Old Oct 22, 2012, 10:26 PM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
I would look at the Graupner carbon filled props these are strong props that will hold up to your application .Anything from 29mm t0 42mm in 4 mm shaft size . Because I've never built a boat of this size I would be a bit Conservative . Try a 34mm or 36mm size prop . Run for one min come in and ck. the temps .if it's cool then you can go bigger .Best thing about these Graupner carbon filled props is they are relatively cheap and you don't have to sharpen and balance them . I'm sure you can find them some where near you , if not go to www.offshoreelectrics.com
highflyerbill is offline Find More Posts by highflyerbill
Old Oct 25, 2012, 01:05 PM
tim_uk is offline
Find More Posts by tim_uk
Joined May 2008
not much to report, still in the sanding and waiting for stuff phase. current weight minus the motor, receiver and servo is 414g so it looks like i've blown my 500g target but seeing as i've no idea what constitutes a particularly lightweight boat i'm not that fussed!
hopefully I'll have a bit of time to glue it together this weekend
tim_uk is offline Find More Posts by tim_uk
Old Oct 27, 2012, 11:27 AM
tim_uk is offline
Joined May 2008
well this was always going to be a tight squeeze! there isn't going to be much room to play around with the CG once I start gluing motor mounts etc. what are people thoughts on the balance point for a small tunnel hull like this? I read something about 35% however is that from the front or the back? should i be aiming for bow heavy, stern heavy or somewhere in the middle? maybe its impossible to work out until the thing is in the water?!
Old Oct 27, 2012, 11:43 AM
Joined Nov 2009
30% measured from rear of transom , not the sponsons is a good starting point . The bottom of the strut about a quarter inch or an 1/8 inch up from bottom of the rear of sponson . Should be a good starting point . And have some fun .
Old Oct 27, 2012, 08:18 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
If you mount the receiver up on a shelf at the transom I bet you could slip the battery under it and further rearward if you needed to.
Kcal is offline Find More Posts by Kcal
Old Oct 28, 2012, 06:12 AM
tim_uk is offline
Joined May 2008
thanks for all the information guys, i'm trying to take it all on board (excuse the pun )
Already having modified so many bits and trying to work out how to squeeze RC into a boat clearly not designed for it i'm thinking I should have gone the whole hog and designed the boat from scratch as well (which might have been even more nuts for a first time build!) or built from a plan (probably more sensible) ah well looking at the weather outside in England I have 6 more months of dark, cold and wet weather to design and build some more of these boats!
anyway back to the boat at hand I've glued all the main bits together now and made a crappy stand, i'll get some more pictures up later when the latest coat of varnish has dried.
Old Oct 28, 2012, 11:08 AM
tim_uk is offline
Joined May 2008
sanding and more sanding. trying to get the bottom of the sponsons really flat and keep the edge sharp. i've also added another layer of balsa under the main hull to keep everything smooth. it'll be a shame to start drilling holes for all the hardware
Old Oct 30, 2012, 07:44 PM
tim_uk is offline
Joined May 2008
still waiting for parts to turn up, slight tinge of regret when i noticed on the hobby king email it said allow 45 days for delivery hopefully it won't be that bad.
i'm painting now and with this colour scheme i really should run it on Lake Coniston, its not that far away and I'm thinking get there at dawn, freezing cold, glassy water, pay my respects to Donald Cambell. oh i'm getting all misty eyed now!!
Old Oct 31, 2012, 06:54 PM
tim_uk is offline
Joined May 2008
still no sign of the motor, been amusing myself with silly paint schemes. are there any good guides online about how to fit a flexi-shaft? is there a trick to bending the brass tube in only one axis? i've not come across any info on this dark art?!
Old Oct 31, 2012, 07:26 PM
Kcal is offline
Joined Jul 2008
Tim,
If you simply “have at it” and make only one slight curve it will always be in a single axis. Barring that to anneal or soften the brass heat it up cherry red with a torch or gas stove… I added a video below. I have never found the need to anneal it and simply worked slowly but surely, in the sizes/diameters we are dealing with it’s pretty easy to do.
Annealing Brass (6 min 10 sec)
Old Nov 01, 2012, 09:19 AM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
balsa
Your best bet is to get 3/16" brass tubing, get 2 pieces, one for spare. You can anneal with torch or bend by hand with CARE. Now use .130 cable and no liner for stuffing tube. When hand bending, wear gloves, to save your hands from injury. Take your time bending and check each time so you don't get kinks. When you get correct lenght and fit nicely into strut. cover join with heat shrink so no leaks occurr. Now if you want liner in stuffing tube, use 7/32 brass tubing and you'll have to sand liner alittle to make it fit but also makes a snug fit and won't move on brass. Now here's a tip given to me by Erney Lazenby of U.K.; sand flex cable except at the coupler and where cable goes into cable shaft. Reason is friction is cut down especially where liner is not used and less heat occurrs.
Mikedown is offline Find More Posts by Mikedown
Old Nov 03, 2012, 05:12 PM
tim_uk is offline
Joined May 2008
modifications to the original design continue, had to make something to put the rudder further back. i've also made a bit of mess of the rudder with the dremel trying to open up the water cooling slot, ah well. still no sign of the motor either
Old Nov 04, 2012, 07:18 AM
Joined Nov 2009
You can eliminate bracket you made for the rudder . All you need for this size boat is a L bracket and two bolts . Move the L bracket to the RH edge of the tub drill two holes ,On second thought it looks to be to much trouble with that bracket . But it,s just a thought .
Old Nov 09, 2012, 07:02 PM
tim_uk is offline
Joined May 2008
got the motor at last so i've finalised the insides, made a battery holder, drilled and fitted the shaft, cut the flexi shaft, added some extra supports, drilled some pointless holes and covered everything in epoxy. everything is ready to screw in, just waiting on some XT60 connectors and its ready to float. its going to fun finding out what happens, i think the battery is a little on the large side!
Old Nov 10, 2012, 06:59 AM
Joined Nov 2009
looks like your about ready to have some FUN .Good luck with it . It's a good looking boat .
Discussion Test dictation Jim T. Graham Test Forum 1 Oct 20, 2012 08:05 PM
For Sale Nikko dictator cars and parts for sale superchamp78 Cars - Cars and Parts (FS/W) 2 Sep 13, 2012 09:55 PM
Question Pacific Balsa / Dictator? sledge21 Micro and Sub-Micro Boats 5 May 28, 2012 10:16 AM
Alert Dictator Obama Issues New Threat BE77 Pilot Life, The Universe, and Politics 2 May 04, 2012 10:24 AM
Build Log Balsa Kit RC Conversion - Pacific Balsa 'Ibis' boingk 1/2A Planes 7 Oct 04, 2011 01:21 AM
