Espritmodel.com Heli Air
Old Oct 21, 2012, 08:43 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The original Vapor Bricks were 3.3g
Then New AR6400 based PKZ 3351 bricks have porked up 3.65g
It would be cool if this was a new, smaller brick that got back to 3.3g
Brushless mode would be cool, too.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Oct 21, 2012, 09:18 PM
Way to many airplanes!
Canada, QC
Joined Oct 2009
Came back to look at the new comments, then looked at the picture again. Missing elevator linkage and horn, and the mylar/film/membrane seem to be glued with a glue gun, not C.A. Not even Parkzone prototype standard in my book. Add lousy color scheme and this should have been posted in April magazine because it does look fishy!
RealGambler is offline Find More Posts by RealGambler
Old Oct 21, 2012, 09:34 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The comparison picture has both elevator and Rudder rods.
The "flying" shot is a typical fake marketing photo overlay. They could have easily photoshopped out the elevator rod by mistake.
Old Oct 21, 2012, 10:01 PM
Canada, QC
Joined Oct 2009
And the horn? The rod is easy to remove by mistake, but to remove the horn, it cannot be an accident...
Anyway, we will see soon enough. Would like it to be sooner than later though, because winter is slowly kicking in here!
Old Oct 21, 2012, 10:11 PM
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I noticed the missing rudder control rod too.
Personally I doubt it's possible to drop the weight from 15g to 9.5g mostly with a lighter motor and battery. I'm not sure the rest of the weight reduction can come from the airframe. But, you never it might be possible. However, I suspect it's a combination of lighter motor/gearbox/prop/battery + lighter airframe + brick lighter than 3.3g in the original Vapor. How much lighter? Only a bit. One way would be to go to servo motors smaller than 4mm diameter.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Oct 21, 2012, 10:12 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
could this be the ultra light, slow tight indoor flyer we've always wanted?
I know there is the carbon butterfly, but something that is spectrum would be fun as well
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 21, 2012, 10:13 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I'm confident the 8.6gweight is without battery.
3.3g for brick +3g for motor/gearbox/prop would leave no room for an airframe with wheels if a 2.5g battery was included.
Old Oct 21, 2012, 10:17 PM
Sleeps on Clouds
airpower's Avatar
Joined May 2007
Any thoughts on what the pricing will be?
airpower is online now Find More Posts by airpower
Old Oct 22, 2012, 05:26 AM
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
I think it's real thing that got killed for whatever reason, perhaps it was found it would eat into the Night Vapor market, thus competing with itself for no real benefit.
Agree with UNGN's assessment, the 8.6 g weight is feasible w/o battery, the prop looks like a Citabria prop and that alone is .82 grams lighter than the Vapor prop. Short can motor and there's another gram saved. Smaller frame and it adds up to ~9 grams.
Looking closer at the photo it's obvious there's two servos on the board, the elevator pushrod just happens to be in front of the main carbon frame and thus invisible.
Pouncer is offline Find More Posts by Pouncer
Old Oct 22, 2012, 06:37 AM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Based on PKZ's traditional pricing structure, likely $99.95 to start, but I'm sure they'll be cheaper @ discount sellers.
Old Oct 22, 2012, 01:41 PM
richos's Avatar
Joined Mar 2008
How can you put a price on a Product that does not exist
OK!!! Try googling PKZU1280 and PKZU1280 (NOTHING!)
OK . Next challenge
Who has a copy of the Jan 2012 Issue of (Electric Flight) magazine?
Now if you have a copy of the Jan 2012 Issue of (Electric Flight) magazine can you scan in the the page of the mini vapor PLEASE !!!
richos is offline Find More Posts by richos
Old Oct 22, 2012, 01:45 PM
Canada, QC
Joined Oct 2009
That was done in msg 4, previous page. Unless you're asking for somebody else to do it, to make sure Flyboy is not pulling our legs?
Old Oct 22, 2012, 02:31 PM
Western Nebraska
Joined Apr 2001
I am not pulling anyones leg...It is in the magazine.
Flyboy70 is offline Find More Posts by Flyboy70
Old Oct 22, 2012, 02:45 PM
richos's Avatar
Joined Mar 2008
http://www.youtube.com/watch?feature...G-TL0WnjE&NR=1
Thanks RealGambler so its a (HOAX) i thought it was
Just like the guys who posted a magnetic accelerator on you-tube And said it was a (Perpetual Motion machine)
Its got a cam on the side to make it work Ha! Ha!
I hate the internet
The more i watch this you-tube video , the more i (BELIEVE)
Is it me or does this (Perpetual Motion machine) look real
Fake or real , check this vid out
It will blow your mind . Ha ! Ha !
Old Oct 22, 2012, 04:39 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Originally Posted by Gordon Johnson View Post
Personally I doubt it's possible to drop the weight from 15g to 9.5g mostly with a lighter motor and battery. I'm not sure the rest of the weight reduction can come from the airframe. Gordon
I find the weight hard to believe also, but the original Vapor was advertised at 12 grams if I remember correctly.
TODD
I R Irv is offline Find More Posts by I R Irv
Wanted I Need a Parkzone (Vapor) DSM2 Rec/ESC/servo "Brick" *** Joe Pierson Aircraft - Electric - Micro & Indoor Airplanes 2 Mar 25, 2012 10:27 PM
Sold parkzone vapor bnf original $50.00 shipped chrisb22 Aircraft - Electric - Micro & Indoor Airplanes 3 Mar 03, 2012 01:25 PM
