Joined Jan 2009
All the bits are here
Finally managed a trip to LHS, and received the motor/ESC ordered from headsuprc. Did a quick little mod to the stock motor mount (pix.) So pretty much everything's on hand to get 'er done.
Maybe overkill, but I'm using ball-joint servo connectors and 0.93" wire all around for the servo linkages. Covering will be Hangar 9 Ultracote dark yellow, maybe with white on certain parts or on underside. Just about ready for covering. |
Joined Jan 2009
Mock ups are useful for discovering little gotchas. This one necessitated a mod. The issue should be obvious. Will it look too weird if I don't make it symmetrical?
(In case it's not obvious: you're looking down the rudder hinge line. Without being cut away, the elevator will interfere with the rudder control horn.) |
