Old Oct 30, 2012, 12:24 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Thanks. I'll take another look at it. I think it needs some support near the vertical bend but maybe something much shorter to reduce any possible binding.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Oct 30, 2012, 04:07 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I always use heatshrink tubing(pre-shrunk) at this size Lee.
NitroCharged is offline Find More Posts by NitroCharged
Old Oct 30, 2012, 08:21 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Wow, have I been busy and traveling, just now catching up and discovering your great build Lee! Very nice progress and design I might say. 35mm should be a great choice for motivation and I love the new curves on the fuselage (no offense Dave!).
Guys great thoughts on the tubing, I'll add a couple I have tried CyA glue tip tubing, canned air extension tube, Carbon fiber tubing (the 2mm OD stuff), and aluminum which is lighter than brass.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Oct 31, 2012, 08:49 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks Fred. Yeah I'm happy with the results so far. When I started sanding the fuselage sides I thought they would just be an experiment, but they came out so nice that they soon became an airframe. I'll be getting fans today. Then I can move forward with gear placement. Maybe a low powered maiden this weekend.
Old Nov 01, 2012, 01:39 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Fitting the fan. I`ve rolled some pre-cured fiberglass sheet to make a front intake extension to fill the gap between the fan and the sanded foam intake ducts. I have it tacked in place but still need to make an efflux tube.
Old Nov 01, 2012, 01:47 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thrust Question
I`ve tested the thrust on 3s (nose down on a gram scale). I`m only showing about 48g of thrust. I`m sure I`m loosing some thrust due to turbulence and drag in the efflux area, but only 1.75oz of installed thrust? My exit dia is 25mm.
Old Nov 01, 2012, 02:24 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
With or without the wing on?
Which speedie are you using? What settings did you program into it?
Old Nov 01, 2012, 08:52 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That's with the wing and intake tube in place, but I also checked it with the wing off and the bell lip only for the intake and got about the same numbers.
The esc is an old one and it may be robbing some power. I have a new Hobbywing 12a that will be here tomorrow. I'll try it and an efflux tube and see if thrust improves any.
Old Nov 01, 2012, 03:38 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Also, what lipo are you using?
Old Nov 01, 2012, 03:50 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I have some new 25c Nanotech 370mah. If those aren't strong enough, I could run it on a large 3s that will hold full voltage to compare numbers.
Old Nov 01, 2012, 04:44 PM
jahel is online now
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
The best lipo I use is the Thunder Power 325mah 65c...
jahel is online now Find More Posts by jahel
Old Nov 01, 2012, 05:48 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Exactly! TP all the way.
Loose the crappotechs. They're no good for high demand edf's.
Old Nov 02, 2012, 09:52 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I'll look around for some TPs
Old Nov 02, 2012, 08:08 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
you did a nice clean job on those intakes !
KCinNC is offline Find More Posts by KCinNC
Old Nov 03, 2012, 02:07 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Thanks. Soft focus help the look lol. But I try.
Sold A-10 Twin 35mm EDF Micro Jet EPO (BNF) glazzies Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Aug 13, 2012 09:17 PM
Sold SOLD - NIB A-10 Twin 35mm EDF Micro Jet EPO (PNF) ross_badger Aircraft - Electric - Airplanes (FS/W) 1 Jul 27, 2012 05:09 PM
Sold MIG-29 twin 35mm EDF Micro Jet BNF ScottTomasello Aircraft - Electric - Jets (FS/W) 1 Mar 26, 2012 08:54 PM
Sold F86 Sabre 35mm EDF Micro Jet EPO (PNF) strangerb43 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Feb 26, 2012 03:43 PM
