding problem--please help! Bob Brown Hitec/Multiplex USA 2 Mar 19, 2012 07:08 AM
Wanted Hitec Minima 6 RX YellowJacketsRC Aircraft - General - Radio Equipment (FS/W) 4 Mar 14, 2012 09:32 AM
Discussion Optima 6 or Minima 6 2.4 Antenna Installation Ron Kay Hitec/Multiplex USA 3 Nov 16, 2011 09:00 PM
