Old Nov 10, 2012, 08:41 AM
tim_uk is offline
Find More Posts by tim_uk
Joined May 2008
once again the post man has let me down, no connectors today saturday post is flakey at the best of times
here's how its looking so far, its a very tight squeeze! thanks for the advice on the motor Bill, looks the part at least. boats upto 650 grams now so i've given up on weighing it!
tim_uk is offline Find More Posts by tim_uk
Old Nov 11, 2012, 06:33 AM
tim_uk is offline
Joined May 2008
got a bad case of mission creep while I wait for parts, i'm already thinking about the next boat! i really want to go the whole hog and design a hull from scratch so i've dusted down the drawing board (which i haven't used for about 20 years!) and hacked away at some depron. I'm looking at this material for a future build as it seems to be used extensively for the aero modelling, is really cheap and super light weight and should be strong once its been glassed. I also like how easy it is to cut!
however this thing didn't fit together very well so i have a lot to learn, especially working out how to get the curves in the panels correct. I know its something to do with lofting so its time for more research!
Old Nov 11, 2012, 10:13 AM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Maybe try templates off of the actual frame, typically you get the keel line to fit best and then sand to fit the sheers. Regardless it looks well put together and quite solid to me, nice work.
Kcal is offline Find More Posts by Kcal
Old Nov 17, 2012, 04:52 AM
tim_uk is offline
Joined May 2008
finally stuck my boat in the water however it didn't go particularly well! the boat goes really well forwards but not so well backwards. I must have something set up wrong because it seems almost random whether the motor started forwards or backwards?! also when i was trying to advance the throttle suddenly it would blip into reserve. this went on for a few mins and then the flexishaft came loose
has anybody got any idea whats going wrong? i've got a spektrum dx5e and the receiver that came with it, the throttle stick rests at the bottom and i was hoping to push it upwards and that would make it go?! but it was starting forwards (sometimes backwards) and then when i pushed it a bit more it went backwards or carried on forwards. i.e completely random. is the speed controller knackered perhaps?
anyway i did get a couple of nice pictures, not a bad spot for a first float
Old Nov 17, 2012, 05:04 AM
tim_uk is offline
Joined May 2008
i've just had a another go with it sat in the bench, the throttle is all over the place, there is no correlation between which direction i push the stick and the direction that the motor spins. somethings not right!
ok so i've worked out the speed controller needs programming, i've tracked down a manual of sorts but its written in terrible engrish, has anybody got a guide for progamming a HobbyKing 50A Boat ESC 3A UBEC
right now its just making loads of mad beeping sounds!
Old Nov 17, 2012, 08:17 AM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
Pacific
Go to HK site and your esc file. Next go to files and copy the 10 pages on copier. They say the files manual is wrong and go to www.link,,,,,,,????????
Mikedown is offline Find More Posts by Mikedown
Old Nov 17, 2012, 08:31 AM
tim_uk is offline
Joined May 2008
think i've worked it out, i had to teach it the full range of stick movement, like a complete novice i had no idea about this! time for another go and this time i have a fishing rod
Old Nov 17, 2012, 09:12 AM
Mikedown is offline
Closed Account
Joined Jul 2006
pacific
I did some hunting. Hook up lipo ; the last thing you do. Also HK has a program card; Turnigy works with HK super simple escs and card must be a besc card by Turnigy.
