Old Oct 27, 2012, 05:16 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Currently the only telemetry Rx is the R7008SB
TimBle is offline Find More Posts by TimBle
Old Oct 27, 2012, 05:50 AM
TimBle is offline
Joined Dec 2009
Originally Posted by pilotpete2 View Post
Tim,
I see in the general features the mention of "Logic switch (condition switch only)"
I don't know if this the same as conditions.
/Bo,
If you look at the screen shot of the servo speed screen, there are 8 channels listed, but up at the top there is the indication that this is screen 1 of 2, so channels 9-12 are probably on the next page. Ch 13 and 14 are not proportional, so no servo speed control possible on those two.
The way the electric retract market is going, there will not be much use for the servo slow feature anyway, since all the new electric retracts with integral motors are non-proportional, but the ones I've seen run at pretty much scale speed anyway
Pete
yip I saw that but I'm looking for confirmation that its across all aircraft types.
It was not a big deal in the 8FG and I've lived without it but I have a few nasty handling airplanes that I'd like to experiment directly with conditions, i.e my Showtime
Old Oct 27, 2012, 07:16 AM
eitanro is offline
Find More Posts by eitanro
eitanro's Avatar
Tel Aviv-Yafo Ben Gurion, Israel
Joined Sep 2004
Is there a way to connect "normal" servos to the S-bus so that I will have telemetry?
eitanro is offline Find More Posts by eitanro
Old Oct 27, 2012, 07:53 AM
wwmilanl is offline
Find More Posts by wwmilanl
United States, TX, Katy
Joined Aug 2009
Yes there is, Take a look on this:
http://www.hobbyking.com/hobbyking/s...dProduct=24481
regards
wwmilanl is offline Find More Posts by wwmilanl
Old Oct 27, 2012, 08:05 AM
bossee is offline
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi,
Can You explain more what You want to be reported/displayed by telemetry in such case?
Non S.Bus servos can be used on S.Bus channel with Futaba SBD-1 S.Bus decoder:
http://www.futaba-rc.com/sbus/index.html
3 pages of S.Bus accessories can be seen here (Robbe):
http://www.robbe.de/rc-fernsteuerung...gen/s-bus.html
If You are talking about T14SG it is shipped with the FASSTest receiver R7008SB and it send telemetry data to transmitter via built in functions (receiver battery voltage, external voltage max. 70 V DC and aerial signal strength) and via external telemetry sensors connected on receiver S.Bus2 socket.
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTL7675
Same info from Robbe (Europe):
http://www.robbe.de/empfaenger-r7008sb-fasstestr.html
PDF manual R7008SB here for example:
http://www.jetsofbergen.no/sites/def.../motaker_2.pdf
Note that they say in the manual: "Analog servos cannot be used with the R7008SB in the FASSTest 12CH mode."
Futaba/Robbe telemetry sensors that You can connect to FASSTest capable receiver on it's S.Bus2 socket:
- Extra voltage sensor
- Temperature sensor
- Vario/altimeter (low cost)
- Vario/altimeter (precision)
- GPS multi sensor
http://www.robbe.de/rc-fernsteuerung...elemetrie.html
- Atmospheric (altitude) sensor
- Magnetic RPM sensor
- Optical RPM sensor
http://www3.towerhobbies.com/cgi-bin...SM&C=MKL&V=FUT
/Bo
bossee is offline Find More Posts by bossee
Old Oct 27, 2012, 09:03 AM
eitanro is offline
eitanro's Avatar
Joined Sep 2004
Originally Posted by bossee View Post
Hi,
/Bo
All I need for my F3K and F5J is to use normal servos, and to have an Rx battery telemetry.
The problem is that in the F3K fuselage there is no space for the decoder.
It looks like I would have to wait until Futaba will have non S-bus receivers with telemetry
Eitan
Old Oct 27, 2012, 09:28 AM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
Eitan
With the R7008SB receiver you still have 8 PWM (non S.Bus) channels you can use non-S.bus servos on those outputs. However, you'll save the most weight/space by installing S.Bus servos, they work really well in a sailplane. For Rx pack voltage you don't even need a senor, that information is sent directly from the receiver.
Steve
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old Oct 27, 2012, 09:30 AM
eitanro is offline
eitanro's Avatar
Joined Sep 2004
Thanks for the answer Steve,
I don't want to change all servos on all of my models (1 F5J and 4 F3K), it will cost to much and I will have to make a lot changes in my models.
Eitan
Old Oct 27, 2012, 09:53 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Will they be offering the transmitter only for us that want to upgrade?
RC Man is offline Find More Posts by RC Man
Old Oct 27, 2012, 09:55 AM
wwmilanl is offline
Joined Aug 2009
good question
+1, Agree, many would like to see the TX only option.
Old Oct 27, 2012, 10:02 AM
wwmilanl is offline
Joined Aug 2009
update?
Originally Posted by Skaluf View Post
Folks, I just received word that you should be able to pre-order 14SG's starting this weekend. Just to be clear, I'm talking about the market serviced by Hobbico (North America). Other distributors may have different plans.
Steve
Skaluf: Any update on the pre-orders? will be available a tx only option?
Old Oct 27, 2012, 10:16 AM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
Why is it that the Futaba reps can confirm everything except Aero flight modes. Futaba says "The 14SG Has it all & more". Is this a lie?
Slats! is offline Find More Posts by Slats!
Old Oct 27, 2012, 10:53 AM
Skaluf is offline
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
regards
You don't need a decoder with the R7008SB receiver it still has 8 PWM channels available, as well as S.Bus and S.Bus2 ports.
Steve
Site Sponsor
Old Oct 27, 2012, 10:54 AM
TimBle is offline
Joined Dec 2009
They can onl comment on what the factory has released and that appears to be mainly the changes between the 8FG and the 14SG. Steve will confirm the Airplane conditions extensions when he gets word from the head office in Japan
Skaluf is offline
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
This question was answered in response to your post on FG.
Site Sponsor
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 06:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 04:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 10:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 09:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 08:45 PM
