Old Dec 25, 2012, 07:22 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Lhs, four dollars.
airpower is offline Find More Posts by airpower
Old Dec 25, 2012, 07:24 PM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Ahh, yeah, found another shop online for $3.79 each.. I ordered three to hold me over. Next time I'm at LHS I'll grab a handful!
TurboRacer is offline Find More Posts by TurboRacer
Old Dec 25, 2012, 07:36 PM
joker24458 is online now
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Ok, so I dont really get it........if I use a 160mah batt how would that kill the motor???
-joker
joker24458 is online now Find More Posts by joker24458
Old Dec 25, 2012, 07:45 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by pgoelz View Post
I have to think that at some point the weight will kill the motor as well?
I have a couple 70mAH Hyperions on the way to try but I don't think I want to go much heavier.
A slightly higher pitch prop might also help, but again, at the possible expense of the motor?
Paul
The weight won't kill the battery, it will just cause the plane to fly poorly. Changing the prop might harm the motor. It flies well as designed for what it was designed for.
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Dec 25, 2012, 07:48 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Generally, the bigger the capacity the lower the internal resistance so a higher capacity battery will have a higher voltage under load than a smaller one. If you look at the test graphs I showed earlier, the Hyperion 70mAh delivers about 0.3V more to the motor than the stock 30mAh at the same current drain. In fact it is worse since in practice the 70mAh will deliver more current into a constant load.
Bottom line both the voltage and current go up when you increase the battery size. Each part is not all that much -10% or so - but the combination may increase the power into the motor significantly. That power comes out as mechanical energy (more thrust and revs) but also as more heat dissipated in the motor. This little motor gets pretty hot anyway and so that is not good.
Whether it is a real problem or not can only be told from practical experience of people who fly on bigger batteries for an extended period. It may be not an issue - it may.
-joker
jj604 is online now Find More Posts by jj604
Old Dec 25, 2012, 07:58 PM
joker24458's Avatar
Joined Mar 2012
Ok, so for now I may just stick with the stock batt. Or even 7-10min flights with a 125mah batt. Would that be all right?
-joker
Old Dec 25, 2012, 08:35 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
As Yoga Berra said, "In theory, theory and practice are the same - in practice they ain't."
Go fly it and feel how hot the motor is compared with the stock battery. If it feels about the same, stop worrying. We can over think these things sometimes - me included.
-joker
Old Dec 25, 2012, 08:36 PM
cale10 is online now
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
anyone thought of my jittering servo issue yet?
cale10 is online now Find More Posts by cale10
Old Dec 25, 2012, 08:43 PM
TurboRacer's Avatar
Joined Oct 2002
Cale10, if it's new, just call HH or if gotten from LHS bring it back and get a new one.
Old Dec 25, 2012, 09:03 PM
joker24458's Avatar
Joined Mar 2012
Ok, I did that little experiment, I couldnt tell if the motor was any hotter. I think I will still fly with the 125 but not the 160. BTW I did get it stuck in the Christmas tree, but it was low so I got it down!
-joker
Old Dec 25, 2012, 09:06 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Cale, only one thing matters, does it fly exactly as it should?
Old Dec 25, 2012, 09:11 PM
pgoelz is offline
Find More Posts by pgoelz
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Heat isn't the only issue here. What is also potentially harmful is increased brush wear from the higher available current. Imagine what is going on at the brush-comm interface of those near microscopic brushes.
I have only flown mine with the stock 30mAH batteries. I did try it once on a 160mAH cell and didn't see a major performance increase so I went back to the 30mAH cells. I am going to try the Hyperion 70mAH cells though.... I figure one more gram probably won't hurt too much.
Paul
pgoelz is offline Find More Posts by pgoelz
Old Dec 25, 2012, 09:18 PM
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
yep exactly. just every so often i'll give full up and then center it and it'll jitter a bit. it dosent always do it thoug. i figures it got some dust in it or something.
Old Dec 25, 2012, 09:39 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Got one of these and at first I was nervous that I would not be able to fly it in our family room. However after a few test crashes I was doing circuits in our 16 x16 room. This is just awesome, under a blizzard warning now and looking forward to more flights in the warmth of my family room.
IndyMatt is offline Find More Posts by IndyMatt
Old Dec 25, 2012, 10:02 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Cale get deoxit f, it's as vital with HH as is using a programmable tx.
Wanted I Need a Parkzone (Vapor) DSM2 Rec/ESC/servo "Brick" *** Joe Pierson Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 25, 2012 10:27 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 03, 2012 01:25 PM
