Old Oct 21, 2012, 03:19 AM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
Mini-HowTo
Head tracker for Optic 6 and other radios.
You will need a ppm signal mixer sold at hobbyking and a radio that can supply...
-PPM out
-PPM in
-ground
-power
Then use a rubber band to hold trainer switch. Make sure you power up head tracker and Tx, BEFORE powering rx. If your receiver has a failsafe, set it.
Optic 6 head tracker (0 min 37 sec)
mecevans is offline Find More Posts by mecevans
Old May 02, 2013, 04:24 PM
andybarry is offline
Find More Posts by andybarry
Joined Mar 2012
I just wanted to confirm for any other folks out there that I got this working on a Hitec Laser 6 a few days ago.
My setup:
- Hitec Laser 6
- Fatshark Predator goggles
- Corona Synthesized Dual-Conv Receiver 9Ch 72Mhz
- PPM signal mixer from hobbypartz: http://www.hobbypartz.com/88e-fb12-ppm-mixer.html
... and a bunch of work to get all the signals in the right ports. I'm powering the PPM signal mixer externally (split from the goggle power source).
andybarry is offline Find More Posts by andybarry
Old May 09, 2013, 11:55 AM
BasTijs is offline
Find More Posts by BasTijs
The Netherlands
Joined Jul 2007
Would this also work on an Aurora 9?
BasTijs is offline Find More Posts by BasTijs
Old May 12, 2013, 06:18 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Negative, but is in the new Aurora 9X due end June 2013.
Aurora 9 has two trainer mode settings:
a). All channels are processed from the Master transmitter
(Slave / buddy transmitter must be programmed with same mixes as the Master Tx)
this being the most secure of all Trainer operation methods.
b). Channels 1 to 4 (aileron, elevator, throttle, rudder) can be mixed from A9 and the Student transmitter,
but known FPV require at least six (Heli seven) channels mixed as in (b).
1, 2, 3 & 4 can be used to control Head Tracker but the others can not be used.
1 = pan
2 = tilt
3 = thro
4 = pit
5 = ail
6 = elev
7 = rudd
As an aside ChainLink UHF Long Range System can be used with an A9:
. Telemetry - FPV Chainlink DIY for Aurora 9 Video.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry,
- FAQ, Setups & Tips
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old May 19, 2013, 04:07 AM
BasTijs is offline
The Netherlands
Joined Jul 2007
Thanks, so adding a LRS system would also be an option.
Would it also be possible to hack the aurora and add something like this?http://www.rcgroups.com/forums/showt...1278835&page=8
Or replace one of the switches with plug for a DIY headtracker?
Bas
Old May 19, 2013, 05:30 AM
A.T. is offline
Joined Aug 2002
Bas
Regret we are unable to assist in this instance.
Manufacturers are happy to help resolve matters relating solely to their own products and accessories.
After market accessories must be referred to the individual manufacturer as under:
. After Market Accessories extract
"Hitec RCD cannot assure compatibility with non-Hitec equipment.
There's just too much of it out there for them to be able to test.
It's also not their responsibility to insure such compatibility.
The maker of the non-Hitec equipment must make sure their items are compatible
- if they are making such a claim.
Many times, non Hitec equipment is used with Hitec equipment even when no claims of compatibility
are made by the maker of the non Hitec equipment, yet the modeler expects universal compatibility."
.. A typical corresponding posts from other brand distributors:
Interference - Ignition Noise
"Many electronic companies who make electronic accessories do not test their equipment's RF output
to see if they meet FCC standards and/or if they create excessive RF in any of the active RC Frequencies
world wide. 27, 35, 36, 40, 41, 72, and now 900 and 2.4."
- Mike Greenshields - Product Manager Airtronics - Global Hobby Distributors
"Futaba cannot assure that non-Futaba equipment
is fully-compatible with other items of Futaba equipment.- Bax "
Alan T.
