Old Jan 16, 2013, 05:58 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Prop out of balance
My prop is out of balance and its causing the rudder to shake about in flight. The hub is drilled off centre and when on a pin the prop comes to rest with the blades horizontal but always the same way . I tried filling the heavy side of the hub and adding tape to the light side to no avail. Any other ideas ?
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 16, 2013, 06:06 AM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Get a new prop! My stock one I couldn't get balanced. I got a couple spares from LHS and they are both perfect.
TurboRacer is offline Find More Posts by TurboRacer
Old Jan 16, 2013, 10:38 AM
UK, Bedworth
Joined Apr 2004
Been experimenting with props as the standard one gives a lot of vibration and the rudder has a resonance at the standard props RPM.
Micro Invent 125 x 75 Mines a bit battered still getting the vibration and resonance from the rudder. but reduced Slight improvement in flight times
Minium 100 x 60 Motor revs much faster so no resonance with the rudder. Model has good performance flying on the wing but less good at high alpha. Better duration at low alpha worse at high.
Anyone else tried other props ?
Terry
Old Jan 16, 2013, 11:54 AM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
Picked up mine on Monday. My new batteries last about 4 minutes each and I'm having the same problem with vibration in my rudder. Will pick up a new prop next time I'm in my LHS and see if that helps.
Belem is offline Find More Posts by Belem
Old Jan 16, 2013, 01:06 PM
UK, Bedworth
Joined Apr 2004
I tried the following without success but it might be worth a try
Put a small piece of sticky tape on one blade , test fly. Did it get better or worse
If worse put tape on other blade and repeat test
If it got better add a bit more tape if it improves add more tape if worse take some off.
Remove prop slide it on a pin , spin it a few times and note where it stops
Mine always stopped with the blades horizontal the same way up. So I started filing the lower edges of the two blades. Didn't make much difference I think the hole is drilled off centre.
Terry
Old Jan 16, 2013, 01:25 PM
TurboRacer's Avatar
Joined Oct 2002
Don't even have to fly to test, just hold on to where the landing gear goes in.. You can feel/see the thing vibrating if it's out of whack. Also check blade tracking, that can make vibrations if uneven..
Old Jan 17, 2013, 03:16 PM
ronaldj is online now
Find More Posts by ronaldj
Winter - Tavares, Florida
Canada, ON, Ottawa
Joined Jan 2012
Originally Posted by coreman View Post
and you can hopefully report back once you get it
Will do. I ordered the props and savers in the links from post #894. The savers are in the mail, but I have been advised that the props are out of stock and there is no known date of when they will be in stock.
I'll have to try to find another source. As I am new to planes does anyone have a url for a good supplier with a large variety of propellers?
I'll see what I can find.
ronaldj is online now Find More Posts by ronaldj
Old Jan 17, 2013, 03:27 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Whats a fair price for a used mini in practically brand new shape with 3 batteries, charger, original box and manual?
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 17, 2013, 03:46 PM
Belem is offline
Foam flogger
Roseville, CA
Joined Apr 2009
BNF or RTF?
Old Jan 17, 2013, 03:57 PM
Joined Sep 2011
Bnf
Old Jan 17, 2013, 05:06 PM
Belem is offline
Foam flogger
Roseville, CA
Joined Apr 2009
If they're stock batteries or better I'd say $80 is fair. You'll lose money on the open box but the batteries should make up for most of it.
Old Jan 18, 2013, 04:39 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
Hey guys, I'm not much of a plane flyer, but I have a UM P-51 and now a Mini Vapor. I was wondering if it makes sense to set rudder->aileron mixing in the TX on the mini vapor so the rudder stick also controls the tail. I was thinking it might make it easier on the brain when swtiching between a 3ch and a 4ch plane.
sideburn is offline Find More Posts by sideburn
Old Jan 18, 2013, 04:58 PM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
I sure find it helpful.
coreman is online now Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Jan 18, 2013, 05:07 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Just remember if you move both the aileron and rudder stick to do a coordinated turn as you would on a 4 channel plane, you will get double the rudder movement as they add together.
jj604 is offline Find More Posts by jj604
Old Jan 18, 2013, 05:44 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I don't, on 3ch with bottom heavy dihedral wings you can almost treat the rudder like an aileron.
airpower is offline Find More Posts by airpower
Wanted I Need a Parkzone (Vapor) DSM2 Rec/ESC/servo "Brick" *** Joe Pierson Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 25, 2012 10:27 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 03, 2012 01:25 PM
