Old Oct 21, 2012, 06:53 AM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
Peanuts-Wallnuts RC conversion
Hi guys,
Excuses my poor english but I'm from France.
I'd like to get you advice about my project. I want to fly a RC peanuts or wallnuts.
If peanut, plane will be 3 axis sport plane like ryan St-Sta, miles 18 ....
If wallnuts, plane will be a warbird, 3 axis and retractable gear like this one:
http://www.rcgroups.com/forums/showthread.php?t=1715999
My supplies are the next:
motor:
http://www.hobbyking.com/hobbyking/s...idProduct=9666
Rx: Rx32d
http://www.micronradiocontrol.co.uk/....html#dt_rx32d
Esc: Varbl1
http://www.microplanesolution.com/mps_000008.htm
Servo:
http://www.indoorflyer.co.uk/falcon-...ervo-575-p.asp
battery:
http://www.hobbyking.com/hobbyking/s...Trex_100_.html
My problem are the next:
for peanuts, I can't find a lot of kit. I found that:
miles 18
http://www.a2zcorp.us/store/ProductDetailNP.asp?Cguid={A19AADBD-BFF7-4659-AB1C-1CDCF976D13F}&ProductID=4304&Category=ModelKitsByB rand:Peck
Druine turbulent:
http://www.a2zcorp.us/store/ProductDetailNP.asp?Cguid={A19AADBD-BFF7-4659-AB1C-1CDCF976D13F}&ProductID=4305&Category=ModelKitsByB rand:Peck Polymers
Ryan St
http://www.easybuiltmodels.com/ff39.htm
no more !!
For wallnuts, I'd like to know if my motor is enough and if i have to move to 2s for the battery.
I'm waiting for your advices !
Thank you
ror is offline Find More Posts by ror
Old Oct 21, 2012, 10:16 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
try this battery: http://www.allerc.com/hyperion-g3-cx...or-p-6007.html
hyperions 100 mah 1S. lighter than nano 160 mah, but should last longer.
not many kits, but look up walt mooney. lots of plans.
nemoskull is offline Find More Posts by nemoskull
Old Oct 21, 2012, 10:21 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Some nice Peanut plans here:
http://peanut.scale.free.fr/index.htm
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 21, 2012, 11:12 AM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
There is few kits for Peanut & Walnut scale but many plans around intended for indoor free flight. Most can be made r/c without problems! For the equipment its a bit more difficult, Peanut are mostly the domain of actuator control(even the Falcon "Fetmo" is too big for them).
You already know about MPS, but there is also the excellent MicroInvent line and off course Plantraco:
http://www.microinvent.com/mambo/index.php
http://www.atomicworkshop.co.uk/catalog/
http://www.microflight.be/fike-e
http://www.microflight.com/
For plans only there is many here too:
http://www.houseoffrog.co.uk/
http://www.outerzone.co.uk/index.asp
http://www.parmodels.com/
http://www.aeronutz.flyer.co.uk/
coriolan is offline Find More Posts by coriolan
Old Oct 21, 2012, 02:09 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Tim Wolff is offline Find More Posts by Tim Wolff
Old Oct 21, 2012, 03:06 PM
ror is offline
ror
ror
Joined Aug 2009
Ok, thank you guys for answering, but I knew almost all of these sites. So I understand, if I want to fly a peanuts, I have to take actuators instead servo ant take the hyperion too. For the motor, I think is good because I used it briefly on plane about 30gr, andhe flew well.
So if I have to take actuators, which one I've to take because I've been told that it was difficult to use and put in place.
Thank
Old Oct 21, 2012, 03:38 PM
ror is offline
ror
ror
Joined Aug 2009
An other question:
Do servo falcon 0,8 Gr are enough for a Wallnut ? And, am I obliged to take 2S fo wallnut ? Because, there is this motor at micro plane solution Bl1 mps 43
http://www.microplanesolution.com/mps_000004.htm
is it good ?
thank
Old Oct 21, 2012, 03:52 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Actuators aren't that difficult to install, just very fragile because of the small wires! They are the only choice when you get down to less than 10<15 grams planes on one cell(Lipo). Brushless motors are OK but for very small stuff brushed are actually better(geared 4mm coreless), another good source in Europe beside MPS is DIDEL in Switzerland:
http://www.didel.com/NewsF.html
And there is lot of info in the sticky on top of that page about the subject:
http://www.rcgroups.com/forums/showthread.php?t=84771
http://www.didel.com/vole/Vole.pdf
Old Oct 21, 2012, 04:27 PM
ror is offline
ror
ror
Joined Aug 2009
thank
why coreless are better than brushless ? Can I get a good trhust with it, in order to do loop or somme aerobatics ?
20-22 Gr for peanut, is it to heavy ?
Old Oct 21, 2012, 08:23 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by ror View Post
thank
It's not the motors themselves, its the gearing. Small diameter motors make less torque than large diameter motors, but a small diameter motor, spinning at high RPM, can be geared to make more torque than a larger diameter, heavier motor.
If a brushless motor were geared, it would make more thrust for the same weight/power than brushed, but ungeared brushed is more efficient.
A 6mm Parkzone J-3 Cub motor/.gearbox wih a 4" prop is a very light/powerful setup for a 20-30g plane
UNGN is offline Find More Posts by UNGN
Old Oct 21, 2012, 10:27 PM
nemoskull's Avatar
Joined Sep 2009
plus, not many motorss below the 2 gram range. there is the AP-02 and the HXt 2 gram motor. and thats it, unless you 'roll your own'.
ive had coreless be more efficent than some of the BL motors i used. probly better made.
Old Oct 21, 2012, 10:31 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Gordon Johnson has some nice tests on his site for brushless and coreless motors, also some actuators test:
http://home.comcast.net/~gordon-johnson/home.htm
Old Oct 22, 2012, 02:25 AM
ror is offline
ror
ror
Joined Aug 2009
Ok, thanks very much.
So I forget the brushless and will take a PZ motor. For the site of gordon johnson, I knew it, but I have forget to compare between brushless and coreless !!
Old Oct 22, 2012, 11:12 AM
nemoskull's Avatar
Joined Sep 2009
burshless = more power, longer lasting.
coreless = cheaper, eaiser.
if your plane weighs more than 20 grams go brushless. (says the guy who flies brushed!)
Old Oct 22, 2012, 11:48 AM
ror is offline
ror
ror
Joined Aug 2009
thanks,
I hope my plane will be under 20 Gr ! So what motor take because the J3 Parkzone is a 2 Gr motor. For that weight, I prefer take the AP02. Can you recomand me some motors plus gearboxe, less than 2 gr, and enough power for 13-15 Gr.
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 01:41 AM
For Sale MicroInvent PIPIER PA-18 / RC Peanut test3 Aircraft - Electric - Airplanes (FS/W) 0 Jan 17, 2006 02:29 AM
Nybody interested in a peanut scale rc contest? Ryan Archer Scratchbuilt Indoor and Micro Models 25 Feb 18, 2005 01:46 PM
Yippee! RC Demoiselle - Peanut scale Didier Lanot Scratchbuilt Indoor and Micro Models 22 Nov 21, 2004 04:56 PM
Heinkel 100 V8 profile peanut rc del Scratchbuilt Indoor and Micro Models 5 Nov 21, 2004 04:09 AM