Old Jul 02, 2013, 12:15 PM
Osprey Engineer is offline
Find More Posts by Osprey Engineer
Osprey Engineer's Avatar
Philadelphia, PA
Joined Oct 2005
Having trouble with Optic 6
Having issues getting my head tracker working. Using a Hitec Optic 6 Tx and an Orange DMS2 8ch Rx. as well as the following parts;
Hobby King PPM mixer
http://www.hobbyking.com/hobbyking/s...dproduct=11848
xgy-1000 head track gyro
http://www.hobbyking.com/hobbyking/s...dproduct=10994
FPV Pan and Tilt mount
http://www.hobbyking.com/hobbyking/s...dproduct=12875
Head tracker is plugged into the trainer port with the cables that came with it. I am using channel 7 and 8 on the receiver and I hold the trainer switch. When I first tried this setup it all seemed to work except if the cables moved. Then it would cut out. If the cables didn't move it worked fine. The red light on the mixer wont always stay solid. If i move it around, the light flashes and it stops working. I used a continuity tester and all the wires seem to work fine. Maybe a bad PPM mixer?
With the trainer switch pulled, none of the other Tx controls work. For instance if I have other servos hooked up for elevator and aileron they stop working if the trainer switch is pulled.
So I need some help please.
1) how can I use channel 7and 8 with the trainer switch and still control the other servos for the air craft?
2) Why would the PPM mixer cut out?
Check out the video. This is the behavior I am getting now. Whats up with that?
XGY-1000 Head Tracker and Optic 6 (1 min 12 sec)
Osprey Engineer is offline Find More Posts by Osprey Engineer
Old Jul 02, 2013, 04:23 PM
A.T. is offline
Joined Aug 2002
Check out the video. This is the behavior I am getting now. Whats up with that? Thanks
1. Optic 6 is a six channel Tx thus channels 7 & 8 not available.
2. Head Tracker Units were not available when the Optic 6 was designed.
3. Hitec RCD is very happy to support all Hitec manufactured products, but please refer to:
. After Market Accessories - Leads, Modules & Switches
extract:
Many times, non-Hitec equipment is used with Hitec equipment even when no claims of compatibility
are made by the maker of the non-Hitec equipment, yet the modeler expects universal compatibility." <snip>
(Same answer as advised by other major RC System brands e.g. Futaba)
. Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ
Alan T.
Old Jul 02, 2013, 06:42 PM
Philadelphia, PA
Joined Oct 2005
Thanks Alan.
However it looks as if mecevans and another guy were successful.
Independent of a possible channel 7 and 8, do you know if ch1-6 are supposed to work while the trainer toggle switch is held on?
Other guy
HobbyKing/ XGY 1000 Xgyrocontrol (Head Tracker) Test on the Hitec Optic6 (2 min 37 sec)
Old Jul 02, 2013, 08:41 PM
A.T. is offline
Joined Aug 2002
Thanks Alan.
Other guy
"Independent of a possible channel 7 and 8, do you know if ch1-6 are supposed to work while
Whilst the Trainer Switch is held "On", the Optic 6, like all similar transmitters, acts as a "pass though" for data
from the student transmitter.
i.e. The stick input and mixes from the slave Tx are passed through the Instructor's Tx direct to the rf output.
When Trainer Switch is released, the data stream from slave tx is stopped and data stream from instructors
own stick & mixes is re-connected to the rf output stage.
. Optic 6 Trainer Cord - Post #2 and #6 may assist.
Alan T.
Sold DSM2-DSMX transmitter modules for Hitec Aurora 9/Optic 6/ Eclipse 7/Futaba radios hammer22 Aircraft - General - Radio Equipment (FS/W) 317 Yesterday 02:22 PM
Question Fat Shark Predator - head tracker cables for other TX's? CactusJackSlade FPV Talk 26 Oct 17, 2012 03:20 PM
Sold Futaba 8U radio w/ Frsky and head tracker Blue Collar FPV Equipment (FS/W) 6 Sep 16, 2012 12:57 AM
Sold DSM2-DSMX transmitter modules for Hitec Aurora 9/Optic 6/ Eclipse 7 radios hammer22 Aircraft - General - Radio Equipment (FS/W) 0 Sep 04, 2012 10:39 AM
Sold Natural 6 DOF Head Tracker optical tracking unit for sale Spidious Aircraft - General - Miscellaneous (FS/W) 9 Jan 03, 2012 08:20 PM
