Old Dec 26, 2012, 08:32 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by jasmine2501 View Post
Yes I agree with this, the Mini has much better power to weight ratio. My Vapor is the original too, not the night one... it's three years old and I'm sure the motor is a little tired. Also, on my mini vapor, I had to move the rod for the rudder to the inner hole, as I didn't feel it would turn tight enough. All those little issues add up to a big difference, as well as setup issues.
However, I don't feel that either one requires mods to fly right. You would think Horizon never tests this stuff or follows a design process, the way everybody itches to mod stuff without even flying it first. I don't think Horizon has ever built an aircraft correctly, right?
I usually end up modifying most of my RC aircraft at some point. But the only time I do it before the maiden is if the need has been established. However, I surely don't consider adjusting the CG, changing pushrod positions, swapping props, or experimenting with different batteries to be modding. These things are simply integral parts of the hobby - essential skills that are required, if one wishes to progress beyond the novice stage.
That said - my MV is still stock. I simply maxed the throws & slapped-in a Hyp 70. I will likely raise the rudder so I can increase up-elevator throw as Todd has done, but that's the only mod I'll likely make to this plane. Unless someone comes out with a 'weightless mod'.
Joel
turboparker is online now Find More Posts by turboparker
Old Dec 26, 2012, 08:40 PM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
'weightless mod'
Working n it!
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Dec 26, 2012, 08:45 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Joel, better than that.
The inflated semi-symetrical section stunt/duration wing with Helium filling will be available as an accessory any day now.
Zero height-loss loops or day long flights guaranteed.
John
jj604 is online now Find More Posts by jj604
Old Dec 26, 2012, 09:16 PM
poulsbobill is offline
Find More Posts by poulsbobill
a little kid at heart
poulsbobill's Avatar
Poulsbo, Wa
Joined Sep 2004
Originally Posted by I R Irv View Post
You can always raise the rudder and give yourself some more elevator. This isn't a mod for everyone but it's just what mine needed.
TODD
Todd,
OK!! that would do it. Did you add on to the shaft that goes through the sleeve or did you just raise it and get rid of the play at the bottom where the tubing is?
Bill
poulsbobill is offline Find More Posts by poulsbobill
Old Dec 26, 2012, 11:07 PM
joker24458 is online now
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
John
I would love to see someone do that.........but for now, it's fantasy.
-joker
joker24458 is online now Find More Posts by joker24458
Old Dec 27, 2012, 02:12 AM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Without having to read through this thread, has anyone figured out the esc rating on this thing. Is it 2amps or less than that?
MUTCAKE is offline Find More Posts by MUTCAKE
Old Dec 27, 2012, 08:41 AM
Joined Jul 2009
Originally Posted by RCBABBEL View Post
Working n it!
rc
John
LOL! Reminds me of that absolutely amazing helium-filled 1/22nd-scale A310.
I have yet to find any specs on this brick.
Joel
Old Dec 27, 2012, 08:47 AM
TurboRacer is online now
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
I tried a 70 mah vapor battery last night. Worked well! Good amount of flight time.. Just barely notice the extra weight.. I like it..
So now have seven stock batts and one 70mah... I need a parallel charger real quick. Going to call LHS today and see if they have any .. I doubt it but worth a shot.
TurboRacer is online now Find More Posts by TurboRacer
Old Dec 27, 2012, 09:51 AM
joker24458's Avatar
Joined Mar 2012
Wow, eight batteries total! I only have one......gotta get some more......
-joker
Old Dec 27, 2012, 09:54 AM
TurboRacer's Avatar
Joined Oct 2002
Dude I got it for Christmas and it was torture flying for 5 mins, then waiting 30-40 to fly again!!!
LHS had stockers for $4.50 each
Old Dec 27, 2012, 11:16 AM
joker24458's Avatar
Joined Mar 2012
I will go to my LHS (not so "local" though.....25 mins away ) ASAP to pick up more batteries and some other RC stuff I need. I will get AT LEAST two 30amp batts and two 70amp batts. Also, I need a multi-port charger that can charge the stock batt. Anyone know of one?
-joker
Old Dec 27, 2012, 12:34 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
-joker
I havent used one in ages but I would assume the celectra 4 port would charge them?
3d astronaut is offline Find More Posts by 3d astronaut
Old Dec 27, 2012, 12:44 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
The problem that you run into is the Celectra charges at 300ma which would be 10C for the 30mah battery. I have one and they are great but it would be too much for these tiny batteries. The nice thing about the parallel boards is that charger thinks it is looking at one battery for the combined capacity so 4 30mah batteries looks like a single 120mah which can then charge on a bigger charger without having the C rating go off the scale.
coreman is offline Find More Posts by coreman
Old Dec 27, 2012, 12:48 PM
TurboRacer's Avatar
Joined Oct 2002
I just picked up a 6 port cable at LHS.. I'm still kinda an electric noob .... So if I charge six 30mah batts at the same tim - 6x30 = 180mah, so I should charge at 0.2 amps to get just a little over a 1C charge rate?
Old Dec 27, 2012, 12:54 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
That is correct
Wanted I Need a Parkzone (Vapor) DSM2 Rec/ESC/servo "Brick" *** Joe Pierson Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 25, 2012 10:27 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 03, 2012 01:25 PM
