Old Feb 17, 2013, 02:38 AM
SalamSyed is offline
Find More Posts by SalamSyed
Fly Low-Fly 3D-Fly Often
SalamSyed's Avatar
United States, DC, Washington
Joined Oct 2009
Originally Posted by TimBle View Post
fully charged 6V pack is 1.5V x 5 = 7.5V
Under load that voltage should be lower than 7.5V for a 5 cell pack?
SalamSyed is offline Find More Posts by SalamSyed
Old Feb 17, 2013, 03:36 AM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
A transmitter does not place a massive load on the battery to drop the voltage significantly. My 14Sg comes off the charger at 7.4V at power up. It settles between 6.7V and 6.4V for around 5-6hrs before running to the factory set 5.6V within 3hrs.
am getting around 11hrs of Tx run time.
TimBle is offline Find More Posts by TimBle
Old Feb 17, 2013, 09:05 AM
SalamSyed's Avatar
Joined Oct 2009
I left it on charge late in the night and now it shows 7.2V but no light indication on the charger to show it is charging. When I hooked up the charger, the light was on and after a few minutes, it started flashing with a few seconds gap and then goes off after a few minutes.
Is this normal?
Old Feb 17, 2013, 09:37 AM
TimBle is offline
Joined Dec 2009
Bit thati have noticed. I just leave it on charge overnight. Will check it tonight.
Old Feb 17, 2013, 01:10 PM
SalamSyed's Avatar
Joined Oct 2009
I charged mine to 7.4V now but the light on the charger remained off all the time. Can anyone confirm this is how it is on their chargers too?
Old Feb 17, 2013, 01:54 PM
Finnspeed is online now
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Sounds like your charger works otherwise OK but has a LED that is failing.
Finnspeed is online now Find More Posts by Finnspeed
Old Feb 17, 2013, 02:34 PM
TimBle is offline
Joined Dec 2009
yeah just checked mine the LED stays rd while the Tx is plugged in
Old Feb 17, 2013, 05:46 PM
SalamSyed's Avatar
Joined Oct 2009
Thank you for confirming. I think I need to call the service center to see what they say about it.
Old Feb 18, 2013, 07:13 AM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
I had the pleasure of trying this radio out and I really like the feel of it. The switches are all easy to reach. I do not fly with a neck strap and often hold my radio in one hand. I currently fly the 14mz and love my radio. But I will be ordering the 14sg here shortly.
I fly mostly gliders and the programming is very nice. And is not complicated. Like some of the other radios out there. Futaba has hit another one out of the park in my opinion.
Joe Wydronek
J. Wydronek is offline Find More Posts by J. Wydronek
Old Feb 18, 2013, 08:23 AM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
When does "late February start"?
The 31 of feb ? LOL
ripacheco is offline Find More Posts by ripacheco
Old Feb 18, 2013, 09:35 AM
TimBle is offline
Joined Dec 2009
late February would be around the 25th
Old Feb 18, 2013, 11:16 AM
bpd964 is offline
Find More Posts by bpd964
Change is good...
Connecticut
Joined Mar 2008
Any idea how we can connect a Dragon Link LRS and the Fatshark Dominator tracking cable to this TX simultaneously?
There is no removable module to use PPM pins so the only choice is to use the trainer socket. Since both use the trainer socket, how can we make these system work together?
bpd964 is offline Find More Posts by bpd964
Old Feb 18, 2013, 12:31 PM
HaventFlownSince2014 is online now
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
There may be a way, but likely you are just creating busy-work for yourself.
Easiest answer is to simply use the trainer for DL and use seperate power for your fatsharks... Sorry if that is not the answer you are looking for.
HaventFlownSince2014 is online now Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Feb 18, 2013, 01:28 PM
bpd964 is offline
Change is good...
Connecticut
Joined Mar 2008
I don't mind using a separate power source for the fatsharks at all. Wasn't sure that was the only physical connection required from the TX. If power is the only concern, Then I'm ok with that because I use a separate power source for it currently with my Aurora A9.
Old Feb 18, 2013, 01:34 PM
USA, GA, Atlanta
Joined Nov 2008
Fatsharks require no physical connection to the rc transmitter at all. The only items your sharks are tied into will be the video rx and power.
If you are just getting into FPV read the stickies in the FPV sections for valuable information. Also, fpvlab.com is priceless.
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 07:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 05:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 11:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 10:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 09:45 PM