Old Nov 24, 2012, 08:48 AM
tim_uk is offline
Joined May 2008
5th go and finally after destroying a flexifsahft + coupling, embarrassing myself in front of a mate (excitedly put the boat in the water convinced it was going to shoot off forwards and it just submarined backwards and unravelled the flexishaft with a load crack! ) and using the fishing rod retrieval method a few too many times i've finally got it working. i've only managed to use about half throttle so far, conditions haven't been ideal. today was a bit too windy and the boat was all over the place. flipped it over a couple of times so i'm going to wait for flat calm, flat water before running again.
the speed is quite incredible by the way! thanks for everyones advice who chipped in
Old Nov 24, 2012, 10:15 PM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Now it's time to start making adjustments.Make one adj. at a time .Good luck with it .
highflyerbill is offline Find More Posts by highflyerbill
Old Dec 02, 2012, 08:11 AM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
Any chance of some video on your next outing?
mozzyrocks is offline Find More Posts by mozzyrocks
Old Dec 02, 2012, 11:41 AM
tim_uk is offline
Joined May 2008
unfortunately i've only got some blurred footage of my last outing, all you can see i wake and hear it zipping about, i propped my phone up on the bank and it chose to focus on a bit of grass which was really really annoying however you can get an idea of the glorious 10 mins i had before the infernal thing broke again!! i'll leave in the moment of disaster so you can hear my pain.
l think the set up is just too powerful, i hardly got it above half throttle and the thing was screaming about however any kind of weakness like the plasticy coupling (which was the only one i could find to fit the motor and the odd sized micro flexishaft) is just not up to the task. soon i tried pushing the throttle a bit it snapped. i've also flipped it more than once and drowned a rudder servo.
anyway i'm now looking for a slightly bigger boat to build! i think the motor, speed controller and batteries i have would be ok powering something a lot bigger than 16inch and what i'd really like is a nice laser cut wood kit for a tunnel hull, a cat or even a mono, something about 25-30 inch in size. I'm struggling to find anything suitable, it doesn't help being in the UK but i'd consider buying from overseas. if anyone has any ideas or can point me in the right direction i'd be grateful. failing that i'm on the hunt for plans!
Old Dec 03, 2012, 01:30 PM
tim_uk is offline
Joined May 2008
pacific dictator (3 min 26 sec)
i'm gutted you can't see the boat or even hear it properly. must try harder next time!
Old Dec 03, 2012, 08:01 PM
Mikedown is offline
Closed Account
Joined Jul 2006
Tim Uk- just get a smaller motor for your 16" balsa unit is all. Now from what i see; it moving back and forth, it has good speed for that size. All that work, don't give up, you learned alot which is great.
Old Dec 04, 2012, 06:36 PM
tim_uk is offline
Joined May 2008
i'm not giving up on this endeavour i'm just having a rethink and drawing up a new boat about 1.5 times the size. the kit that i bought was never intended for radio so sealing it up has been difficult, all the gear had to be crammed in and the components just haven't been strong enough. i'm therefore going to fit a sensible sized flexifshaft and a solid metal coupling this time. its currently costing me about 10 every time i run and i can probably build a new hull for not much more than that with the stuff i have already so i'm biting the bullet.
i've started drawing a new boat in photoshop, its not exactly suited to the task but i'm only roughing out ideas at the moment. i've taken a few measurements from the existing hull and scaled them up to try and keep things vaguely in proportion. at the moment i can't seem to get the rocker line right, so i need to do more research and perving at boat pron oh and i'm going it call it 'Bigger Shaft' for a giggle
I'm still on the hunt for a decent laser cut kit as well, seems to be very few options out there, especially in the uk I have developed a penchant for these tunnel hulls so if anyone out there knows of a kit or even a decent tunnel plan I would be eternally grateful.
Discussion Test dictation Jim T. Graham Test Forum 1 Oct 20, 2012 08:05 PM
For Sale Nikko dictator cars and parts for sale superchamp78 Cars - Cars and Parts (FS/W) 2 Sep 13, 2012 09:55 PM
Question Pacific Balsa / Dictator? sledge21 Micro and Sub-Micro Boats 5 May 28, 2012 10:16 AM
Alert Dictator Obama Issues New Threat BE77 Pilot Life, The Universe, and Politics 2 May 04, 2012 10:24 AM
Build Log Balsa Kit RC Conversion - Pacific Balsa 'Ibis' boingk 1/2A Planes 7 Oct 04, 2011 01:21 AM
