Old Oct 21, 2012, 12:55 AM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
best coating for pcb to stop corrosion
not to sure how this board is still alive but corrosion is getting the best of it, i have heard that deck varnish was the the previous protection on it used by the manufacture, whatever it was it really didn't hold up well. i was thinking of just dipping it that liquid plastic that you can find at most hardware stores for coating tools. just wondering if that would work or is there something better to use
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Oct 21, 2012, 01:47 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
PCB Conformal coating, designed for the job.
http://en.wikipedia.org/wiki/Conformal_coating
srnet is offline Find More Posts by srnet
Old Oct 21, 2012, 01:51 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
I used to spray copper boards after making then with this AISLARCO 2.
I see they have now AISLOARCO 1 as well.
This spray leaves a coating that prevents corrosion is non conductive and allows soldering afterwards.
http://www.cetronic.es/sqlcommerce/d...0003&cPath=807
IceWind is online now Find More Posts by IceWind
Old Oct 21, 2012, 02:10 AM
jeff262 is offline
farmington, mn
Joined Sep 2003
i remember awhile back hearing someone say that Conformal coatings are nothing more then clear enamel spray paint just more expensive..any truth to that? also im not sure the that conformal coating would stick to the the corrosion that has already started.
Old Oct 21, 2012, 03:36 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Depends which type of conformal coating you are referring to. The cheapest of the proper conformal coatings are around the same price as 'clear enamel spray' so why would you not want to use the 'proper' stuff.
There are conformal coatings for specialized purposes that are expensive and very very different to 'clear enamel spray'.
Your free to experiment of course.
Old Oct 21, 2012, 11:05 AM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
Clear Krylon is ok, for pro use Humiseal type 1B73 is better.
For really tough apps, I've spread 5 min epoxy across the bottom of the board,
but good luck doing any repairs after that.
jglenn is offline Find More Posts by jglenn
Old Oct 22, 2012, 03:14 AM
Roguedog is offline
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
Usually a manufacturer will pot with epoxy as it's rather hard to spray on in small quantities.
I would try to find a real conformal coating like the a for mentioned Humiseal type 1B73. The best part of using a conformal coating is under a black lite it will show u where you missed applying it. The 1B73 is Acylic and has it's own remover in case you need to do repairs.
I would not try something not designed for conformal coating use as you could possible short out your circuitry with it. Better safe than sorry.
edit --- I would also clear off all the flux as it looks like it has a ton of it on the circuit board. Could be contributing to the corrosion.
Roguedog is offline Find More Posts by Roguedog
Discussion best rattle can flat clear coat? wollins Painting and Finishing Tips 33 Aug 04, 2013 11:53 AM
Question Best clear coat? DaxFX Foamies (Kits) 4 Aug 02, 2012 10:41 PM
For Sale UV exposure lamp & PCB w/ UV coating CombatWombat Aircraft - General - Miscellaneous (FS/W) 0 May 01, 2011 11:00 AM
Question Good One Stop Shop for all things PCB related? ejaf DIY Electronics 13 Jan 27, 2007 12:08 AM
