Old Oct 23, 2012, 09:06 PM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, FL, Daytona Beach
Joined Nov 2007
Originally Posted by RCvehicleGuy View Post
The counter balances and less chord more span for the ratio is a good idea.
Rearward servos is a great idea! It should also help make up for the brick up front, 25 gram motor! VPP system too. Should balance it out.
Hand-cut kit or did you use a CNC machine? Kudos if it is hand-cut.
Chris G.
Hand cut. MY skeleton ones were laser cut, then I got hit with a stupid bill. Not that again!
Originally Posted by Free View Post
Talking about control surface size, on the V2(if there is one), you might want to make the ailerons a tad bigger for vpp.
BTW, What makes Nov 4th the magical day?
Free
Technically, this is version three, precision adaptation. I'll keep that in mind for Isis P3V2 though.
JR indoor?
OR is that the third? Third and second?
JR is that weekend. I forgot about that. My Nov 4th is our indoor fly-in.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 23, 2012, 09:35 PM
Joined Nov 2007
More contemplation...
I changed my mind on the batteries. I'm looking for some nano-tech 300mah 2s batteries. I despise nano's but I'll give them another try here.
Old Oct 23, 2012, 10:13 PM
Joined Nov 2007
The split aileron links look so much cooler than a single servo setup. I'll be using figure-4s on all surfaces along with russian z-bends on the servos. The Rods will be detachable in seconds without having to stress the servo, airframe, or control surface.
I'm going to get some black and white 32awg wire for the tail servos. I'll clip it about an 1" from the servo ends and simply insert the wire in the middle.
She's not looking too bad so far.
Description: Name: ImageUploadedByTapatalk1351048383.809389.jpg
Description:
Old Oct 24, 2012, 02:29 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
What ESC are you planning to use that can has a BEC that can handle 5 small servos?
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 24, 2012, 08:22 AM
Joined Nov 2007
E-flite 10 amp
Any of them should handle four micro servos. I forgot about the vpp servo though. It won't be any different than using three bigger servos.
Old Oct 24, 2012, 01:35 PM
Joined Nov 2007
I took these as I was leaving so excuse the quality. The elevator servo isn't glued in yet, but that's where it will go. The rudder will be right behind it on the other side.
I may have the rear servos on the same power leads just to save a little weight. The only thing is that I would have to solder the leads if the elevator servo fails. To solve that, I can put a small connector in line near the servo.
Joined Nov 2007
Description: Name: ImageUploadedByTapatalk1351102549.671199.jpg
Description: Name: ImageUploadedByTapatalk1351102564.739975.jpg
Description:
Old Oct 24, 2012, 04:19 PM
Fly for God, not for the World
Not Free's Avatar
United States, CA, SF
Joined Sep 2011
+1
Not Free
Not Free is offline Find More Posts by Not Free
Old Oct 24, 2012, 06:39 PM
Joined Nov 2007
I will. I don't want to intrude on privacy or anything, but you two are twins right? (feel free to ignore)
It weighs 60g with four servos and upper fuse (minus glue). I still need the rudder and SFGs. I may add another piece of carbon to the top for the upper fuse, if needed. How does 80g sound so far?
rx - 5g
esc - 10g
battery - 20g
Description: Name: ImageUploadedByTapatalk1351121813.497052.jpg
Description:
Old Oct 24, 2012, 07:02 PM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
Your weight sounds pretty good. What motor have you settled for?
Twins? That would be interesting.
Free
Free is offline Find More Posts by Free
Old Oct 24, 2012, 07:10 PM
Joined Nov 2007
The VPP system isn't mine, but a friend said I can use it since he isn't using it. I has a Hacker, but I'm not sure which one. I don't think it is the A20-34S though. This was one of the original units when they sold for less than $10.
If that doesn't happen, I have an AXI 2203 (20g). Other than that, I have an AX-2205 1500kv (26g).
Old Oct 24, 2012, 10:59 PM
Joined Nov 2007
Ailerons and Elevator complete
Rudder servo in place
It's amazing how much time goes into thinking about what you are going to do before you do it.
Description: Name: ImageUploadedByTapatalk1351137519.489283.jpg
Description: Name: ImageUploadedByTapatalk1351137538.449624.jpg
Description:
Old Oct 24, 2012, 11:06 PM
"Free" in Christ!
Free's Avatar
Joined Jan 2012
Looks nice!
I agree on the time comment.
Free
Old Oct 25, 2012, 05:40 AM
Mr. Foam, Tape, and Carbon
RCvehicleGuy's Avatar
Joined Feb 2011
Lookin' slick!
Chris G.
RCvehicleGuy is offline Find More Posts by RCvehicleGuy
Old Oct 30, 2012, 09:54 PM
Joined Nov 2007
I'm dropping the VPP. I don't want to damage it since it isn't mine.
Sold RCRCM Predator P3, Carbon, SoCal LCA_57 Aircraft - Sailplanes (FS/W) 3 Sep 02, 2012 03:59 PM
New Product Isis II Keenan smith Hand Launch 96 Jul 11, 2012 11:36 AM
Discussion 70 mm p3 f16 hop up chas650r Don's RC 2 Apr 06, 2012 10:20 PM
Build Log Isis - the Lico Look Alike: Maiden Success! boredom.is.me Indoor and Micro Models 140 Jan 15, 2012 04:57 AM
Question P3 Squall system in a P3 F16?? dmize Foamy EDFs 1 Nov 10, 2010 08:11 PM
