Old Jan 14, 2013, 05:05 AM
MalcolmHolt is online now
Find More Posts by MalcolmHolt
Brighton UK
Joined Dec 2010
I charged the new battery (6.0V 1800 NiMH) slowly and had a good flying session with the 14SG. It feels much more solid than the 8FG.
Then, as I was spending time tinkering with the transmitter at home, I decided to let the battery run down until the alarm sounded. I wanted to see if the vibes remained on or switched off after a few seconds and also get an idea of battery life.
I can confirm that the audible alarm and vibes both remain on until the transmitter is switched off. More interesting is the fact that the stock battery lasted for 11 hours and 58 minutes. A fair proportion of this was with the screen backlight on as I explored the menus.
I have no strong feelings either way on the NiMH/ Li-Fe debate but thought this bit of information might be useful to those of you who are undecided.
MalcolmHolt is online now Find More Posts by MalcolmHolt
Old Jan 14, 2013, 05:37 AM
spacewalker_ is offline
Find More Posts by spacewalker_
spacewalker_'s Avatar
Joined Dec 2012
does anyone know where i can get a charging cabel?
Can i cut off the wire from the original charger and put on 2 4mm gold contact stecker to charge the battery?
The reason why im asking, i read lots off bad things of the integratet electronic in the transmitter battery. So i removed the electronic and added a balancer wire.
Now i can and want charge the battery in the transmitter but on my own charger.
i think nobody unterstands my super english
I would also like to make a test how long my battery rans till the alarm comes.
But then comes a Message "please turn Transmitter off" how can i kick this message and make a test?
spacewalker_ is offline Find More Posts by spacewalker_
Old Jan 14, 2013, 05:43 AM
Joined Dec 2012
Originally Posted by RC Man View Post
How many telemetry channels or did I miss that. I assume it’s 14 just like the control channels but I have not seen that published.
32 telemetry chanels (robbe.de)
Old Jan 14, 2013, 05:45 AM
DougV is online now
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
That radio is not available here in the states yet. But if its like the 8fg, then I use this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSMF3&P=7
Doug.
DougV is online now Find More Posts by DougV
Old Jan 14, 2013, 05:49 AM
Joined Dec 2012
Hello Doug!
Thanks for your answer!
Im Happy that you unterstand me!
The Problem is, the charge plug is smaller then the plug on the t10cg.
They are not the same.
Old Jan 14, 2013, 05:55 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
Correct. It was done like that for a reason I guess, so you don't use the 10c (9.8v)charger with the 8/12fg (7.4 )
Doug.
Old Jan 14, 2013, 06:42 AM
Joined Dec 2012
Doug.
It dont matter. The T10CG came with only a charging cable (wire) not with a power supply only the cable you unterstand?
I did changed the standard nimh battery in the t10cg against a LIFE battery. Who i charge with my normal charger.
Because i removed this stupid electronic from the t14sg accu now who will just turn off the transmitter if the electronic thinks its ok. i can and want now to charge with my normally charger again. so i only need a charging wire.
you know that question if i can use the power supply who comes with the t14sg if i cut the wire and add 2x 4mm gold plugs to put it in my charger.
Old Jan 14, 2013, 07:00 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
Originally Posted by spacewalker_ View Post
It dont matter.
Yeah you can do that if you want, it's your power supply. I personally wouldn’t do that in case later on I want to sell the radio.
Doug.
Old Jan 14, 2013, 07:04 AM
Joined Dec 2012
The question who is open for me how does it look like UNDER the isolation? :S
Old Jan 14, 2013, 07:06 AM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
NO.
Use a power supply that suits your normal charger, assuming your normal charger is a LiPo balance/charger.
The electronics you stripped off are to balance & protect from overvoltage (explosion) if using the normal powersupply/charger (assuming again, youre on Robbe stuff, right? Dont charge the stripped battery while in your transmitter! Thats why Robbe had some electronics in the 'accu' and provided the 500mA 'steckdose')
numnutchris is offline Find More Posts by numnutchris
Old Jan 14, 2013, 07:08 AM
Joined Dec 2012
You dont unterstand
i dont want to use the charger that comes with the t14sg i want only the WIRE
i know modelflying for about 30 years so i know what i do.
The electronic is a big fail if you look in to google you will see that! suddenly in fly the transmitter turns off without low voltage beep.
1 guy lost his 3m edge 540 because of this !"§$%& so dont give a !"§$ of this damn electronic.
Old Jan 14, 2013, 07:23 AM
numnutchris
Joined Sep 2009
You dont unterstand
Something probably went lost in translation as you talked about 'use the power supply who comes with the t14sg'.
At what voltage did it cut off? And what is the voltage setting in the transmitter (LNK - WARNING - LOW BATTERY)?
Old Jan 14, 2013, 07:26 AM
Joined Dec 2012
Ok pictures say more like words right?
I dont want to use the power supply who comes with the transmitter.
only the cable
Old Jan 14, 2013, 07:56 AM
Mikarro is offline
Find More Posts by Mikarro
M$ Security
Joined Jun 2010
http://www3.towerhobbies.com/cgi-bin...93p?&C=MHF&P=7
Mikarro is offline Find More Posts by Mikarro
Reply With Quote  (Disabled)
Old Jan 14, 2013, 08:20 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
WOW that’s incredable. Is there a diagram somewhere that tells how you would hook up 32 telemetry devices?
RC Man is online now Find More Posts by RC Man
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 06:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 04:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 10:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 09:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 08:45 PM
